keithellis
wifi not working after apt-get upgrade
Thu Nov 17, 2016 10:45 pm
I have done this three times now and get the same issue every time.
Download and flash the latest Raspbian Jessie lite - September 2016
Plug SD card into a Pi2, connect to ethernet and boot up
edit /etc/wpa_supplicant/wpa_supplicant.conf
add the following
network={
    ssid="myssid1"
    psk="mywifipasscode"
network={
    ssid="myssid2"
Disconnect lan cable, reboot and ssh in via wifi connection. All is working fine.
sudo apt-get update
sudo apt-get install python3 python3-dev python3-pip git
pip2 install thingspeak
#Download and compile ffmpeg
reboot, all is still working
sudo apt-get upgrade
reboot, wifi is no longer working
kellis@raspberrypi:~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:a3:c6:3f
          inet addr:192.168.54.132  Bcast:192.168.54.255  Mask:255.255.255.0
          inet6 addr: fe80::e0f7:8e2:6ab3:308a/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:382 errors:0 dropped:30 overruns:0 frame:0
          TX packets:167 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:87572 (85.5 KiB)  TX bytes:20817 (20.3 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  HWaddr 00:0b:81:9b:8c:30
          inet6 addr: fe80::ba1a:4410:4526:9e3d/64 Scope:Link
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
kellis@raspberrypi:~ $ lsusb
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
kellis@raspberrypi:~ $ iwconfig
wlan0     unassociated  Nickname:"<WIFI@REALTEK>"
          Mode:Auto  Frequency=2.412 GHz  Access Point: Not-Associated
          Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Power Management:off
          Link Quality:0  Signal level:0  Noise level:0
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
lo        no wireless extensions.
eth0      no wireless extensions.
kellis@raspberrypi:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
#allow-hotplug wlan1
#iface wlan1 inet manual
#    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
kellis@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
country=GB
update_config=1
network={
	ssid="myssid1"
	psk="mypsk1"
#network={
#	ssid="myssid2"
#	psk="mypsk2"
How do I get wifi working again?
Regards,
Keith
wh7qq
Re: wifi not working after apt-get upgrade
Fri Nov 18, 2016 3:13 am
network={
ssid="myssid1"
psk="mypsk1"
Is this how your file actually looks or are you using "myssid1" and "mypsk1" as dummy valules just for security here on the forum?
You must change these values to match your actual network and the values to put in are to be found in the config pages of your router's web interface.
keithellis
Sun Nov 20, 2016 3:26 pm
wh7qq wrote: Is this how your file actually looks or are you using "myssid1" and "mypsk1" as dummy valules just for security here on the forum?
I have the correct settings in here, I changed then just for the forum. Anyway, how do you know these are not my settings ;-)
The settings work before the 'apt-get upgrade' and without changing anything after the upgrade it stops working :-(
wh7qq
Tue Nov 22, 2016 7:22 pm
keithellis wrote: I have the correct settings in here, I changed then just for the forum. Anyway, how do you know these are not my settings ;-)
I don't know...I was asking you. I just know they won't work and they were what you posted. Go to the sticky thread on this forum on wifi problems.
Martin Frezman
Tue Nov 22, 2016 7:29 pm
wh7qq wrote: I don't know...I was asking you. I just know they won't work and they were what you posted.
You don't know that at all.
As he mentioned, those could be his correct values.
If this post appears in the wrong forums category, my apologies.
jbudd
Tue Nov 22, 2016 7:47 pm
I've seen a few reports of wifi problems after apt-get upgrade, but my Pi has never had this trouble.
You said that you unplugged the ethernet cable, but your code
shows an IP address on eth0
I wonder if this is relevant - if the Pi thinks it has ethernet, I am not sure if it will enable wifi.
