TheDarkMonster62
How to vnc into berryboot
Fri Nov 25, 2016 9:52 pm
Hi ,
I would like to use my rpi3 as a headless device by ssh in the rpi , i have installed berryboot .
When berryboot menu starts i can't ssh in or vnc in , how can i select what system i wanna boot to without an external screen ?
Thank you .
Last edited by TheDarkMonster62 on Sat Nov 26, 2016 11:41 am, edited 1 time in total.
Re: BerryBoot problem
Fri Nov 25, 2016 10:44 pm
TheDarkMonster62 wrote:Hi ,
Thank you .
http://www.berryterminal.com/doku.php/b ... stallation
TheDarkMonster62
Sat Nov 26, 2016 9:42 am
Thank you .
I tried this already but i can't vnc when berry boot menu is showing .
In my cmdline.text there is that :
elevator=deadline quiet bootmenutimeout=25 datadev=mmcblk0p2 qmap=fr vncinstall ipv4=192.168.1.17/255.255.255.0/192.168.1.1 vncinstall ipv4=192.168.1.17/255.255.255.0/192.168.1.1/wlan0
I put 2x times the vncinstall command in case i wanna use my rpi in wifi .
In my etc/dhcp.conf i put this :
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
nohook lookup-hostname
interface eth0
static ip_address=192.168.0.17/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
interface wlan0
I dont know what i did wrong and when i plug off my raspberry then plug in , i try to vnc connect , it says unencrypted connection with a black screen then the vnc client says connection lost .
Then when i try again to vnc , it says connection refused so i go in Putty to connect in ssh and guess what raspbian is already started .
I would like to be able to modify Os and all others things in the berryboot menu , headless .
Sorry for my bad english :roll:
