devenh
3.5mm audio output volume
Wed Aug 31, 2016 1:49 am
I have a Python 3 app that plays audio using pygame. The audio output using headphones is okay, but if I plug the audio into my car's AUX input, the volume is very low. I have to turn the car's volume WAY up and the sound is still low. Running a Pi 2 under Jessie.
Suggestions?
devenh
Re: 3.5mm audio output volume
Wed Aug 31, 2016 2:01 am
Should have noted that pygame volume is set to the maximum. I've also tried a few scripts that adjust volume with no luck.
brekee12
Wed Aug 31, 2016 6:50 am
Xwindows volume control determines the whole system sound level. You may set the volume to maximum on the GUI and logout from Xwindows. The volume will stay the given value.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
flatmax
Wed Aug 31, 2016 8:59 am
Try also checking if there are extra audio controls from alsamixer.
Matt
Check the Ultra 2 sound card - use our shop instead of Amazon Europe (Amazon USA is live).
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
