[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.22-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #912 SMP Mon Sep 26 19:04:59 BST 2016
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x3a800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 808c2f40, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9520->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @b9f62000 s22592 r8192 d22464 u53248
[ 0.000000] pcpu-alloc: s22592 r8192 d22464 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa21041 bcm2709.serial=0xcc4ca211 smsc95xx.macaddr=b8:27:eb:4c:BC:79 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.speed=1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 939072K/966656K available (6348K kernel code, 432K rwdata, 1716K rodata, 476K init, 764K bss, 19392K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x807e8550 (8066 kB)
.init : 0x807e9000 - 0x80860000 ( 476 kB)
.data : 0x80860000 - 0x808cc250 ( 433 kB)
.bss : 0x808cf000 - 0x8098e1ec ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000011] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000032] Switching to timer-based delay loop, resolution 52ns
[ 0.000347] Console: colour dummy device 80x30
[ 0.001530] console [tty1] enabled
[ 0.001584] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.001661] pid_max: default: 32768 minimum: 301
[ 0.002072] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002125] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.003347] Disabling cpuset control group subsystem
[ 0.003426] Initializing cgroup subsys io
[ 0.003489] Initializing cgroup subsys memory
[ 0.003574] Initializing cgroup subsys devices
[ 0.003625] Initializing cgroup subsys freezer
[ 0.003675] Initializing cgroup subsys net_cls
[ 0.003770] CPU: Testing write buffer coherency: ok
[ 0.003884] ftrace: allocating 21222 entries in 63 pages
[ 0.056311] CPU0: update cpu_capacity 1024
[ 0.056391] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.056431] [bcm2709_smp_prepare_cpus] enter
[ 0.056593] Setting up static identity map for 0x8240 - 0x8274
[ 0.058987] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.059420] [bcm2709_secondary_init] enter cpu:1
[ 0.059480] CPU1: update cpu_capacity 1024
[ 0.059488] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.060064] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.060415] [bcm2709_secondary_init] enter cpu:2
[ 0.060446] CPU2: update cpu_capacity 1024
[ 0.060454] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.060983] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.061236] [bcm2709_secondary_init] enter cpu:3
[ 0.061267] CPU3: update cpu_capacity 1024
[ 0.061275] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.061362] Brought up 4 CPUs
[ 0.061473] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.061506] CPU: All CPU(s) started in HYP mode.
[ 0.061535] CPU: Virtualization extensions available.
[ 0.062457] devtmpfs: initialized
[ 0.076038] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.076541] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.077588] pinctrl core: initialized pinctrl subsystem
[ 0.078396] NET: Registered protocol family 16
[ 0.084248] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.092672] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.092735] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.092961] Serial: AMBA PL011 UART driver
[ 0.093308] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.598431] console [ttyAMA0] enabled
[ 0.602743] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.682102] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.690846] SCSI subsystem initialized
[ 0.694858] usbcore: registered new interface driver usbfs
[ 0.700511] usbcore: registered new interface driver hub
[ 0.705994] usbcore: registered new device driver usb
[ 0.721168] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-09-21 13:13
[ 0.756944] clocksource: Switched to clocksource arch_sys_counter
[ 0.815791] FS-Cache: Loaded
[ 0.819144] CacheFiles: Loaded
[ 0.838749] NET: Registered protocol family 2
[ 0.844376] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.851658] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.858338] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.864866] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.870898] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.877632] NET: Registered protocol family 1
[ 0.882491] RPC: Registered named UNIX socket transport module.
[ 0.888492] RPC: Registered udp transport module.
[ 0.893219] RPC: Registered tcp transport module.
[ 0.897963] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.905884] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.915760] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.937738] VFS: Disk quotas dquot_6.6.0
[ 0.942068] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.951851] FS-Cache: Netfs 'nfs' registered for caching
[ 0.958395] NFS: Registering the id_resolver key type
[ 0.963539] Key type id_resolver registered
[ 0.967779] Key type id_legacy registered
[ 0.974884] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.982607] io scheduler noop registered
[ 0.986570] io scheduler deadline registered (default)
[ 0.991827] io scheduler cfq registered
[ 0.998681] BCM2708FB: allocated DMA memory fac00000
[ 1.003708] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 1.019806] Console: switching to colour frame buffer device 80x30
[ 1.977615] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.986124] vc-cma: Videocore CMA driver
[ 1.993175] vc-cma: vc_cma_base = 0x00000000
[ 2.000942] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 2.009360] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 2.018054] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 2.053022] brd: module loaded
[ 2.070290] loop: module loaded
[ 2.077585] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ 2.089248] Loading iSCSI transport class v2.0-870.
