mount 2 RPI not working anymore(Solved?)
Posted: Thu Nov 17, 2016 10:34 am
I'll try to mount to RPI's
one direction is working.
The other way not. Both RPI are the same way configured for mounting (Except the IP adresses offcourse)
It worked in the past.
But now one is not mounting.
I checked the rpcbind. It started and its running on both machines.:
ewh@raspberrypi-1 ~ $ df -h
Bestandssysteem Grootte Gebruikt Besch Geb% Aangekoppeld op
/dev/root 14G 3,7G 9,2G 29% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 0 463M 0% /dev/shm
tmpfs 463M 6,8M 457M 2% /run
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p5 60M 20M 40M 33% /boot
//192.168.2.100/NetwerkSchijf/Edward/BackupRasp 1,8T 1,5T 304G 84% /mnt/NAS
tmpfs 93M 0 93M 0% /run/user/106
tmpfs 93M 0 93M 0% /run/user/1001
The line in fstab is:
nmap -sn 192.168.2.202 gives:
I do see a difference at the mount directory between both RPI's. At the one the owner is ewh at the other root root:
If I try sudo mount -a.
I have to use CTR C to stop the command and mount is not happening.
Where can I find mount error login?
The strange part is that it worked fine in the past?
What could be wrong?
ewh@raspberrypi-1 ~ $ sudo systemctl status rpcbind
● rpcbind.service - LSB: RPC portmapper replacement
Loaded: loaded (/etc/init.d/rpcbind)
Drop-In: /run/systemd/generator/rpcbind.service.d
└─50-rpcbind-$portmap.conf
Active: active (running) since wo 2016-11-16 21:08:26 CET; 10min ago
Process: 410 ExecStart=/etc/init.d/rpcbind start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/rpcbind.service
└─434 /sbin/rpcbind -w
nov 16 21:08:26 raspberrypi-1 systemd[1]: Starting LSB: RPC portmapper replacement...
nov 16 21:08:26 raspberrypi-1 rpcbind[410]: Starting rpcbind daemon....
nov 16 21:08:26 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
nov 16 21:08:29 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
nov 16 21:11:04 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
ewh@raspberrypi-3:~ $ sudo systemctl status rpcbind
Active: active (running) since wo 2016-11-16 21:17:32 CET; 1min 42s ago
Process: 1746 ExecStart=/etc/init.d/rpcbind start (code=exited, status=0/SUCCESS)
└─1756 /sbin/rpcbind -w
nov 16 21:17:32 raspberrypi-3 rpcbind[1746]: Starting rpcbind daemon....
nov 16 21:17:32 raspberrypi-3 systemd[1]: Started LSB: RPC portmapper replacement.
raspberrypi-3 is mounting. correct.
raspberrypi-1 not:
ewh@raspberrypi-3:~ $ df -h
/dev/root 14G 4,0G 8,7G 32% /
tmpfs 463M 6,6M 457M 2% /run
/dev/mmcblk0p6 66M 21M 46M 31% /boot
192.168.2.185:/home/ewh 14G 3,7G 9,2G 29% /mnt/PI
tmpfs 93M 0 93M 0% /run/user/1000
/dev/mmcblk0p5 30M 445K 28M 2% /media/ewh/SETTINGS
192.168.2.202:/home/ewh /mnt/PI nfs rw 0 0Code: Select all
Starting Nmap 6.47 ( http://nmap.org ) at 2016-11-16 22:03 CET
Nmap scan report for 192.168.2.202
Host is up (0.011s latency).
Nmap done: 1 IP address (1 host up) scanned in 0.06 seconds
drwxrwxrwx 2 root root 4096 apr 1 2015 PI
ewh@raspberrypi-1:/mnt $
drwxrwxrwx 5 ewh 1004 4096 okt 22 16:57 PI
ewh@raspberrypi-3:/mnt $
