I didn't have a USB charger available so I used a general 12v 1A power supply through a premade 5v smps with a 1.5A rating and plugged it into the 5v and ground pins on the GPIO header. This worked fine for hours until this morning I VNC'd into it, it was fine. Then tried again a few minutes later and it wouldn't connect. Now the only thing I get is a dim PWR LED. I finally found a USB charger and when I use it I get nothing.
When plugged into USB the test points show 1.7v. When plugged into those pins it shows 4.9v.
F1, F2 and F3 all seem to be conducting.
Was it a mistake to plug the power into that pin? Is there anything I can do about it now, or anything I can test?