[ 2.098051] usbcore: registered new interface driver smsc95xx
[ 2.106844] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.315968] Core Release: 2.80a
[ 2.322053] Setting default values for core params
[ 2.329826] Finished setting default values for core params
[ 2.538871] Using Buffer DMA mode
[ 2.545101] Periodic Transfer Interrupt Enhancement - disabled
[ 2.553885] Multiprocessor Interrupt Enhancement - disabled
[ 2.562439] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.569831] Dedicated Tx FIFOs mode
[ 2.576702] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ 2.592801] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.630397] dwc_otg: Microframe scheduler enabled
[ 2.630482] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x80447410
[ 2.639636] WARN::hcd_init_fiq:414: FIQ ASM at 0x80447780 length 36
[ 2.649064] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb87e000
[ 2.658202] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.666299] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.679892] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 2.688696] Init: Port Power? op_state=1
[ 2.695725] Init: Power Port (0)
[ 2.702294] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.712278] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.725698] usb usb1: Product: DWC OTG Controller
[ 2.733567] usb usb1: Manufacturer: Linux 4.4.22-v7+ dwc_otg_hcd
[ 2.742759] usb usb1: SerialNumber: 3f980000.usb
[ 2.751533] hub 1-0:1.0: USB hub found
[ 2.758420] hub 1-0:1.0: 1 port detected
[ 2.766103] dwc_otg: FIQ enabled
[ 2.766117] dwc_otg: NAK holdoff enabled
[ 2.766127] dwc_otg: FIQ split-transaction FSM enabled
[ 2.766168] Module dwc_common_port init
[ 2.766546] usbcore: registered new interface driver usb-storage
[ 2.776017] mousedev: PS/2 mouse device common for all mice
[ 2.785509] bcm2835-cpufreq: min=600000 max=900000
[ 2.793669] sdhci: Secure Digital Host Controller Interface driver
[ 2.802949] sdhci: Copyright(c) Pierre Ossman
[ 2.810797] sdhost: log_buf @ bac13000 (fac13000)
[ 2.876987] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.885884] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.895445] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.904878] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.913761] usbcore: registered new interface driver usbhid
[ 2.922560] usbhid: USB HID core driver
[ 2.930222] Initializing XFRM netlink socket
[ 2.934168] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.936169] mmc0: new high speed SDHC card at address 59b4
[ 2.937041] mmcblk0: mmc0:59b4 USDU1 15.0 GiB
[ 2.952615] mmcblk0: p1 p2 p3
[ 2.974626] NET: Registered protocol family 17
[ 2.974662] Indeed it is in host mode hprt0 = 00021501
[ 2.990665] Key type dns_resolver registered
[ 2.998659] Registering SWP/SWPB emulation handler
[ 3.007745] registered taskstats version 1
[ 3.015206] vc-sm: Videocore shared memory driver
[ 3.023086] [vc_sm_connected_init]: start
[ 3.030922] [vc_sm_connected_init]: end - returning 0
[ 3.039382] of_cfs_init
[ 3.044967] of_cfs_init: OK
[ 3.054791] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 3.068076] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 3.147037] usb 1-1: new full-speed USB device number 2 using dwc_otg
[ 3.156968] Indeed it is in host mode hprt0 = 00021501
[ 3.357262] usb 1-1: not running at top speed; connect to a high speed hub
[ 3.367710] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.377656] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.389084] hub 1-1:1.0: USB hub found
[ 3.396178] hub 1-1:1.0: 5 ports detected
[ 3.559793] EXT4-fs (mmcblk0p2): recovery complete
[ 3.579127] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.593335] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.606482] devtmpfs: mounted
[ 3.613472] Freeing unused kernel memory: 476K (807e9000 - 80860000)
[ 3.697011] usb 1-1.1: new full-speed USB device number 3 using dwc_otg
[ 3.807395] usb 1-1.1: not running at top speed; connect to a high speed hub
[ 3.818297] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.828686] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.845936] smsc95xx v1.0.4
[ 3.912273] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4c:BC:79
[ 3.964309] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.986483] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 4.007018] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 4.018639] systemd[1]: Detected architecture 'arm'.
