howroyd
Arduino Programming over Serial
Thu Sep 22, 2016 5:21 pm
Hello all,
Right, firstly there seems to be loads of information out there but not for this specific problem (that I can find). Mega thanks to anyone who can help.
I have an Arduino Nano hooked up to my Pi (2B) on the rx/tx lines, crossed and via a LLC.
I want to use avrdude to program my Arduino over the serial connection, on top of the normal bootloader. What command line command do I use to do this?
All the posts I have read use SPI and overwrite the bootloader which is not what I want.
This must be possible because that is exactly how the normal USB programming works.
Kind regards
Simon
PS: I have a transistor on the reset pin hooked up to rPi GPIO25 which I can use to manually toggle the reset when needed (or I can just press the button!)
hal8000
Re: Arduino Programming over Serial
Fri Sep 23, 2016 8:20 pm
I'm not sure this is exactly what you want to do because I can only find
avrdude at the link below:
http://www.ladyada.net/learn/avr/avrdude.html
Is that the Avrdude program you want to use?
It looks like its intended for windows use and although there
is a menu for unix, minicom and cutecom are terminal programs
for linux.
This page has a minicom example to communicate with Arduino
https://oscarliang.com/raspberry-pi-and ... rial-gpio/
