david reeves
RPI3 Jessie - Pixel but doesn't start-still LXDE/LXpanel
Thu Dec 22, 2016 7:54 pm
RPI3 with Jessie - Pixel is installed but won't start either initially or startx from cmd line - both start LXDE/LXPanel. I've googeled everything available. Anyone have any ideas? Thanks!
david reeves
Re: RPI3 Jessie - Pixel but doesn't start-still LXDE/LXpanel
Thu Dec 22, 2016 8:18 pm
Interesting ... couldn't find /usr/share/pixel-wallpaper/ directory. Does this indicate that PIXEL was not installed correctly?
ShiftPlusOne
Fri Dec 30, 2016 9:53 pm
How did you determine that it has been installed?
HawaiianPi
Fri Dec 30, 2016 11:06 pm
david reeves wrote:I've googeled everything available.
Not likely.
We need details...
Where did you get the Raspbian Jessie with Pixel image (and what is the filename)?
Did you verify the SHA-1 hash (checksum)?
How did you extract the image file?
How did you write the image file to your SD card?
How is your Raspberry Pi3 set up (screen+keyboard+mouse, headless SSH, etc.)?
If there was a guide you used, post a link.
david reeves
Sun Jan 01, 2017 6:40 pm
Thanks for the reply!
Fortunately I have this one wrapped NOW...apparently there was an issue with installing the Pixel and a conflict with another installed desktop package. It was an older Rasbian, originally Wheezy updated to Jessie that I was adding Pixel to. When I installed the pixel updates it appeared that it was ok but apparently not when I removed and re-installed them I found an error.
Thank you again for the reply!