[ 4.117281] usb 1-1.3: not running at top speed; connect to a high speed hub
[ 4.128886] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[ 4.139688] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.154585] usb 1-1.3: Product: USB 2.0 Hub
[ 4.163863] hub 1-1.3:1.0: USB hub found
[ 4.171767] hub 1-1.3:1.0: 4 ports detected
[ 4.175816] NET: Registered protocol family 10
[ 4.178068] systemd[1]: Inserted module 'ipv6'
[ 4.181483] systemd[1]: Set hostname to <raspberrypi>.
[ 4.328187] uart-pl011 3f201000.uart: no DMA platform data
[ 4.379861] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 4.506996] usb 1-1.3.1: new full-speed USB device number 5 using dwc_otg
[ 4.603064] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.621395] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.638062] usb 1-1.3.1: not running at top speed; connect to a high speed hub
[ 4.639888] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.669478] usb 1-1.3.1: New USB device found, idVendor=1a40, idProduct=0101
[ 4.678332] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.679390] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.679611] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 4.719268] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 4.740432] random: systemd: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 4.766635] usb 1-1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.783135] usb 1-1.3.1: Product: USB 2.0 Hub
[ 4.793189] hub 1-1.3.1:1.0: USB hub found
[ 4.801965] hub 1-1.3.1:1.0: 4 ports detected
[ 4.897759] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 4.907066] usb 1-1.3.2: new full-speed USB device number 6 using dwc_otg
[ 4.926337] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.942501] systemd[1]: Expecting device dev-ttyAMA0.device...
[ 4.957835] systemd[1]: Starting Remote File Systems (Pre).
[ 4.972226] systemd[1]: Reached target Remote File Systems (Pre).
[ 4.982629] systemd[1]: Starting Encrypted Volumes.
[ 4.996005] systemd[1]: Reached target Encrypted Volumes.
[ 5.005626] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 5.027394] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.044742] systemd[1]: Starting Swap.
[ 5.052698] usb 1-1.3.2: device descriptor read/all, error -71
[ 5.066521] systemd[1]: Reached target Swap.
[ 5.074659] systemd[1]: Expecting device dev-mmcblk0p1.device...
[ 5.089004] systemd[1]: Starting Root Slice.
[ 5.101473] systemd[1]: Created slice Root Slice.
[ 5.110003] systemd[1]: Starting User and Session Slice.
[ 5.123272] systemd[1]: Created slice User and Session Slice.
[ 5.132754] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 5.146982] usb 1-1.3.1.3: new full-speed USB device number 7 using dwc_otg
[ 5.158181] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.168971] systemd[1]: Starting Delayed Shutdown Socket.
[ 5.182480] systemd[1]: Listening on Delayed Shutdown Socket.
[ 5.192056] systemd[1]: Starting Journal Socket (/dev/log).
[ 5.205612] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.215303] systemd[1]: Starting udev Control Socket.
[ 5.228018] systemd[1]: Listening on udev Control Socket.
[ 5.237129] systemd[1]: Starting udev Kernel Socket.
[ 5.249555] systemd[1]: Listening on udev Kernel Socket.
[ 5.258462] systemd[1]: Starting Journal Socket.
[ 5.267318] usb 1-1.3.1.3: not running at top speed; connect to a high speed hub
[ 5.267619] usb 1-1.3.1.3: New USB device found, idVendor=0424, idProduct=2412
[ 5.267631] usb 1-1.3.1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.268672] hub 1-1.3.1.3:1.0: USB hub found
[ 5.268820] hub 1-1.3.1.3:1.0: 2 ports detected
[ 5.331226] systemd[1]: Listening on Journal Socket.
