^CTraceback (most recent call last):
File "./sendSMS.py", line 96, in <module>
res = sendSMS(destinationNumber, "129", message)#domestic format numbers
File "/home/wvandiver/gsm/RPI_examples/a-gsm-RPI-examples-py-library-based-v1_ 2/agsm_SMS_Lib.py", line 36, in sendSMS
res = recUARTdata(">","ERROR",12)
File "/home/wvandiver/gsm/RPI_examples/a-gsm-RPI-examples-py-library-based-v1_ 2/agsm_Serial_Lib.py", line 88, in recUARTdata
dt = agsm.read(tm)
File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 447, in re ad
ready,_,_ = select.select([self.fd],[],[], self._timeout)
# select based implementation, proved to work on many systems
def read(self, size=1):
"""Read size bytes from the serial port. If a timeout is set it may
return less characters as requested. With no timeout it will block
until the requested number of bytes is read."""
if not self._isOpen: raise portNotOpenError
read = bytearray()
print "Loosing it at bytearray: ",read #read is an empty string
while len(read) < size:
# If select was used with a timeout, and the timeout occurs, it
# returns with empty lists -> thus abort read operation.
# For timeout == 0 (non-blocking operation) also abort when there
# is nothing to read.
if not ready:
break # timeout
buf = os.read(self.fd, size-len(read))
# read should always return some data as select reported it was
# ready to read when we get to this point.
if not buf:
# Disconnected devices, at least on Linux, show the
# behavior that they are always ready to read immediately
# but reading returns nothing.
raise SerialException('device reports readiness to read but returned no data (device disconnected?)')
read.extend(buf)
return bytes(read)
#a-gsm-send-SMS.py v1.01/13 June 2016 - a-gsm 2.064 send SMS utility / demo
#COPYRIGHT (c) 2016 Dragos Iosub / R&D Software Solutions srl
#You are legaly entitled to use this SOFTWARE ONLY IN CONJUNCTION WITH a-gsm DEVICES USAGE. Modifications, derivates and redistribution
#of this software must include unmodified this COPYRIGHT NOTICE. You can redistribute this SOFTWARE and/or modify it under the terms
#of this COPYRIGHT NOTICE. Any other usage may be permited only after written notice of Dragos Iosub / R&D Software Solutions srl.
#This SOFTWARE is distributed is provide "AS IS" in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied
#warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#Dragos Iosub, Bucharest 2016.
#http://itbrainpower.net
#HEALTH AND SAFETY WARNING!!!!!!!!!!!!!!!!!!!!
#High power audio (around 700mW RMS)! You can damage your years! Use it with care when headset is connected.
#We recomend to use AT+CLVL=20 (as maximum value), audio setup command in order to limit the output power.
# WARNING: WIRING the a-gsm-gsm board with u-controllers/boards(RPi) must be made with boards UNPOWERED!!
# LEGAL DISCLAIMER:
# Incorrect or faulty wiring and/or connection can damage your RPi and/or your a-gsm board!
# Following directives are provided "AS IS" in the hope that it will be useful, but WITHOUT ANY WARRANTY!
# Do the wiring on your own risk!
# References:
# http://itbrainpower.net/a-gsm/images/RaspberyPI_a-gsm_shield-wiring.png
# http://itbrainpower.net/a-gsm/downloadables/a-gsm_kickstart_v_0-90.pdf
# http://itbrainpower.net/a-gsm/gsm-shield-Arduino-RaspberryPI-features-code-examples.php
# http://itbrainpower.net/a-gsm/gsm-shield-Arduino-RaspberryPI-projects.php
# this utility must be runned as root (just use: sudo python yourPythonFileName.py)
message="Hi!\r\nThis message has been sent from the a-gsm v2.064 shield connected with my RPi board."
destinationNumber="1234567890" #usually phone number with International prefix eg. +40 for Romania - in some networks you must use domestic numbers
usePoweringControl = 1 #change it to 0 if you do not want to control powerUP/powerDown the a-gsm board. In this case, please be sure the a-gsm board is powered UP(..see a-gsm_kickstart_v_x-yz.pdf) before run this utility
#Do not change under following line! Insteed make one copy of the file and play with!
#Hint: if you make changes of the code, before you run it run clear utility (erase the Python compiled *.pyc files)...
###erase .pyc files by `find . -name '*.pyc' -delete`
import os
import serial
from time import sleep, time
from string import replace
from globalParVar import *
from agsm2_064_hw_control import *
from agsm_Serial_Lib import *
from agsm_Basic_Lib import *
from agsm_SMS_Lib import *
print "Light example - just send a SMS to a destination number"
sleep(1)
if not os.getuid() == 0:
print("please use root privileges! try: \"sudo python yourPythonFileName.py\"")
exit(0)
if destinationNumber=="":
print("No destination number has been set for your SMS!")
print("Edit the file and set the destinationNumber in line 35\r\n")
exit(0)
# set SERIAL/USB communication section start
# bellow chose value bw [SER] Serial /dev/ttyAMA0 or [USB] /dev/ttyUSB0
# if module USB port maps to other port as /dev/ttyUSB1, just edit the moduleName_Serial_lib.py...
serialCommunicationVia = SERIALCON # OVERRIDE the default value loaded from globalParVar.py. here I use via SERIAL communication
setSerialCom(serialCommunicationVia) # set the current communication option
startSerialCom() # open serial communication bw. RPi and a-gsm shield
# set SERIAL/USB communication section end
# set HARDWARE CONTROL setup & POWER ON section start
if usePoweringControl==1:
hwControlSetup() # setup the RPi I/O ports
sleep(2)#some delay...
poweron()
sleep(1)
# set HARDWARE CONTROL setup & POWER ON section end
# set MODEM STARTUP SETUP section start
setupMODEM()
# set MODEM STARTUP SETUP section end
# MAIN PROGRAM section start
print "try to send a SMS...."
#check AT command pdf for proper 129/145 parameter/number format usage
#res = sendSMS(destinationNumber, "145", message)#international format numbers
if res==0:
print "SMS has been sent with succes"
# MAIN PROGRAM section end
# stop SERIAL COMMUNICATION section start
stopSerialCom() # close modem communication
# stop SERIAL COMMUNICATION section end
# HARDWARE CONTROL release & POWER OFF section start
poweroff() #shutdown modem
hwControlRelease() # free GPIO
# HARDWARE CONTROL release & POWER OFF section end
print("\r\n\r\nThat's all folks!\r\n")
