sebbero
Error Downloading nginx , OpenSSL, php5,
Fri Jul 01, 2016 1:23 pm
Hi
Try following command sudo apt-get install nginx openssl ssl-cert php5-cli php5-sqlite php5-gd php5-common php5-cgi sqlite3 php-pear php-apc curl libapr1 libtool curl libcurl4-openssl-dev php-xml-parser php5 php5-dev php5-gd php5-fpm memcached php5-memcache varnish
If y verifcation it fails say forbidden. When i say to verfication it says some packages could not authenticated. Any one have any ideas?
New to this.
Raspberry pi error setting owncloud.PNG (37.97 KiB) Viewed 760 times
epoch1970
Re: Error Downloading nginx , OpenSSL, php5,
Fri Jul 01, 2016 3:28 pm
Your local repository cache may be outdated
Try "sudo apt-get update && sudo apt-get install ..."
