microSDHC card : Removing embedded card write protection
Posted: Sun Sep 25, 2016 10:28 pm
by BigJinge
I bought a 16GB microSDHC card a month or so ago and have been using it fine in my Rasp Pi 3.
I've now bought a Rasp Pi Zero 1.3 and went to reuse the memory card.
I used Win32DiskImager again to write the Jessie Lite img and it said that the card is write protected.
I've gone though all the steps, registry change, diskpart, EaseUS, Paragon, even putting the microSDHC card in a full size SD card converter (one with a write protect tab, turned off) and nothing will remove the write protection.
SD cards have an independent software write protect flag. I found this article on how to remove it with a Rasp Pi.
http://www.bertold.org/sdtool/
In a nutshell it says to use the following command to lock the card, ergo I used unlock at the end.
wget http://bertold.org/sdtool/sdtool-rpi -O /tmp/sdtool;chmod +x /tmp/sdtool;/tmp/sdtool /dev/mmcblk0 lock
However.....
When I run this with unlock, it gives the error :
[-] Failed to open MMC block device: Permission denied
The boot card in the Pi is mmcblk0. Same error if I put sudo in front of the command.
Anyone had this issue, used this tool? Different syntax?
Note : This card isn't faulty. It works fine in the Pi 3. It's just locked and I want to wipe it to install Jessie Lite on it, fresh..
UPDATE : The card is permanently locked, any writing to the card after the permanent write protect flag was turned on, is ignored.
Thanks in advance
BigJinge
Re: microSDHC card : Removing embedded card write protection
Posted: Sun Sep 25, 2016 11:12 pm
by MrEngman
Curious so just tried the command but changed lock to status and got the same error. "Failed to open MMC block device: Permission denied"
So this gives error
wget http://bertold.org/sdtool/sdtool-rpi -O /tmp/sdtool;chmod +x /tmp/sdtool;/tmp/sdtool /dev/mmcblk0 status
Changed the command adding sudo to change the last part of the command to give sudo /tmp/sdtool /dev/mmcblk0 status like
wget http://bertold.org/sdtool/sdtool-rpi -O /tmp/sdtool;chmod +x /tmp/sdtool;sudo /tmp/sdtool /dev/mmcblk0 status
and this then worked OK and showed the status.
[+] Found RCA for /dev/mmcblk0: AAAA.
[+] Card CSD: 400E005A5B590001DBD37F800A404009.
[+] Write protection state: Off.
Hope this helps you.
MrEngman
Posted: Mon Sep 26, 2016 12:14 am
by BigJinge
So I tried your updated sudo status version and my card came back with this...
[+] Write protection state : Permanent
I tried with unlock at the end and it said this...
[?] Card is permanently locked. I will try to clear the flag, but it will likely fail
[+] Writing CSD.
[+] Write protection state : Off.
I ran another status just in case...
Hmmmmm.
I've read others have had this write protect issue after installing Raspbian then trying to reuse the card. I wonder if Raspbian is locking the card.
Best wishes
BigJinge
Posted: Mon Sep 26, 2016 12:25 am
by BigJinge
He's someone else with the permanent write protected lock bit enabled on the card.
viewtopic.php?p=422350#p422350
Posted: Mon Sep 26, 2016 12:55 am
by BigJinge
Doing some more digging it appears that if the firmware of an SD card thinks that the data on the card will get corrupted it turns on the permanent write protect flag basically turning the card into a ROM card.
You're not supposed to remove the permanent write flag but that doesn't stop people from trying.
viewtopic.php?p=162205#p162205
Posted: Mon Sep 26, 2016 1:21 am
by wh7qq
Funny, I have never encountered this problem with any legitimate SD card. I think the problem lies with Win32DiskImager. It must need a freshly formatted SD card so if you use the SDFormat utility (free from SD Association) or the Linux utility "gparted" to put a new format on the card, it should accept an image just like new.
Posted: Mon Sep 26, 2016 2:04 am
by BigJinge
I'll check the other card (exact same type) and see if the Permanent flag is on.
Regarding Win32DiskImager, if it was locking the cards after the img file was pushed then you wouldn't be able to configure the card with raspi-config, which you can.
I've installed OpenCV and others.
Only now I want to format it do I find it perm locked in the card firmware.
Posted: Mon Sep 26, 2016 7:25 am
by drgeoff
wh7qq wrote:I think the problem lies with Win32DiskImager. It must need a freshly formatted SD card so if you use the SDFormat utility (free from SD Association) or the Linux utility "gparted" to put a new format on the card, it should accept an image just like new.
That thinking is incorrect. Win32DiskImager does not require a formatted card.
Posted: Mon Sep 26, 2016 2:23 pm
by BigJinge
Follow up.
I checked my other card, and that is fine. The status for that one reads
Both cards are Lexar 633x microSDHCs
On the card with the issue I created a folder and a txt file, then rebooted the Pi. The folder and txt file had disappeared pointing to the changes were made to RAM but the write commits didn't complete on the card..... due to it being permanently locked.
I've made a support request to Lexar for an exchange.