[ 5.339997] systemd[1]: Starting System Slice.
[ 5.352155] systemd[1]: Created slice System Slice.
[ 5.360734] systemd[1]: Starting File System Check on Root Device...
[ 5.387056] usb 1-1.3.2: new full-speed USB device number 8 using dwc_otg
[ 5.427842] systemd[1]: Starting system-systemd\x2dfsck.slice.
[ 5.442461] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 5.452866] systemd[1]: Starting system-autologin.slice.
[ 5.467024] systemd[1]: Created slice system-autologin.slice.
[ 5.476786] systemd[1]: Starting system-serial\x2dgetty.slice.
[ 5.491632] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.502042] systemd[1]: Starting Increase datagram queue length...
[ 5.520040] systemd[1]: Starting Restore / save the current clock...
[ 5.537517] usb 1-1.3.2: not running at top speed; connect to a high speed hub
[ 5.547221] systemd[1]: Starting Load Kernel Modules...
[ 5.562617] usb 1-1.3.2: New USB device found, idVendor=1a40, idProduct=0101
[ 5.562630] usb 1-1.3.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 5.562639] usb 1-1.3.2: Product: USB 2.0 Hub
[ 5.577489] hub 1-1.3.2:1.0: USB hub found
[ 5.577683] hub 1-1.3.2:1.0: 4 ports detected
[ 5.618800] usb 1-1.3.1.3.1: new low-speed USB device number 9 using dwc_otg
[ 5.693343] systemd[1]: Started Set Up Additional Binary Formats.
[ 5.707773] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.734107] systemd[1]: Mounting Debug File System...
[ 5.751874] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.771319] systemd[1]: Mounted Huge Pages File System.
[ 5.775299] fuse init (API version 7.23)
[ 5.789188] systemd[1]: Starting udev Coldplug all Devices...
[ 5.808645] systemd[1]: Starting Slices.
[ 5.822755] systemd[1]: Reached target Slices.
[ 5.839848] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.853843] systemd[1]: Mounted Debug File System.
[ 5.867231] i2c /dev entries driver
[ 5.875381] systemd[1]: Started Increase datagram queue length.
[ 5.910286] systemd[1]: Started Restore / save the current clock.
[ 5.927263] systemd[1]: Started Load Kernel Modules.
[ 5.941696] systemd[1]: Started File System Check on Root Device.
[ 5.957730] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 6.017465] systemd[1]: Time has been changed
[ 6.087099] usb 1-1.3.1.3.1: new low-speed USB device number 10 using dwc_otg
[ 6.101535] systemd[1]: Started udev Coldplug all Devices.
[ 6.250931] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.307944] systemd[1]: Mounting FUSE Control File System...
[ 6.326215] systemd[1]: Starting Apply Kernel Variables...
[ 6.345926] systemd[1]: Mounting Configuration File System...
[ 6.364544] systemd[1]: Starting Syslog Socket.
[ 6.378556] systemd[1]: Listening on Syslog Socket.
[ 6.387711] systemd[1]: Starting Journal Service...
[ 6.409847] systemd[1]: Started Journal Service.
