alberich2k5
No shared libraries
Thu Aug 30, 2012 9:19 am
Hi again,
I'm trying to build a very simple firmware, using the github repository stuff.
I got the cross-compiler, the target_fs, and the kernel (cutdown, and kernel.img).
Then I cross-compiled zlib and libjpeg with no problem, and after that i tiny program i did.
For my surprise, the firmware cannot load shared libraries. I also tried to set up the LD_LIBRARY_PATH variable, with no luck. All libraries are located at /lib (by the make install, not by me).
Anyone has faces a similar issue??
thanks!
