ulix
After startup raspistill won't safe images
Mon Sep 12, 2016 1:57 pm
why is raspistill not saving images to the place I wrote in local.rc?
See my code..., when used in the command line it works :cry:
  GNU nano 2.2.6                                                        Datei: rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will "exit 0" on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
mkdir /home/pi/tl/$(date '+%d-%b-%Y')
sudo raspistill -n -o /home/pi/tl/$(date '+%d-%b-%Y')/p%04d.jpg -t 4000000 -tl 45000
exit 0
thank you
nl3prc
Re: After startup raspistill won't safe images
Mon Sep 12, 2016 3:11 pm
Check your logs in /var/log
But I think that your rc.local script runs to soon
N
ulix
Mon Sep 12, 2016 3:14 pm
well which log file? I did look, but found nothing.
How can I start it later? How long do I have to wait?
nl3prc
Mon Sep 12, 2016 3:47 pm
Make a file
sudo nano yourfile
Make your text in the file
Ctrl x to exit and y to confirm that you want to save the file
#!/bin/bash
sudo chmod 755 yourfile
Then put the file in /etc/init.d
sudo update-rc.d youfile defaults 95 5
ulix
Mon Sep 12, 2016 9:50 pm
got it working with the command sleep!
Thanks a lot!