[ 6.547091] usb 1-1.3.1.3.1: new low-speed USB device number 11 using dwc_otg
[ 6.615266] systemd-udevd[137]: starting version 215
[ 7.047077] usb 1-1.3.1.3.1: new low-speed USB device number 12 using dwc_otg
[ 7.409948] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.547033] usb 1-1.3.1.3.2: new low-speed USB device number 13 using dwc_otg
[ 8.006978] usb 1-1.3.1.3.2: new low-speed USB device number 14 using dwc_otg
[ 8.466980] usb 1-1.3.1.3.2: new low-speed USB device number 15 using dwc_otg
[ 8.966978] usb 1-1.3.1.3.2: new low-speed USB device number 16 using dwc_otg
[ 9.476006] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 9.487351] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 10.220473] systemd-journald[134]: Received request to flush runtime journal from PID 1
[ 11.030620] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 11.030970] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.928600] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:2019324k SSFS
[ 11.943289] cfg80211: World regulatory domain updated:
[ 11.943317] cfg80211: DFS Master region: unset
[ 11.943326] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 11.943340] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.943351] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.943361] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.943374] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 11.943387] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 11.943397] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 11.943408] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.943418] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 12.618978] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 12.660960] nf_conntrack version 0.5.0 (14808 buckets, 59232 max)
[ 13.157831] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.159316] smsc95xx 1-1.1:1.0 eth0: link up, 10Mbps, half-duplex, lpa 0x0020
[ 13.384547] tun: Universal TUN/TAP device driver, 1.6
[ 13.384573] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 14.957625] random: nonblocking pool is initialized
[ 85.117328] usb 1-1.3.4: new full-speed USB device number 17 using dwc_otg
[ 85.240914] usb 1-1.3.4: not running at top speed; connect to a high speed hub
[ 85.251426] usb 1-1.3.4: New USB device found, idVendor=12d1, idProduct=1001
[ 85.251451] usb 1-1.3.4: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 85.251469] usb 1-1.3.4: Product: HUAWEI Mobile
[ 85.251484] usb 1-1.3.4: Manufacturer: HUAWEI Technology
[ 85.256120] usb-storage 1-1.3.4:1.0: USB Mass Storage device detected
[ 85.259890] usb-storage 1-1.3.4:1.1: USB Mass Storage device detected
[ 85.261384] usb-storage 1-1.3.4:1.2: USB Mass Storage device detected
[ 85.317777] usbcore: registered new interface driver usbserial
[ 85.317933] usbcore: registered new interface driver usbserial_generic
[ 85.318055] usbserial: USB Serial support registered for generic
[ 85.335916] usbcore: registered new interface driver option
[ 85.336113] usbserial: USB Serial support registered for GSM modem (1-port)
[ 85.337024] option 1-1.3.4:1.0: GSM modem (1-port) converter detected
[ 85.340109] usb 1-1.3.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 85.340318] option 1-1.3.4:1.1: GSM modem (1-port) converter detected
[ 85.340924] usb 1-1.3.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 85.341059] option 1-1.3.4:1.2: GSM modem (1-port) converter detected
[ 85.341583] usb 1-1.3.4: GSM modem (1-port) converter now attached to ttyUSB2
[ 91.787355] usb 1-1.3.1.1: new full-speed USB device number 18 using dwc_otg
[ 91.910919] usb 1-1.3.1.1: not running at top speed; connect to a high speed hub
[ 91.921651] usb 1-1.3.1.1: New USB device found, idVendor=12d1, idProduct=1001
