blackboy
(help) UART on raspberry
Tue Jul 26, 2016 1:46 pm
Hi every one,
i'm new member.
i am setting uart on raspberry, but it not work. (i am using newest version -raspian 2016-05-27).
I dont see "ttyAMA0" directory in my RPI =>
can you help me?
thank you verry much. (sorry about my english is not good.)
binaryhermit
Re: (help) UART on raspberry
Tue Jul 26, 2016 2:29 pm
MarkHaysHarris777
Tue Jul 26, 2016 2:44 pm
blackboy wrote: setting uart on raspberry, but it not work.
make sure to sudo apt-get update
make sure to sudo apt-get upgrade
Disable serial console in raspi-config; or at least remove the serial console item from /boot/cmdline.txt
Include the following two lines in /boot/config.txt:
core_freq = 250
enable_uart = 1
reboot.
You will have two serial devices: serial0 and serial1
serial0 will be a symbolic link to /dev/ttyS0
serial1 will be a symbolic link to /dev/ttyAMA0
marcus
marcus
:ugeek:
DirkS
Wed Jul 27, 2016 11:18 pm
MarkHaysHarris777 wrote:You will have two serial devices: serial0 and serial1
Only if it's a Pi3B!
blackboy
Tue Aug 02, 2016 6:50 am
core_freq = 250
enable_uart = 1
marcus
Thank you for your quick reply. i have a problems when i read uart data from icomsat v1.1 (module sim900) as shown below. Can you help me fix it?
Tks so much.
my code :
import serial
from serial import Serial
from time import sleep
ser = Serial("/dev/ttyAMA0", 9600, timeout=1)
while True:
data2 = ser.write('at')
data = ser.read(9999)
if len(data) > 0:
print data
sleep(0.5)
ser.close()
blackboy
Tue Aug 02, 2016 6:51 am
binaryhermit wrote:viewtopic.php?f=28&t=141195 perhaps?
Tks so much.
scotty101
Tue Aug 02, 2016 10:51 am
My guess would be a baud rate problem. The SIM900 seems to auto-sync baud rates but....
http://simcom.ee/documents/SIM900/SIM90 ... _V1.03.pdf
See section 4.
It is recommended to send "AT" until host device receives the "OK" response, echih means host device and SIM900 are correctly synchronised.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
blackboy
Tue Aug 02, 2016 2:35 pm
scotty101 wrote:My guess would be a baud rate problem. The SIM900 seems to auto-sync baud rates but....
See section 4.
tks for your help. i tried it, when i called to module sim, it didn't appeared "Ring Ring Ring" , i saw x###### ... on the LCD instead. I dont know what heppend?
Do you know it?
Massi
Tue Aug 02, 2016 2:57 pm
are you sure "that thing" is returning text and not binary data that you have to decode?
Tue Aug 02, 2016 5:07 pm
That looks like not the right protocol (is it sending 8N1) or not the right baud rate.
blackboy
Wed Aug 03, 2016 2:17 am
Massi wrote:are you sure "that thing" is returning text and not binary data that you have to decode?
yes, I am. When i called, Raspberry Pi recived something, but i don't know what is it, it look like "RING RING RING".
blackboy
Wed Aug 03, 2016 2:53 am
DougieLawson wrote:That looks like not the right protocol (is it sending 8N1) or not the right baud rate.
tks for your help!
I set 9600 bauds on Raspberry Ri and I used the connection as figure.
karrika
Wed Aug 03, 2016 3:30 am
blackboy wrote: while True:
if len(data) > 0:
print data
Sending "at" is not the same as sending "AT". You need to send capital letters in order to let the board recognize the right baud rate.
blackboy
Wed Aug 03, 2016 4:30 am
if len(data) > 0:
print data
That's right! but i don't read data from RX on raspberry pi. (x### as picture)
karrika
Wed Aug 03, 2016 8:30 am
According to the specs you need to send AT AT AT AT with the desired baud rate until you get OK back. Then you should lock the baud rate by sending AT+IPR
I have no clue of what this invention does. But the docs are well written and worth reading.
