GPIO Server stops after reboot
Posted: Tue Dec 06, 2016 5:40 pm
by HombreSolaire
I use pigpio in a project on my raspi.
To get pigpio to work I need to activate "GPIO Server" in the raspi-config (entry AB).
Unfortunately after a reboot this Server needs to activate again via raspi-config. Therefore I see no possibility to run my python script at startup (etc/rc.local)
I would very much apreciate some advice here.
LG
HombreSolaire
Re: GPIO Server stops after reboot
Posted: Tue Dec 06, 2016 6:32 pm
by joan
Use the following command (once) and the daemon should start at boot.
sudo systemctl enable pigpiod
The raspi-config option defines whether the server can be used over the network or just locally.
Posted: Tue Dec 06, 2016 6:55 pm
by HombreSolaire
Thanks joan for the quick response.
I will try that.
regards
HombreSolaire
Posted: Wed Dec 07, 2016 2:52 pm
by HombreSolaire
Thanks again,
worked like a charm
I wonder how can anyone know this stuff? Is it in the man pages of pigpiod? I have no idea?
regards
Hombre
Posted: Wed Dec 07, 2016 2:56 pm
by joan
HombreSolaire wrote:Thanks again,
worked like a charm
regards
Hombre
If falls between two stools, as we say.
It's not part of pigpio, it's part of a Raspberry Pi Org change to Raspbian.
