lestra
Can't connect laptop using putty with Raspberry pi 3 B
Fri Dec 16, 2016 1:00 pm
1) I connected my raspberry pi 3 B with laptop using ethernet port and in cmd wrote ipconfig, I double check it using app angrryip and the ip I got from the app and cmd as well was (raspberrypi.mshome.net)192.168.137.89
2a) After that in Putty I insert that ip adress "192.168.137.89" after running it, I got the msg "Connection was refused"
3)Laptop windows 7, 64bit.
Can you help me resolving this problem? :?
lestra
Re: Can't connect laptop using putty with Raspberry pi 3 B
Fri Dec 16, 2016 2:13 pm
So if I got it right I need just to make an empty file with name "ssh" and extension "txt"?
Martin Frezman
Fri Dec 16, 2016 2:19 pm
lestra wrote:So if I got it right I need just to make an empty file with name "ssh" and extension "txt"?
In the current implementation, the file must have no extension. So, lose the ".txt" extension.
Yes, doing this is tricky in MS Windows.
Hopefully, this will be fixed in a future version.
If this post appears in the wrong forums category, my apologies.
lestra
Fri Dec 16, 2016 2:28 pm
Thank you guys, it is working now. :D
B.Goode
Fri Dec 16, 2016 2:29 pm
Exactly that.
The Release Notes do not say that: you have invented it. Adding that extension will prevent it working as described.
Edit: I see you replied as I was typing this. Left here as emphasis for anyone else who encounters this thread.
