helicta
Rainbow Freeze
Mon Jul 25, 2016 12:14 pm
Hi everybody !
I've a problem, when I start my Raspberry Pi B+, the green light flash two times (for 2/3 secondes) and then a big rainbow square appears on the screen.
I've tried to change power supply, micro USB cable shorter, set boot_delay=1 in config.txt and nothing works.
I don't know what to do anymore, does someone have the same problem ?
Thanks a lot.
drgeoff
Re: Rainbow Freeze
Mon Jul 25, 2016 12:25 pm
What OS is on the card and how did it get on there?
Has this ever worked previously?
RaTTuS
Contact: Twitter YouTube
Re: Rainbow Freeze
Mon Jul 25, 2016 12:59 pm
Covfefe
RAZERZ
Re: Rainbow Freeze
Mon Jul 25, 2016 1:23 pm
When the big rainbow square appears, does it appear as a small square in the top right corner of the screen or just huge in the middle?
Raspberry pi 3 set up as desktop with raspbian.
I guess you can say I am not newbie with linux but I am not a master at it either.
I will always try to help you as much as I can because I know how hard it is to run into problems :D
helicta
Re: Rainbow Freeze
Mon Jul 25, 2016 1:51 pm
I've tried several softwares as libreelec, OpenElec, and Osmc. Now it's runing on OpenElec.
There is only a huge rainbow square, no little square.
To be precise, the raspberry used to work a year and a half ago on OpenElec (with the problem of little square top right of the screen). Then I did not use it for 1y1/2 and then I've formated the new OpenElec with Kodi build and these problems happened...
RAZERZ
Re: Rainbow Freeze
Mon Jul 25, 2016 7:19 pm
If it only happens once, at boot, that is normal. As long as it does not happen at random times, that is unusual. I have seen multiple youtube videos were that happens, infact this (if you forward to 5:30) will show it.
