spl23
Fixing a missing taskbar on the x86 image (obsolete)
Sat Dec 24, 2016 11:40 am
Several people have reported that the x86 image boots and then shows just a desktop and wastebasket without a taskbar. This seems to be caused by either some incompatibility with the on-board sound device in the target machine and the Linux ALSA sound architecture, causing the volume control plugin on the taskbar to crash, or the CPU monitor plugin crashing due to some incompatibility with the host machine. We'll investigate these and hopefully find fixes for the next release, but in the meantime, the workaround is to remove the plugins from the panel.
To do this, here are the steps. (You'll need to be running with a persistence partition for the changes to be saved.)
Open a terminal (Ctrl-Alt-T)
Launch Geany to open the lxpanel configuration file - geany ~/.config/lxpanel/LXDE-pi/panels/panel
There are two sections which might cause the problem. The volume control is:
Plugin {
  type=volumealsa
  Config {
The CPU monitor is:
Plugin {
  type=cpu
  Config {
    ShowPercent=1
    Foreground=#a9a9a9a9a9a9
    Background=#d3d3d3d3d3d3
Try deleting each in turn, and see if it fixes the problem for you.
If you do find that one or the other of these fixes the problem, it would be much appreciated if you could please post here and let us know!
carvellw
Re: Fixing a missing taskbar on the x86 image
Wed Dec 28, 2016 3:51 pm
I removed the lines you listed and the taskbar is still missing.
nipponese
Wed Dec 28, 2016 10:23 pm
Same experience as @carvellw. Commenting out these lines did not fix the issue.
ShiftPlusOne
Wed Dec 28, 2016 10:37 pm
Is persistence working? Does the change remain in the file after you reboot?
nipponese
Thu Dec 29, 2016 12:07 am
ShiftPlusOne wrote:Is persistence working? Does the change remain in the file after you reboot?
Yes, just booted the machine from off. The lines were still commented out. I have another theory: The taskbar seems to flash when the wifi drops or switches to another network, so that may be the reason.
ShiftPlusOne
Thu Dec 29, 2016 1:25 am
I don't remember the command off the top of my head, but you can try running lxpanel with the LXDE-pi(?) profile to see what went wrong. Simon should be able to provide the exact command. That should tell you why it's crashing. There is also a .log file that contains that information, but I don't have the path to that right now either.
spl23
Thu Dec 29, 2016 8:45 am
ShiftPlusOne wrote:I don't remember the command off the top of my head, but you can try running lxpanel with the LXDE-pi(?) profile to see what went wrong. Simon should be able to provide the exact command. That should tell you why it's crashing. There is also a .log file that contains that information, but I don't have the path to that right now either.
lxpanel -p LXDE-pi
is what you need - run that from a terminal (Ctrl-Alt-T to open one from the desktop) and see what happens.
bensimmo
Thu Dec 29, 2016 3:16 pm
Just for some feedback
DISC worked fine (MagPi cover)
PenDrive written from downloaded ISO, booted up and no Taskbar.
switching out (C-A-F1) and killing ( sudo pkill lxsession), logging back in did not help (as per MAgPi, pg76)
Though a reboot worked and it's showing now.
(since you mention ALSA, that is HDA NVidia (Alsa Mixer on this))
billis2020
Thu Dec 29, 2016 7:09 pm
I have this problem too and i need HELP!
nipponese
Thu Dec 29, 2016 9:16 pm
lxpanel -p LXDE-pi
Strangely, the taskbar re-appears again after running this command, but then disappears when I kill the command.
Here's the output:
[email protected]:~ $ lxpanel -p LXDE-pi
** Message: x-terminal-emulator has very limited support, consider choose another terminal
** Message: Connecting ...
** Message: Status changed to down
** Message: Status changed to opened
** Message: Connected to dhcpcd-6.7.1
** Message: Status changed to connected
** Message: wlan0: Associated with <my SSID>
** Message: wlan0: Configured 192.168.1.<x>/24
** Message: wlan0: WPA status connected
** Message: wlan0: Received scan results
** Message: bt: Name org.bluez owned on DBus
** Message: bt: New agent manager found
** Message: bt: No adapter found
ShiftPlusOne
Thu Dec 29, 2016 10:06 pm
Could you post your ~/.cache/lxsession/LXDE-pi/run.log ?
spl23
Thu Dec 29, 2016 10:10 pm
nipponese wrote:Strangely, the taskbar re-appears again after running this command, but then disappears when I kill the command.
Here's the output:
That's exactly what should happen - including the taskbar vanishing when you kill the command. It looks as if something is causing the taskbar to crash at first boot, but whatever it is goes away later on. I've actually seen something similar on my Mac mini - I get a taskbar crash on boot but can then restart it later and have it work fine. We'll carry on investigating, but if you could provide the log file ShiftPlusOne suggests above, that would be helpful.
nipponese
Fri Dec 30, 2016 7:37 am
ShiftPlusOne wrote:Could you post your ~/.cache/lxsession/LXDE-pi/run.log ?
