promod
USB to Serial ( with CH34x ) not working.
Mon Sep 12, 2016 10:46 am
I try USB to serial convertov with chip CH 341 ( CH340 ) but it doesn't work. I try steps on https://github.com/aperepel/raspberrypi-ch340-driver but 1-Minute How-To nor compilation fails. Is it possible to use CH34x with raspberry?
Thanks for your answer.
topguy
Re: USB to Serial ( with CH34x ) not working.
Mon Sep 12, 2016 11:40 am
Providing error-messages from those failures would be helpful for those people who would like to help but dont know the answer to "Is it possible to use CH34x with raspberry?".
promod
Mon Sep 12, 2016 12:47 pm
If I try to follow steps in https://github.com/aperepel/raspberrypi-ch340-driver but:
One minute how to ends :
sudo insmod ch34x.ko
insmod: ERROR: could not insert module ch34x.ko: Invalid module format
Compilation - produces ch34x.ko, but driver doesn't work..
I try to send something with serial parameters 4800 Baud, Even parity, 7 Bits, 1 Stop bit, and I get other bytes that I sent. On raspberry forum there were some discusions about converter CH341 ( CH 340 ) but I didn't find success result of this driver mistake.
ernestzulueta
Wed Nov 02, 2016 2:50 am
hi everyone, can we use FTDI drivers in ch340 chip ?
Alexandre Toledo
Mon Sep 04, 2017 4:21 am
download
[email protected]:~ $ wget https://github.com/aperepel/raspberrypi ... 7/ch34x.ko
check
[email protected]:~ $ lsmod
Module Size Used by
bnep 12051 2
hci_uart 20020 1
btbcm 7916 1 hci_uart
bluetooth 365511 22 hci_uart,bnep,btbcm
brcmfmac 222874 0
brcmutil 9092 1 brcmfmac
cfg80211 543027 1 brcmfmac
rfkill 20851 4 bluetooth,cfg80211
snd_bcm2835 24427 1
snd_pcm 98501 1 snd_bcm2835
snd_timer 23968 1 snd_pcm
snd 70032 5 snd_timer,snd_bcm2835,snd_pcm
bcm2835_gpiomem 3940 0
evdev 12423 6
joydev 9988 0
uio_pdrv_genirq 3923 0
uio 10204 1 uio_pdrv_genirq
fixed 3285 0
i2c_dev 6913 0
fuse 99603 3
ipv6 408971 70
go towards
[email protected]:~ $ cd /lib/modules/$(uname -r)/kernel/drivers/usb/serial
Install first
[email protected]:/lib/modules/4.9.35-v7+/kernel/drivers/usb/serial $ sudo insmod usbserial.ko
Check once again
[email protected]:/lib/modules/4.9.35-v7+/kernel/drivers/usb/serial $ lsmod
Module Size Used by
usbserial 29943 0 <===== Need be installed FIRST
bnep 12051 2
hci_uart 20020 1
brcmfmac 222874 0
snd_bcm2835 24427 1
evdev 12423 6
joydev 9988 0
fixed 3285 0
i2c_dev 6913 0
fuse 99603 3
ipv6 408971 68
NOW, install ch341.ko
[email protected]:/lib/modules/4.9.35-v7+/kernel/drivers/usb/serial $ sudo insmod ch341.ko
Voilá !!!
Module Size Used by
ch341 6086 0 <==== Must be here first
usbserial 29943 1 ch341 <==== Can you see me now ?
bnep 12051 2
hci_uart 20020 1
brcmfmac 222874 0
snd_bcm2835 24427 1
evdev 12423 6
joydev 9988 0
fixed 3285 0
i2c_dev 6913 0
fuse 99603 3
ipv6 408971 68
Greetings
Alexandre Toledo
[email protected]
Posted too at : https://github.com/aperepel/raspberrypi ... r/issues/3
gatherer
Sat Dec 16, 2017 10:30 pm
Still not working?
Kernel 4.9.59-v7+
scruss
Sun Dec 17, 2017 2:13 am
Has worked fine for me for some time with stock kernel and no recompilation. Are the devices not being seen at all? Anything in lsusb? Are there any /dev/ttyUSB* devices?
Pronouns: he/him
gatherer
Sun Dec 17, 2017 6:58 pm
Sorry for the fuzz. It’s working perfect with a new cable.
Thank you
