paolojo
How to monitor threads activities
Tue Oct 11, 2016 10:28 am
Hi!
Could you suggest me a method to analize what are the threads that are runnig (something like "task manager" in windows)?
My python script launches simultaneously three thread every about five seconds. Each thread runs for about one second then he finishes his activities.
The problem is that after the script launches about 90 times the above theads, the raspy crashes.
My doubt is: probably the threads don't finish but remain in background causing CPU crash.
Could you help me?
Thanks a lot
topguy
Re: How to monitor threads activities
Tue Oct 11, 2016 11:03 am
Are you saying that the whole Pi freezes and not only your program crashes ?
The "ps" command is similar to task-manager in windows.
List all running processes.
ps -ef
Show running threads for a specific process.
ps -Lf -p799
joan
Tue Oct 11, 2016 11:04 am
Use top, e.g.
top -u pi H
will show all threads used by user pi.
mfa298
Tue Oct 11, 2016 12:45 pm
paolojo wrote:Hi!
Could you help me?
Thanks a lot
Threads in things like Python and Ruby don't always equate directly to OS threads.
Sometimes the easiest way to see what's happening is to put lots of print statements into your code. Print out when threads start and exit and you should have some idea if what's happening.
If your script is running and then exiting then any threads it created should also stop (If you've started up external commands then they may not get killed by your script or the OS when the script finishes).
ewaller
Tue Oct 11, 2016 4:33 pm
joan wrote:Use top
Or, IMHO even better, htop
