KStatefan
Unsecurred Network
Fri Jul 15, 2016 12:25 pm
Trying to get a pi with open sprinkler to work on an unsecured network. I can get it to connect while sitting on my desk to a secured network with the following code:
update_config=1
# To configure wifi access insert your SSID and PSK with keeping the quotation marks then save the file
network={
ssid="ConfRm_2.4GHz"
psk="*********"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
auth_alg=OPEN
When I move it to the sprinkler box there is not a secure network to use so I change the code to this but it will not connect.
update_config=1
network={
ssid="Hutchinson Campus WiFi"
key_mgmt=none
How do I connect to the unsecured network?
davidcoton
Re: Unsecurred Network
Fri Jul 15, 2016 1:12 pm
You do realise that by publishing the PSK your secured network is no longer secure?
Signature retired
KStatefan
Fri Jul 15, 2016 1:43 pm
davidcoton wrote:You do realise that by publishing the PSK your secured network is no longer secure?
How do I connect to the unsecured network? I am not worried about the secured network.
mahjongg
Sat Jul 16, 2016 1:41 pm
censored psk.
