wmsrite
Pi3 acts like no SD is inserted
Sat Jul 23, 2016 7:13 pm
've downloaded Noobs, extracted it copied the files from the folder to a formatted micro sde card on my Linux machine. I insert the SD into a usb port via the supplied adapter from Cnakit (just a usb dongle with slot for the SD. I then plug in the Pi and nothing happens.
Thoughts? suggestions?
Goraxium
Re: Pi3 acts like no SD is inserted
Sun Jul 24, 2016 4:03 am
By extracted and copied, do you mean you followed the instructions here: https://www.raspberrypi.org/documentati ... s/linux.md?
klricks
Sun Jul 24, 2016 5:24 am
wmsrite wrote:'ve downloaded Noobs, extracted it copied the files from the folder to a formatted micro sde card on my Linux machine. I insert the SD into a usb port via the supplied adapter from Cnakit (just a usb dongle with slot for the SD. I then plug in the Pi and nothing happens.
I don't think boot from external USB has been implemented for general use yet....
If you want to try an experimental setup then look at this: https://github.com/raspberrypi/document ... des/msd.md
Otherwise the SD card needs to be in the SD slot on the RPi board.
drgeoff
Sun Jul 24, 2016 7:17 am
+1
Unless the micro-SD card is inserted in the slot on the underside of the board, the RPi3 will behave in exactly the same way as no card plugged in.
