rleonardi
Display problems after updating
Mon Aug 01, 2016 11:18 am
Dear all,
I'm using Raspberry Pi2 and Raspberry official Touch Display 7". They worked fine.
This morning I updated Raspbian by using "sudo rpi-update". After reboot and "startx", the menu bar of the desktop started to flicker and the Start button is nolonger available.
I tried also "sudo apt-get upgrade" and "sudo apt-get update" but it's the same.
I also tried on an external HDMI monitor but it's the same.
Thank you in advance for any help.
Ciao
Re: Display problems after updating
Mon Aug 01, 2016 11:30 am
rleonardi wrote:Dear all,
Ciao
sudo rpi-update is not recommended unless under advisement to fix a known issue, it will install a Testing Kernel / Firware, the correct procedure is:
sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot
RPi 4B 4GB (SSD Boot)..
rleonardi
SOLVED Display problems after updating
Mon Aug 01, 2016 12:17 pm
SOLVED
Dear Fruitoftheloom,
Yes, it worked well.
Thank you very much.
Ciao