Couldn't attach a .log or .txt, and file was too big to paste directly into post, so here's the pastebin:
https://pastebin.com/reZPefvv
spl23
Fri Dec 30, 2016 11:33 am
That's really helpful, thank you.
It looks as if the CPU monitor crashed, rather than the volume control. We've seen this happen occasionally in the past, but have never been able to repeat it - looks like it may be a bigger problem on x86 builds. (Which would make sense.)
To confirm that this is indeed the issue, you could try removing the CPU monitor from the taskbar instead of the volume control. Follow the directions in the post at the top of this thread, but remove this section of the panel file instead:
Plugin {
  type=cpu
  Config {
    ShowPercent=1
bensimmo
Fri Dec 30, 2016 12:40 pm
Is there any way the taskbar can ignore the crash and carry on regardless? (Which seems the sensible way to me) Or is it just the way the taskbar works?
(Interested over actually trying to help :oops: )
spl23
Fri Dec 30, 2016 12:46 pm
bensimmo wrote:Is there any way the taskbar can ignore the crash and carry on regardless? (Which seems the sensible way to me) Or is it just the way the taskbar works?
Unfortunately not - the plugins are shared code libraries which are loaded by the taskbar at startup, and if any one of them segfaults, it invariably takes the taskbar down with it. The only exceptions to this are applications which show icons in the system tray, which are completely separate applications that just provide an icon to a specific part of the taskbar - it might be possible to rewrite all plugins to work like this, but then you'd lose the ability to choose the order they appear, nicely space them out, etc. It'd be a lot of work to try, and I don't think the results would be entirely satisfactory. (I'm not saying crashing plugins taking the taskbar down is satisfactory either, but it's probably the lesser of two evils at present...)
billis2020
Fri Dec 30, 2016 2:38 pm
When i delete the lines they return back after reboot and i use persistence (i have usb stick)
nipponese
Fri Dec 30, 2016 7:20 pm
spl23 wrote:That's really helpful, thank you.
Ok, gave this try and it seemed to work. I ran it through my "test" (compiling ruby 2.2 via RVM) and the taskbar didn't disappear or flicker as it normally does.
spl23
Fri Dec 30, 2016 8:38 pm
Thank you very much for the confirmation - I'll have another look through that plugin and see if I can see any likely failure modes.
fos
Mon Jan 02, 2017 4:53 pm
I was experiencing an intermittent missing menu when using Raspbian PIXEL on my 2007 vintage Dell Inspiron and a usb memory chip. After setting the audio device settings, I have not had the menu disappear for several days.
YMMV. I will report further is the menu problem returns.
v/r
Jeff
https://faroutscience.com
carvellw
Tue Jan 03, 2017 2:13 pm
So i didn't try the removing of the CPU monitor line. But I did unplug the ethernet cable then reboot. After the reboot the taskbar came back and working just fine. I then reboot with the ethernet cable in and the taskbar does not come up. I confirmed that it does not show up when ethernet cable is plugged in.
harmen
Tue Jan 03, 2017 10:09 pm
On my HP Elitebook 8440p, I #-ed out:
Plugin {
type=cpu
Config {
ShowPercent=1
in the config file, did a reboot and I have a taskbar on top of my screen.
billis2020
Thu Jan 05, 2017 11:51 am
Deleted CPU plugin and now my taskbar is back!
dgordon42
Tue Jan 10, 2017 11:57 am
I also have had problems with the Task Bar intermittently disappearing for 10 to 20 seconds, then usually but not always reappearing. It tends to do this when there is lots of activity on the USB Memory Stick I'm booting from.
I can always reproduce the snag by running 'sudo apt-get update'. The Task Bar will always cycle once or twice while apt-get runs.
I'm running PIXEL with persistence on a 10 year old Dell Inspiron 1501 laptop with (unusually) an AMD Athlon processor.
I can confirm that commenting out the CPU activity app entry in '~/.config/lxpanel/LXDE-pi/panels/panel' has 100% fixed my problem, I've been running for the last day or so without a problem, before I would be lucky to get past 20 minutes.
Hope this helps,
Dave.
GuruLarsson
Fri Feb 03, 2017 1:30 pm
I tried to run Pixel on an old HP laptop, Compac 8510w and I got the same problem.
I then booted from the same USB stick on a Fujitsu S710 and there it worked fine toolbar and everything.
Yesterday I found this thread and thought I should have another go with the HP laptop and we-hey it worked like a charm! with the same USB stick, so it seems that I had made it work on the Fujitsu laptop it later worked on the HP laptop, I thought that might help others to figure out what is going on in the code.
Great idé to port Pixel to x86 and I really hope it will com an installer so I can put on the internal hard-drive on the laptop.
Gunnar
Return to “Raspberry Pi Desktop for PC and Mac”
