Canedje
mounting problem 2 RPI's (again)
Fri Nov 11, 2016 9:13 pm
I do try to mount two RPI's to each other using the commandline in /etc/fstab:
192.168.2.202:/home/ewh /mnt/PI nfs rw 0 0
This worked fine in the past.
But suddenly one of the RPI's is not mounting any more. (The other one still mounting well)
I tried restart both RPI's in different order several times but one RPI (the same) is not mounting.
Very sometimes it is mounting again.
I tried the command "sudo mount -a". This results that It is hanging and I do need to stop the mount command by Ctrl C
What could be the problem?
Is there a file somewhere I can read to find the mount error?
Canedje
Re: mounting problem 2 RPI's
Sat Nov 12, 2016 9:28 am
I changed the /etc/eports file from:
/home/ewh 192.168.2.185(rw) 192.168.2.186(rw) 192.168.2.200(rw) 192.168.2.201(rw)
to
#192.168.2.186(rw) 192.168.2.200(rw) 192.168.2.201(rw)
Now it works fine.
Strange. It worked before with multiple IP's in one line.
Is it not allowed to put more IP's behind each other, because I do have in the other RPI and that is working fine?
EDIT:
After restart again not running.
After changing /etc/eports some how and put IP's in line again, and saving. Its running??
Sat Nov 12, 2016 9:53 am
Is rpcbind running on the client machine?
Canedje
Sat Nov 12, 2016 10:10 am
I didn't do that myself.
How to test or to get it running?
Sat Nov 12, 2016 10:38 am
sudo systemctl start rpcbind
sudo systemctl status rpcbind
Canedje
Sat Nov 12, 2016 10:42 am
Thanks.
In my new raspberry pi3b the command is running
at my old RPI 3 the systemctl command is unknown.
Is this a new jessie command?
Sat Nov 12, 2016 10:49 am
On Whezzy use sudo /etc/init.d/rpcbind start and sudo /etc/init.d/rpcbind status.
You really need to think about getting rid of Wheezy, it's no longer maintained, you probably don't have the Dirty COW kernel fix on that one.
Canedje
Sat Nov 12, 2016 10:58 am
Thanks again.
Is there a method to convert? Or do you realy need to start from scratch again?
Because it is running a lot of daily used programming for controlling my heating for example
Sat Nov 12, 2016 11:27 am
Starting with a fresh copy of Jessie and lifting things from your old Wheezy card is going to be easiest. You'll need a USB SDCard reader to bea able to mount the old Wheezy SDCard.
Canedje
Sat Nov 12, 2016 2:30 pm
I did a upgrade mentioned here:
https://www.raspberrypi.org/magpi/fix-d ... pberry-pi/
Ik took some hours and apache didn't start first.
But now I'm up and running again.
Thanks again for the advise
Canedje
Wed Nov 16, 2016 8:22 pm
I thought I tackled the problem.
But still the old raspberry is not binding the CIFs. (It did for a while!)
I checked the rpcbind. It was not started after reboot. I started it and now its running on both machines.:
ewh@raspberrypi-1 ~ $ sudo systemctl status rpcbind
● rpcbind.service - LSB: RPC portmapper replacement
   Loaded: loaded (/etc/init.d/rpcbind)
  Drop-In: /run/systemd/generator/rpcbind.service.d
           └─50-rpcbind-$portmap.conf
   Active: active (running) since wo 2016-11-16 21:08:26 CET; 10min ago
  Process: 410 ExecStart=/etc/init.d/rpcbind start (code=exited, status=0/SUCCESS)
   CGroup: /system.slice/rpcbind.service
           └─434 /sbin/rpcbind -w
nov 16 21:08:26 raspberrypi-1 systemd[1]: Starting LSB: RPC portmapper replacement...
nov 16 21:08:26 raspberrypi-1 rpcbind[410]: Starting rpcbind daemon....
nov 16 21:08:26 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
nov 16 21:08:29 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
nov 16 21:11:04 raspberrypi-1 systemd[1]: Started LSB: RPC portmapper replacement.
ewh@raspberrypi-3:~ $ sudo systemctl status rpcbind
   Active: active (running) since wo 2016-11-16 21:17:32 CET; 1min 42s ago
  Process: 1746 ExecStart=/etc/init.d/rpcbind start (code=exited, status=0/SUCCESS)
           └─1756 /sbin/rpcbind -w
nov 16 21:17:32 raspberrypi-3 rpcbind[1746]: Starting rpcbind daemon....
nov 16 21:17:32 raspberrypi-3 systemd[1]: Started LSB: RPC portmapper replacement.
raspberrypi-3 is mounting. correct.
raspberrypi-1 not:
ewh@raspberrypi-3:~ $ df -h
Bestandssysteem                                 Grootte Gebruikt Besch Geb% Aangekoppeld op
/dev/root                                           14G     4,0G  8,7G  32% /
devtmpfs                                           459M        0  459M   0% /dev
tmpfs                                              463M        0  463M   0% /dev/shm
tmpfs                                              463M     6,6M  457M   2% /run
tmpfs                                              5,0M     4,0K  5,0M   1% /run/lock
tmpfs                                              463M        0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p6                                      66M      21M   46M  31% /boot
192.168.2.185:/home/ewh                             14G     3,7G  9,2G  29% /mnt/PI
//192.168.2.100/NetwerkSchijf/Edward/BackupRasp    1,8T     1,5T  304G  84% /mnt/NAS
tmpfs                                               93M        0   93M   0% /run/user/1001
tmpfs                                               93M        0   93M   0% /run/user/1000
/dev/mmcblk0p5                                      30M     445K   28M   2% /media/ewh/SETTINGS
ewh@raspberrypi-1 ~ $ df -h
/dev/root                                           14G     3,7G  9,2G  29% /
tmpfs                                              463M     6,8M  457M   2% /run
/dev/mmcblk0p5                                      60M      20M   40M  33% /boot
tmpfs                                               93M        0   93M   0% /run/user/106
the command in /etc/fstab: 192.168.2.202:/home/ewh /mnt/PI nfs rw 0 0 is not executed and the system is waiting here.
because if I swop this command in /etc/fstab before: //192.168.2.100/NetwerkSchijf/Edward/BackupRasp /mnt/NAS cifs defaults,rw,username=admin,password=xxxxx,domain=workgroup 0 0.
This line is also not executed. So the /etc/fstab file will never be finished executing.
nmap -sn 192.168.2.202 gives:
Starting Nmap 6.47 ( http://nmap.org ) at 2016-11-16 22:03 CET
Nmap scan report for 192.168.2.202
Host is up (0.011s latency).
Nmap done: 1 IP address (1 host up) scanned in 0.06 seconds
I do see a difference at the mount directory between both RPI's. At the one the owner is ewh at the other root root:
drwxrwxrwx 2 root root  4096 apr  1  2015 PI
ewh@raspberrypi-1:/mnt $
drwxrwxrwx 5 ewh   1004 4096 okt 22 16:57 PI
ewh@raspberrypi-3:/mnt $
What could be wrong?
