kgzg289
PWM on PI3 model
Tue Oct 18, 2016 2:21 pm
I tried a small C-program to use the PWM channel on PI2 B+ RPI (plug pin 12 GPIO pin 18) model and it worked fine. Now I configured a PI3 model with Raspian and tried the sam program but it did not work. Any one that can help me out? See code below.
// pwm.c
// Example program for bcm2835 library
// Shows how to use PWM to control GPIO pins
// After installing bcm2835, you can build this
// with sint argc, char **argvomething like:
// gcc -o pwm pwm.c -l bcm2835
// sudo ./pwm
// Or you can test it before installing with:
// gcc -o pwm -I ../../src ../../src/bcm2835.c pwm.c
// sudo ./pwm
// Author: Mike McCauley
// Copyright (C) 2013 Mike McCauley
// $Id: RF22.h,v 1.21 2012/05/30 01:51:25 mikem Exp $
#include <bcm2835.h>
#include <stdio.h>
// PWM output on RPi Plug P1 pin 12 (which is GPIO pin 18)
// in alt fun 5.
// Note that this is the _only_ PWM pin available on the RPi IO headers
#define PIN RPI_GPIO_P1_12
// and it is controlled by PWM channel 0
#define PWM_CHANNEL 0
// This controls the max range of the PWM signal
//#define RANGE 1024
#define RANGE 1024
int main(int argc, char **argv)
if (!bcm2835_init()) return 1;
// Set the output pin to Alt Fun 5, to allow PWM channel 0 to be output there
bcm2835_gpio_fsel(PIN, BCM2835_GPIO_FSEL_ALT5);
// Clock divider is set to 16.
// With a divider of 16 and a RANGE of 1024, in MARKSPACE mode,
// the pulse repetition frequency will be
// 1.2MHz/1024 = 1171.875Hz, suitable for driving a DC motor with PWM
// bcm2835_pwm_set_clock(BCM2835_PWM_CLOCK_DIVIDER_1024);
bcm2835_pwm_set_clock(400);
bcm2835_pwm_set_mode(PWM_CHANNEL, 1, 1);
bcm2835_pwm_set_range(PWM_CHANNEL, RANGE);
// Vary the PWM m/s ratio between 1/RANGE and (RANGE-1)/RANGE
int direction = 1;
// int data = 1;
int data = 30;
while (1)
// if (data == 1)
if (data == 30)
direction = 1;
// else if (data == RANGE-1)
else if (data == 110)
direction = -1;
data += direction;
// bcm2835_pwm_set_data(PWM_CHANNEL, 50);
bcm2835_pwm_set_data(PWM_CHANNEL, data);
bcm2835_delay(50);
bcm2835_close();
return 0;
BMS Doug
Re: PWM on PI3 model
Tue Oct 18, 2016 2:38 pm
Have you looked at PIGPIO, you can get hardware timed PWM on any GPIO pin.
General
The pigpio library is written in the C programming language.
The pigpio daemon offers a socket and pipe interface to the underlying C library.
A C library and a Python module allow control of the GPIO via the pigpio daemon.
There is third party support for a number of other languages.
Doug.
