GPIO pin doesnt deliver power
Posted: Mon Dec 05, 2016 12:58 pm
by antonbruhn
Hello!
Im up to a project with a relay. But the relay doesnt click when im running the script, there is a small led that blinks when im running the script so its coded right but it doesnt click.
When i take the signal wire and connect it directly to the 3,3v gipo pin the relay clicks. so its just like the gpio pin 26 doesnt deliver my power. any ideas what this can be ?
Re: GPIO pin doesnt deliver power
Posted: Mon Dec 05, 2016 1:02 pm
by mahjongg
GPIO pins are not designed to provide power!
They only can deliver a few mA, and only either a 0V or a 3.3V signal.
They are designed as control signals.
To drive a relay you will need a relay driver.
Beware that commercial relay driver boards are normally designed to be driven with 5V logical signals, NOT with 3.3V signals.
Be doubly careful to not under any circumstance get more than 4Volt on a GPIO, as that will destroy the GPIO, and thus the PI!
This can happen with badly designed relay boards, so be careful with them. Best if the board has a schematic you can post here to ask for advice.
Posted: Mon Dec 05, 2016 1:04 pm
by antonbruhn
mahjongg wrote:GPIO pins are not designed to provide power!
Its only a signal that i need.
like 20 mAh
Posted: Mon Dec 05, 2016 1:10 pm
by mahjongg
That's too much, a GPIO cannot drive a relay directly!
Also you MUST add a reverse diode across the winding's of the relay, because if you break the current to the relay coil, a large negative voltage will appear across the winding's, which will destroy the relay driver, if you do not short that voltage with a diode.
Google for a relay driver, there are plenty to be found.
Posted: Mon Dec 05, 2016 1:13 pm
by antonbruhn
i bought this. i think it is a relayboard.
http://www.electrokit.com/relakort-x2-5v.49419
Posted: Mon Dec 05, 2016 1:14 pm
by joan
like 20 mAh
A GPIO may be able to deliver 20mA. It won't be able to drive much more.
Do you realise that the back EMF from a collapsing relay coil could destroy the GPIO and the Pi?
If you know what you are doing you could use two or more GPIO in parallel to supply the current.
If you destroy your Pi please don't come back here and complain.
Posted: Mon Dec 05, 2016 1:54 pm
by antonbruhn
so how do i use a relay board?
Posted: Mon Dec 05, 2016 2:01 pm
by gordon77
You add an interface, eg transistor, opto isolator etc.
What relay are you using ?
Posted: Mon Dec 05, 2016 2:27 pm
by drgeoff
antonbruhn wrote: Its only a signal that i need.
like 20 mAh
Learn to get your units right. mAh is current multiplied by time. Often used to specify battery capacity.
Posted: Mon Dec 05, 2016 3:01 pm
by joan
antonbruhn wrote:so how do i use a relay board?
The relay module you have linked to will be safe. It isolates the relay itself from the Pi with suitable electronics.
If it operates from the 3V3 pin (pin 1) then the voltage isn't a problem, it's just the current. I would try connecting two GPIO to the relay module input rather than 1. Switching them both on should work to switch the relay module on.
Posted: Mon Dec 05, 2016 5:55 pm
by davidcoton
joan wrote: I would try connecting two GPIO to the relay module input rather than 1. Switching them both on should work to switch the relay module on.
But as you said earlier,
@antonbruhn Unless your program always switches the two GPIOs together, without any possibility of interruption, sometime you will end up with a GPIO LOW connected to a GPIO HIGH. Potentially that is "Bye bye Miss Raspberry Pi".
I suggest using a single transistor (with a base resistor of 10K) to drive the relay, and supply the relay with 5V. I can't see if your board has a suppression diode for back EMF (inverse parallel across the relay coil), if not you should add one.
Posted: Mon Dec 05, 2016 6:04 pm
by joan
davidcoton wrote: ...
Potentially, yes.
However it is trivial to ensure that GPIO are switched as a group, e.g. http://abyz.co.uk/rpi/pigpio/python.html#set_bank_1
Posted: Mon Dec 05, 2016 6:27 pm
by Burngate
That electrokit.com relay board has on its signal input a 1k resistor to the transistor base (emitter to ground), a 1k resistor into a LED to ground, and a 10k resistor to ground.
My calculation says the current can't be more than 5mA - I can't see that overloading the GPIO.
What I do see is that the relay itself could take 20mA, through the VCC terminal.
Are you by any chance connecting both the CH1 and VCC terminals to the GPIO? Quite possibly the relay would click if you connected both to 3v3, but a GPIO couldn't handle that.
VCC should be connected to 5v
Posted: Mon Dec 05, 2016 10:57 pm
by davidcoton
Burngate wrote:That electrokit.com relay board has on its signal input a 1k resistor to the transistor base (emitter to ground), a 1k resistor into a LED to ground, and a 10k resistor to ground.
My calculation says the current can't be more than 2mA - I can't see that overloading the GPIO.
It's amazing what you can find out when you click on the schematic link! Burngate is correct, the drive circuit (and suppression diode) is onboard and should "just work", but Vcc needs to be connected to 5V (from the Pi or elsewhere).
