Canedje
Installing new RPI 3B problems
Thu Oct 27, 2016 3:16 pm
I just bought an extra RPI 3 B and trying to initiate it.
I try to fix the ip adresses for wifi and eth using the same code as used in an older RPI 3 in /etc/network/interfaces.
It lookes like:
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.2.187
netmask 255.255.255.0
network 192.168.2.0
broadcast 192.168.2.255
gateway 192.168.2.1
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.2.202
network 192.168.2.0
gateway 192.168.2.1
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
For the Wlan there is now a fixed ip adress.
For the eth0 not (still using a dhcp adress).
ifconfig shows:
eth0      Link encap:Ethernet  HWaddr b8:27:eb:65:18:18
          inet addr:192.168.2.173  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::c1d5:9b74:7bfc:415c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:12994 errors:0 dropped:350 overruns:0 frame:0
          TX packets:800 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:841885 (822.1 KiB)  TX bytes:155533 (151.8 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:140 errors:0 dropped:0 overruns:0 frame:0
          TX packets:140 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:11888 (11.6 KiB)  TX bytes:11888 (11.6 KiB)
wlan0     Link encap:Ethernet  HWaddr b8:27:eb:30:4d:4d
          inet addr:192.168.2.202  Bcast:192.168.2.255  Mask:255.255.255.0
          inet6 addr: fe80::b76b:fcf0:278a:679d/64 Scope:Link
          RX packets:14875 errors:0 dropped:4174 overruns:0 frame:0
          TX packets:619 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1493745 (1.4 MiB)  TX bytes:78356 (76.5 KiB)
What am I doing wrong?
Beside this I did add a new user.
Every time I use the sudo command the first time after login it ask the sudo password. Like:
[sudo] password for ewh:
How can i fix not to type everytime the sudo passwd once?
Thanks inadvance
epoch1970
Re: Installing new RPI 3B problems
Thu Oct 27, 2016 3:58 pm
In Raspbian Jessie, dhcpcd is responsible for handling interfaces configuration, and /etc/network/interfaces is less useful.
(If you don't like that, as I do, I think you can remove the dhcpcd package. I am not advocating for that, but it is a possibility.)
If you have an extra user and give it super-user powers without at least verifying once the user identity, you just could as well login as root and leave the console open...
But I have to admit I have this in my sudo file:
www-data	ALL=NOPASSWD: /usr/sbin/hostapd_cli
And if you really wanted to give root power to your user you could do this (note the %sudo line is above the user line):
# Allow members of group sudo to execute any command
%sudo	ALL=(ALL:ALL) ALL
# Allow user badidea to run any command as root without entering a password even if it belongs to the sudo group
badidea	ALL=NOPASSWD: ALL
Canedje
Thu Oct 27, 2016 4:06 pm
Epoch, thanks. The passwd problem is solved.
I don't understand how to use fixed adresses bij dhcpcd? Or how to remove it?
In my old RPI i used /etc/network/interfaces working fine?
drgeoff
Thu Oct 27, 2016 4:41 pm
Canedje wrote:Epoch, thanks. The passwd problem is solved.
There are many posts with the details of putting static IPs in dhcpcd.conf for Raspbian Jessie. Which ones have you read and not understood?
Quis custodiet ipsos custodes?
Canedje
Thu Oct 27, 2016 5:23 pm
I did read several posts around this subject and they are quit confusing.
I do have it working now but I do think it orchanized in the wrong way.
I did use both systems :
/etc/network/interfaces. I configures this file like:
auto lo
network 192.168.2.0
gateway 192.168.2.1
allow-hotplug wlan0
network 192.168.2.0
gateway 192.168.2.1
and the file : /etc/dhcpcd.conf like this (At the end of the file):
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface wlan0
static ip_address=192.168.2.202/24
static routers=192.168.2.1
static domain_name_servers=192.168.2.1 8.8.8.8
interface eth0
static ip_address=192.168.2.187/24
Is this the right way to achieve eth0: 192.168.2.187 static adres
and Wlan0: 192.168.2.202 static adres?
EDIT: Strange part is that my router says that both adresses are dhcp and not static??
