Stephen_J
RPi won't boot after first shutdown
Sun Nov 27, 2016 7:57 am
Hello, I'm new to RPi and to the Forum. I just got my first RPi3. I am a linux admin at work so cli is nothing new to me. I put the Raspbian Image on an mSD card with Etch. The Pi booted fine. I played around with it and did a shutdown -h now. When I removed power and plugged it back in, no signal was ever sent to the monitor and the green LED flashes long sequences. I counted some with results being 23, 13 , 45 and 48 flashes with 1 second breaks and no established a pattern. Google searches netted me mentions of flash codes of less than 10. I read the boot problems sticky and nothing sounds like my issue. I have a vga monitor connected via an hdmi to vga adapter. Unplugging it and plugging it back in didn't help.
I burned Raspbian Lite to a second microSD card and got the same results. There seems to be no issues with the first boot of the image but any attempt to boot again doesn't seem to start. Reboot commands are successful. Reflashing the image to the SD card gets it going again.
Thank you in advance.
Stephen
pws
Re: RPi won't boot after first shutdown
Sun Nov 27, 2016 2:54 pm
Sounds like you are not waiting long enough after you issue the "shutdown" command to remove power/sd card. Wait until activity light completely stops blinking.
fred44nl
Sun Nov 27, 2016 3:19 pm
are you by any chance using a usb-hdd without it's own power-supply ??
that's what I tried and that did nog go very well.
headless RPi 3B running from usbhdd.
Stephen_J
Sun Nov 27, 2016 5:00 pm
Thanks for the ideas. I am using brand new samsung SD cards not hdd. I have ensured that I waited for the 10 "shutdown" flashes per the instructions on the troubleshooting thread and made sure the ACT light was off for a period. Here is what else I have found. It appears to be some kind of disk corruption. When I take the SD card and put it back in the Windows machine that imaged it, Windows says it is corrupt. If I reimage it, the Pi boots fine on the refreshed image.
Stephen
HawaiianPi
Sun Nov 27, 2016 6:21 pm
I wouldn't worry about Windows saying something is corrupt. It says that whenever you connect a drive that wasn't formatted in Windows. I get that all the time with flash drives I format in Linux, and when I let Windows "scan and repair" the drive it always says no errors were found. That's just Windows being stupid.
As for your issue, that is odd. The first thing I would suspect is your HDMI>VGA adapter, because I have found those to be troublesome in the past.
Are you sure the Pi is not booting? Have you tried to SSH into it when you're getting no video?
Try adding hdmi_force_hotplug=1 to your config.txt file, and maybe config_hdmi_boost=7 as well.
Stephen_J
Mon Nov 28, 2016 12:59 am
HawaiianPi wrote:I wouldn't worry about Windows saying something is corrupt. It says that whenever you connect a drive that wasn't formatted in Windows. I get that all the time with flash drives I format in Linux, and when I let Windows "scan and repair" the drive it always says no errors were found. That's just Windows being stupid.
So, I did all three of these things and now it works. I haven't gone back and undone them one at a time to see which one it was. If I have a minute, I'll figure out which one and then post back here for the next guy.
Thanks HawaiianPi
Stephen
LakyStrajk
Wed May 23, 2018 3:44 pm
Hi. I had the same problem as Stephen_J. It was because I am using old monitor (VGA to HDMI converter). Adding hdmi_force_hotplug=1 and config_hdmi_boost=7 to my config.txt solved the issue. Thank you guys! ;)
Wed May 23, 2018 7:53 pm
The first thing to try to get over the "won't boot after shutdown" bug is sudo rpi-update; sudo poweroff pull power and reboot. That gets the 4.14.42-v7+ kernel with new bootcode that solves that boot problem. It's been out for a couple of days and is running on 13 out of 15 of my raspberries.
LakyStrajk
Sun May 27, 2018 3:05 pm
thank you, firmware updated ;)
Cardship
Sun Dec 02, 2018 2:25 am
Short pins 5&6 after a shutdown to boot.
