I have on my Raspbian Jessie the Libreoffice 4.3.3.2 and I want to upgrade to Libreoffice 5.2.0.
How can I do it?
Thanks!
Re: Updating Libreoffice
Assumng that LO is part of the standard Debian Jessie build, then it won't update much (if any) from the version you have with apt; when the OS is released it locks packages at the current version and they're only updated for critical security / bug fixes. If the RPF added it to the Raspbian Jessie build, then they can update it if they want.antonio8909 wrote:Hi,
How can I do it?
Thanks!
Your only other options are to remove all installed LO packages, then build from source, or run an installer if one is available for the archtecture you are using.
As far as I am aware only ArchLinuxArm has 5.2 in their Repositoryantonio8909 wrote:Hi,
How can I do it?
Thanks!
https://archlinuxarm.org/packages/armv7 ... fice-fresh
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
Yes with Raspbian go from Jessie (Stable) to Stretch (Testing) and you will have lots of newer packages not just LibreOfficeHiisi wrote:Any way to install it under Jessie?fruitoftheloom wrote:
Thanks!fruitoftheloom wrote: Yes with Raspbian go from Jessie (Stable) to Stretch (Testing) and you will have lots of newer packages not just LibreOffice
Just for the input: I did the following. Edited /etc/apt/sources.list file, changed 'jessie' to 'stretch', then
sudo apt-get update
sudo apt-get install libreoffice
I tried this, but now every time I go to Add/Remove Softwareit hangs on Searching Packages.
Any ideas how to fix? I've tried sudo apt-get update after restoring "jessie" from "stretch".
Thanks!
Thanks!
