Binson
Keyboard remapping broken on X-windows ?
Mon Sep 03, 2012 4:56 am
Hi All !
As i was preparing for may first attempt at compiling anything ever * i remarked that my a's came out as q's . After some searching on this forum i hit on a subject** and posted this :
Quote/
Am having the same problem as Johann : Belgian keymap (azerty iso qwerty, etc) is used in the console, but as soon as i use X lxde the mapping reverts to qwerty . This is on a fresh install of the official raspbian, with latest updates of firmware, software et al .
I also installed an sd card with pisces MATE R2, did all the updates and upgrades, and Bingo! Qwerty in the GUI . In MATE one can set the keymap in the preferences, but this shows the be(lgian) map duly set .
I can't recall having this problem when i first installed the official raspbian image, few hours after it came out, so it's got to be one of the upgrades to the x innards thats the culprit, hence this mayday call .
end quote/
I have rewritten the MATE sd-card with an original raspbian image and can confirm remapping works correctly in an un-upgraded X-lxde session on my machine . I can keep this image for now to run some upgrade tests, but don't know where to start . The fully upgraded wheezy armel image that i also have does not exhibit this flaw btw .
Thanks for reading .
Binson
* want to compile Synergy 1.4.10 on PI to be able to use it as server with my Macbook as client, but thats andother story
**http://www.raspberrypi.org/phpBB3/viewt ... 42#p163542
thsBavR10
Re: Keyboard remapping broken on X-windows ?
Mon Sep 03, 2012 3:49 pm
I have the same problem,
(keyboard mapping is in gnome different to bash, qerty istead of qwertz (german)),
and i can't find an option in gnome to change the remapping. there is no option in settings.
Has anybody made an custom xorg.conf or an other solution?
Thanks!
thsBavR10
Mon Sep 03, 2012 4:30 pm
I've found an workaround:
inserting the line
setxkbmap -option grp:ctrl_shift_toggle,grp_led:scroll  de,de
in the file /etc/X11/xinit/xinitrc
(before calling . /etc/X11/Xsession) helps.
You have only to insert the mapping at the end of the line.
Binson
Tue Sep 04, 2012 1:56 am
Hi All !
Thanks thsBavR10 for putting me on the right track .
The file you mentioned did not have any entries so i just added in
setxkbmap be
and it worked !!!
Forcing it in this way does not explain what, or how, it got broken in the first place though .
Hmmm ...
Bye for now .
Binson
thsBavR10
Tue Sep 04, 2012 10:22 am
I am pleased that it has helped.
But this is, as you wrote, only a workaround, not a final solution.
Something has broken between the individual changes at the console to locale and keyboard-mapping and so on,
and the X11 / LXDE.
Don't know, where to adress this error (maybe in the rasbian board).
Sleep Mode zZ
Tue Sep 04, 2012 10:33 am
I can confirm this problem. I'm not sure when I last time typed something in X, I noticed this only now.
brutus
Fri Nov 30, 2012 9:32 am
Same problem for me, mz swiss kezboard work fine under the standard bash but switch to Uk or US kezboard as soon as I run LXDE, as zou can see :)
brutus
Fri Nov 30, 2012 12:37 pm
thsBavR10 wrote:I've found an workaround:
Thanks, it work for me except that I used the Swiss - French keyboard
setxkbmap -option 'grp:ctrl_shift_toggle,grp_led:scroll' 'ch(fr)'
ausinch
Fri Dec 21, 2012 11:50 pm
My problem is my Swiss German does work right from the start.
BUT the Alt Gr button will not work - so I cant get a backslash or AT symbol.
I have run "sudo raspi-config" and set the k/b again (configure_keyboard) but to no avail
thsBavR10
Sat Dec 22, 2012 11:25 am
AltGr is working for me, both on commandline and in X11.
What does your /etc/default/keyboard contain regarding XKBMODEL ?
XKBMODEL="pc105"
I also have this file:
cat /etc/X11/xorg.conf.test :
# only sectionInputDevice for testing
Section "InputDevice"
	Identifier	"Generic Keyboard"
	Driver	"kbd"
	Option	"XkbRules"	"xorg"
	Option	"XkbModel"	"pc105"
	Option	"Xkblayout"	"de"
EndSection
ausinch
Mon Dec 24, 2012 11:05 am
My Alt Gr key works now.
I didnt do anything to get it going it just started working. I did change the power supply on the pi to a hub and connected the wireless USB transmitter to the hub, it could have been a power issue.
Here's my config file anyway:
cat /etc/default/keyboard
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="logicda"
XKBLAYOUT="ch"
XKBVARIANT=""
XKBOPTIONS="lv3:ralt_switch,terminate:ctrl_alt_bksp"
BACKSPACE="guess"
