rpikurti
module i2c missing
Wed Aug 17, 2016 9:15 am
Hello to all,
I'm new here and I use a RPI for several applications.
Most of them are sensors which are connected to the i2c-port.
Now I have one problem using a LCD-display.
I do not know what drivers I need for this.
The supplier provides a image (=Linux rpizero 4.4.11 #2 Tue May 24 22:50:33 CST 2016 armv6l GNU/Linux) which works very good for the LCD display :) . But...
I can not use the i2c port.
If I run
raspi-config
I get the following message:
There was an error running option A6 I2
and
modprobe: FATAL: Module i2c-dev not found.
I think I need to add the i2c modules to the image.
I have 2 questions:
  • what i2c module do I need?
    where can i get this?
    how to add this modules ti the image?
You see I'm not an expert in making kernel.
Please can anybody give me a hint how to solve this problem?
Thanks a lot in advance!
Kurt
Re: module i2c missing
Wed Aug 17, 2016 10:05 am
Run sudo rpi-update to get the 4.4.17 kernel and replace your missing modules.
This is a doctor free zone.
rpikurti
Thu Aug 18, 2016 5:07 pm
Thanks DougieLawson,
I did execute sudo rpi-update and after the reboot there was a message on the LCD screen (watchdog watchdog0 did not stop!) :( .
Then the LCD display dit not work anymore. :oops:
I checked the item and it's a 3.5 LCD display for SPI interface which has been made by kedei and the image I got from here:
Does somebody have any idea what I can do to ger the LCD and i2c working?
Thanks!
Kurt
Fri Aug 19, 2016 1:07 am
You'll need to reinstall your screen drivers.
rpikurti
Fri Aug 19, 2016 10:05 am
thanks for your answer but I have no idea where I get this drivers. If I install the drivers provited by kedei.net Then the i2c drivers have gone.
Neither I can activate them by running raspi-config.
Sat Aug 20, 2016 6:33 am
You'll need to ask the nice folks at http://kedei.net to put them back. If they've built the kernel without I2C support then they'll have to fix it for you.
doublehp
Tue Jan 24, 2017 6:40 pm
I also had this issue.
I had downloaded rpi_35_v6_0_2_jessie_kernel_4_4_11.rar in september 2016, and had this issue.
I redownlaoded today rpi_35_v6_1_2_3_jessie_kernel_4_4_19.rar from http://kedei.net/raspberry/raspberry.html and it seems to contain the driver (according to /lib/modules directory; not running it yet).
doublehp
Thu May 17, 2018 1:43 pm
On a rPi v1, I also using pigpio to emulate I2C on the misc IO pins
http://abyz.me.uk/rpi/pigpio/
https://en.wikipedia.org/wiki/Raspberry_Pi
P5(6), GPIO 28 to 31.
