First-timer here. I recently set up a ribbon cable up to my Pi, going onto a breadboard. I've been following a beginner tutorial that came with this starter kit that involves running the 3.3V power (3V3) through a 220-ohm resistor, through the LED, finally ending with the ground (GND) pin.
My goal is to light up the LED, which to my understanding should be lighting up immediately upon plugging in the power to the Pi, if everything is set up correctly.
However, I cannot get the LED to light up.
I've triple-checked several connections, such as:
- Making sure the ribbon cable is oriented correctly on the Pi (red line is positioned towards the SD card (outer side))
- Making sure the ribbon cable is oriented correctly on the breadboard (only one orientation is physically possible, due to a notch in the cable)
- Making sure the LED is oriented the right way (longer leg towards the resistor)
Lastly, I believe that the breadboard does not have any interrupted power (the blue and red lines are continuous, with no break).
I think my next step is to buy a multimeter and confirm the electricity flow at each step.
What do you think? Is my wiring correct for now? Please see the following photo. Note that I added in purple/pink squares to more easily see where those jumpers are going.
http://i.imgur.com/EomKX4T.jpg
