medicengonzo
Samba client keeps asking for password and can't login.
Sat Sep 03, 2016 9:08 pm
I recently corrupted my sd and after fixing it I have found that my samba server wasn't working as expected.
After reinstalling the samba server using this instructions http://raspberrywebserver.com/serveradm ... twork.html I try to log in to the smb server from Kodi in Ubuntu but after I put my username and password Kodi just asks for it again (the same thing happens from the ubuntu File Manager).
All this was working fine the first time I set it up.
Here's my smb.conf file:
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
#  - When such options are commented with ";", the proposed setting
#    differs from the default Samba behaviour
#  - When commented with "#", the proposed setting is the default
#    behaviour of Samba but the option is considered important
#    enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
   workgroup = WORKGROUP
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
   wins support = yes
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
;   wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
   dns proxy = no
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
   max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
#   syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
   syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
   panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone sever" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
   server role = standalone server
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
   passdb backend = tdbsam
   obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
   unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<[email protected]> for
# sending the correct chat script for the passwd program in Debian Sarge).
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
   pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
   map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
#   logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
#   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap uid = 10000-20000
;   idmap gid = 10000-20000
;   template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
;   usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
   usershare allow guests = yes
#======================= Share Definitions =======================
[homes]
   comment = Home Directories
   browseable = no
[pihome]
   comment= Pi Home
   path=/home/pi
   browseable=Yes
   writeable=Yes
   only guest=no
   create mask=0777
   directory mask=0777
   public=no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
   read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# The following parameter makes sure that only "username" can connect
# to \\server\username
# This might need tweaking when using external authentication schemes
   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
;   directory mask = 0700
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
;   write list = root, @lpadmin
EDIT:
It seems this only happens when I try to access my mounted USB (the home folder I can access fine). Maybe I mounted it in a wrong way?
topguy
Re: Samba client keeps asking for password and can't login.
Sat Sep 03, 2016 9:10 pm
And you did set the password with "smbpasswd" on the Pi ?
medicengonzo
Sat Sep 03, 2016 9:29 pm
I did
smbpasswd -a pi
Then I entered my raspberry password twice.
I have followed those instructions successfully before. But since I had to reinstall the samba server everything stopped working.
medicengonzo
Mon Sep 05, 2016 4:54 pm
Just coming back to say I fixed my issue:
What I did is change my smb.conf, the part of the USB Share now looks like this:
[torrent_complete]
	comment = Torrent directory
	path = /media/pi/SERAPH02/Torrent_complete
	valid users = pi
	create mask = 0777
	directory mask = 0777
I erased all the settings that allowed guest users and instead used "valid users" to allow my default pi user. This fixed completely my issues.
donbrew
Mon Sep 05, 2016 5:06 pm
I am curious. Why would you need Samba to access a local Linux folder? You should only need it for a Windows network folder.
topguy
Tue Sep 06, 2016 11:13 am
I'm assuming that the "Ubuntu" machine with Kodi is not the Pi. The Pi is the fileserver.
Wed Sep 07, 2016 12:27 am
topguy wrote:I'm assuming that the "Ubuntu" machine with Kodi is not the Pi. The Pi is the fileserver.
If both the client and the server are running Linux then NFS is a much better choice for filesharing that CIFS/Samba.
This is a doctor free zone.
eMEsut
Fri Apr 19, 2019 9:31 am
Hi Everyone,
I have same problem.
I tried many method but still i have same problem. I can get login screen but can't login from windows :(
First this tutorial https://elinux.org/R-Pi_NAS#Configuring ... Windows_PC
then i install again raspbian
Second i tried https://pchelp.ricmedia.com/build-raspb ... -server/4/
 sudo smbpasswd -a pi
Then I entered my raspberry password twice...
Can you help me please?
Press enter to see a dump of your service definitions
# Global parameters
[global]
        max log size = 1000
        syslog = 0
        usershare allow guests = Yes
        map to guest = Bad User
        obey pam restrictions = Yes
        pam password change = Yes
        unix password sync = Yes
        dns proxy = No
        idmap config * : backend = tdb
[homes]
        browseable = No
        create mask = 0700
        valid users = %S
[printers]
        browseable = No
        printable = Yes
        create mask = 0700
[print$]
[NAS]
        comment = RasPi NAS Share
        path = /mnt
        create mask = 0777
        force user = root
        read only = No
hortimech
Fri Apr 19, 2019 12:24 pm
Why are you forcing everyone to be 'root' ? this is very insecure.
Talking off insecure, this is possibly your problem, the version of Samba that comes with raspbian has NTLMv1 turned off, but your Windows clients may not have, try adding 'ntlm auth = yes' to smb.conf and see if this helps.
eMEsut
Fri Apr 19, 2019 3:02 pm
Thank you very much for your help.
I am just newbie on linux
On smb.conf file i remove frocing everyone than added ntlm auth = yes
But i have still same problem, i am realy confused. :shock:
I like to see all my sdcard, usb sticks on rpi for copying, removing file easy way. If you show me different solitons like samba, i can it install?
 [email protected]:~ $ testparm
Load smb config files from /etc/samba/smb.conf
rlimit_max: increasing rlimit_max (1024) to minimum Windows limit (16384)
WARNING: The "syslog" option is deprecated
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
Processing section "[NAS]"
Global parameter ntlm auth found in service section!
Loaded services file OK.
Server role: ROLE_STANDALONE
# Global parameters
[global]
        max log size = 1000
        syslog = 0
        dns proxy = No
[homes]
        browseable = No
        create mask = 0700
        valid users = %S
[printers]
        browseable = No
        printable = Yes
        create mask = 0700
[print$]
[NAS]
        path = /mnt
        create mask = 0777
        read only = No
        valid users = pi
[email protected]:~ $ sudo /etc/init.d/samba restart
[ ok ] Restarting nmbd (via systemctl): nmbd.service.
[ ok ] Restarting smbd (via systemctl): smbd.service.
Fri Apr 19, 2019 3:04 pm
It's probably a NTFS filesystem mounted at /mnt with no override for uid=, & gid= on the mount command.
It is 100% insecure.
eMEsut
Fri Apr 19, 2019 3:19 pm
Thank you
But i am just newbie, when something going wrong i lose my self on linux :D
I just install raspbian on rpi3 to my sd and install it. When i like to use samba on my rpi these are happend :?