[ 91.921675] usb 1-1.3.1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 91.921692] usb 1-1.3.1.1: Product: HUAWEI Mobile
[ 91.921708] usb 1-1.3.1.1: Manufacturer: HUAWEI Technology
[ 91.926944] usb-storage 1-1.3.1.1:1.0: USB Mass Storage device detected
[ 91.928640] option 1-1.3.1.1:1.0: GSM modem (1-port) converter detected
[ 91.929372] usb 1-1.3.1.1: GSM modem (1-port) converter now attached to ttyUSB3
[ 91.930259] usb-storage 1-1.3.1.1:1.1: USB Mass Storage device detected
[ 91.930956] option 1-1.3.1.1:1.1: GSM modem (1-port) converter detected
[ 91.931573] usb 1-1.3.1.1: GSM modem (1-port) converter now attached to ttyUSB4
[ 91.932310] usb-storage 1-1.3.1.1:1.2: USB Mass Storage device detected
[ 91.932921] option 1-1.3.1.1:1.2: GSM modem (1-port) converter detected
[ 91.933518] usb 1-1.3.1.1: GSM modem (1-port) converter now attached to ttyUSB5
[ 94.097341] usb 1-1.3.2.4: new full-speed USB device number 19 using dwc_otg
[ 94.220664] usb 1-1.3.2.4: not running at top speed; connect to a high speed hub
[ 94.231229] usb 1-1.3.2.4: New USB device found, idVendor=12d1, idProduct=1001
[ 94.231245] usb 1-1.3.2.4: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 94.231256] usb 1-1.3.2.4: Product: HUAWEI Mobile
[ 94.231267] usb 1-1.3.2.4: Manufacturer: HUAWEI Technology
[ 94.234608] usb-storage 1-1.3.2.4:1.0: USB Mass Storage device detected
[ 94.235147] option 1-1.3.2.4:1.0: GSM modem (1-port) converter detected
[ 94.235590] usb 1-1.3.2.4: GSM modem (1-port) converter now attached to ttyUSB6
[ 94.236189] usb-storage 1-1.3.2.4:1.1: USB Mass Storage device detected
[ 94.236561] option 1-1.3.2.4:1.1: GSM modem (1-port) converter detected
[ 94.236998] usb 1-1.3.2.4: GSM modem (1-port) converter now attached to ttyUSB7
[ 94.238138] usb-storage 1-1.3.2.4:1.2: USB Mass Storage device detected
[ 94.238613] option 1-1.3.2.4:1.2: GSM modem (1-port) converter detected
[ 94.239114] usb 1-1.3.2.4: GSM modem (1-port) converter now attached to ttyUSB8
[ 96.307350] usb 1-1.3.2.2: new full-speed USB device number 20 using dwc_otg
[ 96.430790] usb 1-1.3.2.2: not running at top speed; connect to a high speed hub
[ 96.441113] usb 1-1.3.2.2: New USB device found, idVendor=12d1, idProduct=1001
[ 96.441131] usb 1-1.3.2.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[ 96.441142] usb 1-1.3.2.2: Product: HUAWEI Mobile
[ 96.441153] usb 1-1.3.2.2: Manufacturer: HUAWEI Technology
[ 96.444571] usb-storage 1-1.3.2.2:1.0: USB Mass Storage device detected
[ 96.445091] option 1-1.3.2.2:1.0: GSM modem (1-port) converter detected
[ 96.445565] usb 1-1.3.2.2: GSM modem (1-port) converter now attached to ttyUSB9
[ 96.446106] usb-storage 1-1.3.2.2:1.1: USB Mass Storage device detected
[ 96.446479] option 1-1.3.2.2:1.1: GSM modem (1-port) converter detected
[ 96.446882] usb 1-1.3.2.2: GSM modem (1-port) converter now attached to ttyUSB10
[ 96.447378] usb-storage 1-1.3.2.2:1.2: USB Mass Storage device detected
[ 96.448608] option 1-1.3.2.2:1.2: GSM modem (1-port) converter detected
[ 96.449142] usb 1-1.3.2.2: GSM modem (1-port) converter now attached to ttyUSB11
[ 133.257515] ------------[ cut here ]------------
[ 133.257587] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:306 dev_watchdog+0x2a4/0x2b0()
[ 133.257624] NETDEV WATCHDOG: eth0 (smsc95xx): transmit queue 0 timed out
[ 133.257641] Modules linked in: option usb_wwan usbserial tun xt_REDIRECT nf_nat_redirect xt_tcpudp iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables x_tables binfmt_misc cfg80211 rfkill snd_bcm2835 snd_pcm snd_timer bcm2835_gpiomem snd bcm2835_wdt uio_pdrv_genirq uio i2c_dev fuse ipv6
[ 133.257845] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.22-v7+ #912
[ 133.257864] Hardware name: BCM2709
[ 133.257912] [<80018784>] (unwind_backtrace) from [<80014058>] (show_stack+0x20/0x24)
