cescm
3TB Drive USB several formats
Fri Aug 24, 2012 3:35 pm
Hello. I'm gettin' mad with this issue.
I have a 3TB drive connected via USB to the rasp.
I've tried the following: (under RASPBMC)
formatted under OSX 10.8 in FAT32->It mounts ok and works
formatted under WIN7 in NTFS -> It doesn't mount
formatted under OSX 10.8 in HFS+->It doesn't mount
I need NTFS or HFS+ in order to store big mobies (>4.3GB), or, if I could format and mount ext4, it would be ok, too.
I've installed all packages for reading/writing ntfs and hfs+ (ntfs-3g,ntfsprogs,ntfsutils,hfsplus,hfsutils,hfsprogs, etc...) with no success.
I've tried the commands sudo mount -t hfsplus /dev/sda2 /media/CINE i.e. and it says not a HFS+ partition or bad superblock.
The same with NTFS.
I write /dev/sda2 because the 3TB is GPT partitionated.
What am I doing wrong?
I hope you can help me, and if the solution is ext4, please tell me how can I setup it.
Thank you.
snydej
Re: 3TB Drive USB several formats
Wed Aug 29, 2012 11:43 am
I also have an NTFS formatted 3TB drive that won't mount. When I look at dmesg I see:
[ 166.657599] NTFS-fs error (device sdb1): parse_ntfs_boot_sector(): Volume size (2TiB) is too large for this architecture. Maximum supported is 2TiB. Sorry.
[ 166.657656] NTFS-fs error (device sdb1): ntfs_fill_super(): Unsupported NTFS filesystem.
The funny thing is that before I switched to the most recent Raspbian image I was able to mount the drive and use it just fine. The image I was using is only about a month old. So some time recently they've managed to break their support for large NTFS filesystems. :(
snydej
Wed Aug 29, 2012 12:08 pm
I've figured out how to fix my problem; I hope yours is the same. All I had to do was the following:
sudo apt-get install ntfs-3g
Then it mounted just fine.
pi3g
Authorised Reseller
Authorised Reseller
Fri May 10, 2013 3:37 pm
Installing the package ntfs-3g also solved the problem for me, thanks!!
(Currently writing up a summary how to use the Raspi as a SAMBA server, in German, and this came in handy).
picockpit.com - tools to make your life with the Pi a little bit easier
soheil
Sat Mar 26, 2016 12:19 am
solved my 4TB external HDD mounting issue as well thanks
jahboater
Sat Mar 26, 2016 8:37 am
mkfs.ext4
see "man mkfs.ext4" for details. You don't need to install anything, ext4 is the "standard" Linux filesystem.
Pi4 8GB running PIOS64 Lite
Nicovideo
Sun Apr 16, 2017 10:04 pm
I installed ntfs-3g but get this message when I do "dmesg" :
[ 94.233365] sd 2:0:0:0: [sde] Spinning up disk...
[ 95.238078] ...................................................................................................not responding...
[ 194.458789] sd 2:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 194.459255] sd 2:0:0:0: [sde] 7814037167 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 201.403972] sd 2:0:0:0: [sde] Test WP failed, assume Write Enabled
[ 208.353775] sd 2:0:0:0: [sde] Asking for cache data failed
[ 208.353816] sd 2:0:0:0: [sde] Assuming drive cache: write through
[ 208.361246] sd 2:0:0:0: [sde] Spinning up disk...
[ 209.368200] ...................................................................................................not responding...
[ 308.428740] sd 2:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
[ 480.678147] INFO: task kworker/u8:0:6 blocked for more than 120 seconds.
[ 480.678178] Not tainted 4.4.50-v7+ #970
[ 480.678190] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 480.678206] kworker/u8:0 D 805b8364 0 6 2 0x00000000
[ 480.678256] Workqueue: events_unbound async_run_entry_fn
Then my 4TB disk drive is not nounted...
Do you have any idea about the reason?
