MacFizz
How does a RPi dies
Tue Nov 15, 2016 10:30 pm
Hello there
It seems my good old RPi B has died.
I didn't know it was even possible without doing anything too exotic.
I was running openelec on it.
Now, when I plug the power, the power led goes on, the ACT (green) is very, very dimly lit and nothing else.
I changed the power supply, cable, SD card with new img freshly loaded (tried openelec, raspian and osmc) and nothing.
Any clues ?
thx
Re: How does a RPi dies
Tue Nov 15, 2016 11:27 pm
Dim green LED on the old Pi B means that it has failed to read anything from the SD card.
Check the connections in the SD card socket. Sometimes they have problems making contact.
MacFizz
Wed Nov 16, 2016 8:34 am
Yes, that's what I'm thinking, but I cleaned the contacts, tried different SD cards.
Would there be any possibilities to boot of an usb card reader ?
thx
RaTTuS
Contact: Twitter YouTube
Wed Nov 16, 2016 8:39 am
if this is an old model B with full sized sdcard the see if the socket is warped.
Covfefe
MacFizz
Wed Nov 16, 2016 9:31 am
Yep, it's an B model with full size SD.
I changed the SD card thinking it might have bended a little because of the contact springs and heat.
I'll check the sdcard reader's soldering.
If the rpi can't boot from usb, I doubt the integrated sdcard reader is fixable...
RaTTuS
Wed Nov 16, 2016 9:38 am
only model 3 can boot from usb
Covfefe
FTrevorGowen
Wed Nov 16, 2016 1:25 pm
RaTTuS wrote:if this is an old model B with full sized sdcard the see if the socket is warped.
Or the early signs of this type of failure:
http://www.cpmspectrepi.uk/raspberry_pi ... ilure.html
Trev.
MacFizz
Thu Nov 17, 2016 11:15 am
Trev.
I checked the sdcard socket and everything looks fine.
I resoldered the sdcard contact on the PCB just in case but nothing new.
However, something really odd:
After letting it rest overnight without any card inserted, it worked. I shut it down and then, the problem reappeared.
Could it be capacitor related somehow, taking some time to cooldown or something ?
FTrevorGowen
Thu Nov 17, 2016 12:09 pm
MacFizz wrote: ...
More likely a polyfuse** issue (partial tripping for some reason). What's the voltage on the "5V" supply rail and what are you powering it with? (One possible cause of "partial trips" could be a "spikey" PSU).
Trev.
** How many polyfuses does it have? - (early) B1's had three (two extra, 140mA ones on the USB ports), B2's onewards, just the one.
