dentex
RPi3 booting with Read-Only root filesystem
Wed Oct 05, 2016 9:45 am
Today I wanted to continue to work on a certain DIY project involving a RPi3, but I found nothing started at boot as it shoud. The filesystem was mounted read-only. Everything work if I do:
sudo mount -o remount,rw /
...but I don't know what happened and where to look for a solution.
By chance, I did a backup image of the root USB system (I always have root filesystem on a USB drive) just after the last shut down, two days ago. So I thought: <<that's good, I'll restore the system to another drive and I'll be good to go. Must be this USB drive>> ... Unfortunately not: whatever happened that's booting Raspbian read-only, it happened before taking the snapshot. On the new drive with the restored image it's exactly the same.
Any ideas? I made some searches, but I found nothing ("read-only" "boot" "raspberry pi" returns only stuff where you *want* to
boot RO and this is not my case).
Thanks!
One of my projects with the Raspberry Pi:
(Raspberry) Pi Aquarium Controller: https://github.com/dentex/piac