[ 133.257965] [<80014058>] (show_stack) from [<80321064>] (dump_stack+0xd4/0x118)
[ 133.257999] [<80321064>] (dump_stack) from [<800253c0>] (warn_slowpath_common+0x98/0xc8)
[ 133.258032] [<800253c0>] (warn_slowpath_common) from [<80025430>] (warn_slowpath_fmt+0x40/0x48)
[ 133.258058] [<80025430>] (warn_slowpath_fmt) from [<804f9640>] (dev_watchdog+0x2a4/0x2b0)
[ 133.258095] [<804f9640>] (dev_watchdog) from [<80081db0>] (call_timer_fn+0x40/0x1a0)
[ 133.258119] [<80081db0>] (call_timer_fn) from [<800820d0>] (run_timer_softirq+0x1c0/0x324)
[ 133.258155] [<800820d0>] (run_timer_softirq) from [<80029110>] (__do_softirq+0x18c/0x3cc)
[ 133.258177] [<80029110>] (__do_softirq) from [<800296f0>] (irq_exit+0xdc/0x140)
[ 133.258215] [<800296f0>] (irq_exit) from [<80071274>] (__handle_domain_irq+0x70/0xc4)
[ 133.258241] [<80071274>] (__handle_domain_irq) from [<80010a74>] (handle_IRQ+0x2c/0x30)
[ 133.258279] [<80010a74>] (handle_IRQ) from [<8000951c>] (bcm2836_arm_irqchip_handle_irq+0xb8/0xbc)
[ 133.258306] [<8000951c>] (bcm2836_arm_irqchip_handle_irq) from [<805ba784>] (__irq_svc+0x44/0x5c)
[ 133.258332] Exception stack(0x80861f08 to 0x80861f50)
[ 133.258351] 1f00: 00000000 b9f623c8 00000000 00000000 80860000 808625dc
[ 133.258379] 1f20: 80862500 80862580 805bee5c 808c68d8 ba7ff6c0 80861f64 808634f8 80861f58
[ 133.258395] 1f40: 80010b34 80010b38 60000013 ffffffff
[ 133.258435] [<805ba784>] (__irq_svc) from [<80010b38>] (arch_cpu_idle+0x34/0x4c)
[ 133.258472] [<80010b38>] (arch_cpu_idle) from [<80063fa0>] (default_idle_call+0x34/0x48)
[ 133.258499] [<80063fa0>] (default_idle_call) from [<800641c8>] (cpu_startup_entry+0x214/0x2b0)
[ 133.258536] [<800641c8>] (cpu_startup_entry) from [<805b503c>] (rest_init+0x88/0x8c)
[ 133.258563] [<805b503c>] (rest_init) from [<807e9d34>] (start_kernel+0x3dc/0x3e8)
[ 133.258628] ---[ end trace c60781dd79e330e3 ]---
[ 150.073181] usb 1-1.3.1.1: USB disconnect, device number 18
[ 150.074566] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 150.074663] option 1-1.3.1.1:1.0: device disconnected
[ 150.077296] option1 ttyUSB4: GSM modem (1-port) converter now disconnected from ttyUSB4
[ 150.077458] option 1-1.3.1.1:1.1: device disconnected
[ 150.079836] usb 1-1.3.4: USB disconnect, device number 17
[ 150.081098] option1 ttyUSB5: GSM modem (1-port) converter now disconnected from ttyUSB5
[ 150.081217] option 1-1.3.1.1:1.2: device disconnected
[ 150.082025] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 150.082155] option 1-1.3.4:1.0: device disconnected
[ 150.083891] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 150.084136] option 1-1.3.4:1.1: device disconnected
[ 150.085298] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 150.085420] option 1-1.3.4:1.2: device disconnected
[ 153.912470] usb 1-1.3.2.4: USB disconnect, device number 19
[ 153.913372] option1 ttyUSB6: GSM modem (1-port) converter now disconnected from ttyUSB6
[ 153.913471] option 1-1.3.2.4:1.0: device disconnected
[ 153.914271] option1 ttyUSB7: GSM modem (1-port) converter now disconnected from ttyUSB7
[ 153.914378] option 1-1.3.2.4:1.1: device disconnected
[ 153.915535] option1 ttyUSB8: GSM modem (1-port) converter now disconnected from ttyUSB8
[ 153.915677] option 1-1.3.2.4:1.2: device disconnected
[ 157.373521] usb 1-1.3.2.2: USB disconnect, device number 20
[ 157.374406] option1 ttyUSB9: GSM modem (1-port) converter now disconnected from ttyUSB9
[ 157.374506] option 1-1.3.2.2:1.0: device disconnected
[ 157.375352] option1 ttyUSB10: GSM modem (1-port) converter now disconnected from ttyUSB10
[ 157.375462] option 1-1.3.2.2:1.1: device disconnected
[ 157.376642] option1 ttyUSB11: GSM modem (1-port) converter now disconnected from ttyUSB11
[ 157.376787] option 1-1.3.2.2:1.2: device disconnected