If you start again with a fresh installation, I suggest trying
sudo apt-get update && sudo apt-get upgrade
as the first step before setting up wifi and installing packages
wh7qq
Wed Nov 23, 2016 8:23 pm
Not very likely but I suppose some actually do use "password" :o
HawaiianPi
Wed Nov 23, 2016 8:44 pm
keithellis wrote:...
Did you update the package list (sudo apt-get update) before the upgrade?
Martin Frezman
Wed Nov 23, 2016 10:17 pm
Not very likely but I suppose some actually do use "password".
I think studies have shown that it is far and away the most common password in use.
HawaiianPi
Wed Nov 23, 2016 10:36 pm
wh7qq wrote:Not very likely but I suppose some actually do use "password" :o
Martin Frezman wrote:I think studies have shown that it is far and away the most common password in use.
I thought it was 1234...
That reminds me of a funny story from the way back when days of early home computers (Apple, Atari, Commodore). I had a friend who used to go on about how he was going to learn all about computers and become the world's greatest hacker. He was also working on a game program on his Commodore 64 at the time, so I made a few changes to his code, and he was greeted by the prompt "Enter password" when he tried to run it.
I also took advantage of a particular quirk of the Commodore system to prevent him from listing his code and removing my alterations.
At first he was upset, but I taunted him about his elite hacking skills and challenged him to defeat what I had done. He spent days trying to figure out what I would have used as a password, names, birthdays, and lots of other personal references, forwards, backwards, etc. Finally he gave up, admitted defeat and asked me for the password.
Well I sighed, shook my head in disappointment and said, "Dude, you won't make a very good hacker if you can't even follow simple directions."
He asked, "What do you mean by that?"
And I asked him, "What does it say on your screen right now?"
Enter passw... [ARGHH!!] :oops: :P :evil:
davidcoton
Wed Nov 23, 2016 11:01 pm
HawaiianPi
Thu Nov 24, 2016 3:58 am
davidcoton wrote:See also the password is secret
LOL! That's awesome. The I.T. department was obviously messing with customer service when they chose that for a password.
FalconFour
Sun Feb 09, 2020 10:15 am
All this damn bantering about whether the guy masked his real SSID and password in his forum-paste, and nobody has actually contributed anything useful. What's this, a full page of back and forth off-topic banter about "he-he ha-ha u didnt use "password" did you hehe ahaha" and I had to sit here reading it while suffering with the EXACT problem OP is mentioning -- the "ESSID:off/any" with a clean install and doing an "apt-get update"/"upgrade" cycle (that took about an hour).
Now 4 years later without a helpful conclusion and the problem still at play, does anyone have anything to offer?
Linux WiFi is so incredibly obtuse and opaque, I can't even understand how to diagnose it. Why would I want a utility called "rfkill" on my system by default? At least it says "unblocked" for Soft and Hard...
FalconFour
Sun Feb 09, 2020 10:43 am
I bashed my head repeatedly into the Google and found the problem.
The firmware bundle "realtek-firmware" was updated by the apt-get process. The firmware for my dongle (rtl8192cu) was updated as a result. Seems that for some reason, apt is picking up an unofficial firmware bundle out of sync with the main Debian tree. The version I picked up was "firmware-realtek:armhf (1:20190114-1+rpt2, 1:20190114-1+rpt4)", but the latest version in the Debian tree is 20161130.
I downloaded that .deb, stuck it on a USB drive, and ran a "dpkg -i firmw~1.deb" on it. It "downgraded" firmware-realtek to that Debian version.
I rebooted, and WiFi was back.
Grab it here: https://packages.debian.org/stretch/all ... k/download
And yes, I did necro-bump this thread, because it comes up in Googling, and the thread was without resolve. Now future help-seekers can find an answer. There is no reason to hate on necro-bumping, so don't do it. Thanks for not doing auto-locks. <3
Sun Feb 09, 2020 11:23 am
There is every reason to hate on necrobumping, because in the vast majority of cars, it's a waste of time.
Closing, apparently solved.
