I started the work with pi3. Today i download NOOBS in SD card according to forum. I insert SD card in PI3 and other accesories. Display is LG CRT tv .The COMPOSITE CABLE IS ALSO TRRS type WHICH IS TESTED BY ME. IT IS IN COMPATIBLE WITH PI3.
I powered the PI3. I pressed 3 in my keyboard for PAL as the start . Then tv screen is showing ONLY raspbian in screen .I install RASPBIAN. After few minutes it is completed. I click the INSTALL option AND THEN I AM SHOCKED the booting is not appear and there is black screen .The ACT LED is NOW NO respond.
Is it possible that all is going on perfectly BUT my OS is not install due to any SD CARD PROBLEM at this final stage of installation? My SD card is KINGSTON 16 GB class 10. What should i do to solve my problem????? pPLZ REPLY
