How do I set wlan0 to internet and eth0 to local network?
Posted: Tue Nov 01, 2016 1:02 am
I have two Pi's that are connected together through a switch as part of a local intranet where each Pi is assigned a static IP for their eth0 interface.
But in order to still be able to update packages, i wanted to set up each Pi's wlan0 interface so that it connects to my home Wifi and can have access to the internet.
I modified /etc/dhcpcd.conf for both as follows:
Then I modified /etc/wpa_supplicant/wpa_supplicant.conf for both to include the SSID and PW for my home Wifi. Everything seems to be connected because when I 'ifconfig', I get:
But when I actually try to apt-get or ping anything on the internet, there doesn't seem to be an actual connection. Am I missing something here? Can I actually separate wlan0 and eth0 onto two separate networks or do they get bridged automatically?
#set static ip for eth0
interface eth0
static ip_address=192.168.50.101/24
static routers=192.168.50.1
static domain_name_servers=192.168.50.1
eth0
inet addr:192.168.50.101 Bcast:192.168.50.255 Mask:255.255.255.0
inet6 addr: fe80::6834:a300:6140:934f/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:4592 errors:0 dropped:1305 overruns:0 frame:0
TX packets:3787 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:292917 (286.0 KiB) TX bytes:617701 (603.2 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:504 errors:0 dropped:0 overruns:0 frame:0
TX packets:504 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:46488 (45.3 KiB) TX bytes:46488 (45.3 KiB)
wlan0 Link encap:Ethernet
inet addr:10.118.7.80 Bcast:10.118.7.255 Mask:255.255.254.0
inet6 addr: fe80::8481:9cd6:a20b:6daa/64 Scope:Link
RX packets:3123 errors:0 dropped:3080 overruns:0 frame:0
TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:693307 (677.0 KiB) TX bytes:7304 (7.1 KiB)
