yonubear
Bad Superblock
Sat Jul 09, 2016 2:12 pm
Hi I am in need of some help I have a bad superblock on my SD Card I have tried fsck but I get this
[email protected]:~$ sudo fsck -v /dev/mmcblk0p6
[sudo] password for reg:
fsck from util-linux 2.20.1
e2fsck 1.42.9 (4-Feb-2014)
root: recovering journal
Superblock needs_recovery flag is clear, but journal has data.
Run journal anyway<y>? yes
fsck.ext4: unable to set superblock flags on root
root: ********** WARNING: Filesystem still has errors **********
I made a DD image of the card and I am able to access every partition using a linux PC any ideas what the problem is I would prefer to fix it rather than having to reconfigure everything from scratch.
Thanks,
Yonu
Re: Bad Superblock
Sat Jul 09, 2016 4:51 pm
I hope you've got a good backup because that error is usually the final death throes before you scrap the filesystem and restore from a backup.
sudo fsck -y -b 32768 /dev/mmcblk0p6
may get things working, but don't bet on it.
This is a doctor free zone.
yonubear
Re: Bad Superblock
Sun Jul 10, 2016 3:05 pm
no just the DD image I was able to pull files as if I pop te card in my linux laptop all the partitions come up so I copied the files i absolutely needed off.
I had actuaually tried that and it gave me this error as well
I am assuming I should just cut my losses and make a new card?
Thanks,
Yonu
DirkS
Re: Bad Superblock
Sun Jul 10, 2016 4:41 pm
u
Are you actually trying to repair the partition you're running from?
If so then try to do with the SD card inserted in your linux laptop.
yonubear
Re: Bad Superblock
Sun Jul 10, 2016 5:00 pm
That error is with it in the laptop I get it on any of the ext4 parts on the cards other than the part name changing
