[*You were right on the money!!*]
Now I can see the drive... I remembered I had one of these multi-drive bays with their own 12V power source.
Device Boot Start End Sectors Size Id Type
/dev/mmcblk0p1 8192 137215 129024 63M c W95 FAT32 (LBA)
/dev/mmcblk0p2 137216 15130623 14993408 7.2G 83 Linux
Disk /dev/sdb: 111.8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 10D53B0C-9832-462C-A721-70F094B38E0B
Device Start End Sectors Size Type
/dev/sdb1 34 262177 262144 128M Microsoft reserved
/dev/sdb2 264192 234440703 234176512 111.7G Microsoft basic data
For completeness sake -- what /var/log/messages should show when a USB drive is connected (at least something like that)
Jun 16 20:35:23 rpiautomation kernel: [13034.779023] usb 1-1.5: USB disconnect, device number 6
Jun 16 20:36:07 rpiautomation rsyslogd-2007: action 'action 17' suspended, next retry is Thu Jun 16 20:37:37 2016 [try http://www.rsyslog.com/e/2007 ]
Jun 16 20:36:48 rpiautomation kernel: [13119.758992] usb 1-1.3: new high-speed USB device number 7 using dwc_otg
Jun 16 20:36:48 rpiautomation kernel: [13119.859790] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
Jun 16 20:36:48 rpiautomation kernel: [13119.859819] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Jun 16 20:36:48 rpiautomation kernel: [13119.859836] usb 1-1.3: Product: USB 2.0 Hub
Jun 16 20:36:48 rpiautomation kernel: [13119.861080] hub 1-1.3:1.0: USB hub found
Jun 16 20:36:48 rpiautomation kernel: [13119.861310] hub 1-1.3:1.0: 4 ports detected
Jun 16 20:36:55 rpiautomation kernel: [13126.899022] usb 1-1.3.3: new high-speed USB device number 8 using dwc_otg
Jun 16 20:36:56 rpiautomation kernel: [13127.180310] usb 1-1.3.3: New USB device found, idVendor=048d, idProduct=1336
Jun 16 20:36:56 rpiautomation kernel: [13127.180340] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jun 16 20:36:56 rpiautomation kernel: [13127.180357] usb 1-1.3.3: Product: Mass Storage Device
Jun 16 20:36:56 rpiautomation kernel: [13127.180373] usb 1-1.3.3: Manufacturer: Generic
Jun 16 20:36:56 rpiautomation kernel: [13127.180388] usb 1-1.3.3: SerialNumber: 00000000000006
Jun 16 20:36:56 rpiautomation kernel: [13127.181687] usb-storage 1-1.3.3:1.0: USB Mass Storage device detected
Jun 16 20:36:56 rpiautomation kernel: [13127.186758] scsi host3: usb-storage 1-1.3.3:1.0
Jun 16 20:36:56 rpiautomation kernel: [13127.269026] usb 1-1.3.4: new high-speed USB device number 9 using dwc_otg
Jun 16 20:36:56 rpiautomation kernel: [13127.370425] usb 1-1.3.4: New USB device found, idVendor=152d, idProduct=2352
Jun 16 20:36:56 rpiautomation kernel: [13127.370453] usb 1-1.3.4: New USB device strings: Mfr=10, Product=11, SerialNumber=3
Jun 16 20:36:56 rpiautomation kernel: [13127.370469] usb 1-1.3.4: Product: USB Mass Storage
Jun 16 20:36:56 rpiautomation kernel: [13127.370485] usb 1-1.3.4: Manufacturer: WANLONGXIN
Jun 16 20:36:56 rpiautomation kernel: [13127.370500] usb 1-1.3.4: SerialNumber: 000000000086
Jun 16 20:36:56 rpiautomation kernel: [13127.372275] usb-storage 1-1.3.4:1.0: USB Mass Storage device detected
Jun 16 20:36:56 rpiautomation kernel: [13127.372815] scsi host4: usb-storage 1-1.3.4:1.0
Jun 16 20:36:57 rpiautomation kernel: [13128.180217] scsi 3:0:0:0: Direct-Access Generic Storage Device 0.00 PQ: 0 ANSI: 2
Jun 16 20:36:57 rpiautomation kernel: [13128.182251] sd 3:0:0:0: Attached scsi generic sg0 type 0
Jun 16 20:36:57 rpiautomation kernel: [13128.186706] sd 3:0:0:0: [sda] Attached SCSI removable disk
Jun 16 20:36:57 rpiautomation kernel: [13128.370099] scsi 4:0:0:0: Direct-Access KINGSTON SV300S37A120G PQ: 0 ANSI: 2 CCS
Jun 16 20:36:57 rpiautomation kernel: [13128.371978] sd 4:0:0:0: Attached scsi generic sg1 type 0
Jun 16 20:36:57 rpiautomation kernel: [13128.372741] sd 4:0:0:0: [sdb] 234441648 512-byte logical blocks: (120 GB/112 GiB)
Jun 16 20:36:57 rpiautomation kernel: [13128.373441] sd 4:0:0:0: [sdb] Write Protect is off
Jun 16 20:36:57 rpiautomation kernel: [13128.374125] sd 4:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Jun 16 20:36:57 rpiautomation kernel: [13128.391824] GPT:Primary header thinks Alt. header is not at the end of the disk.
Jun 16 20:36:57 rpiautomation kernel: [13128.391857] GPT:234441646 != 234441647
Jun 16 20:36:57 rpiautomation kernel: [13128.391868] GPT:Alternate GPT header not at the end of the disk.
Jun 16 20:36:57 rpiautomation kernel: [13128.391879] GPT:234441646 != 234441647
Jun 16 20:36:57 rpiautomation kernel: [13128.391888] GPT: Use GNU Parted to correct GPT errors.
Jun 16 20:36:57 rpiautomation kernel: [13128.392008] sdb: sdb1 sdb2
Jun 16 20:36:57 rpiautomation kernel: [13128.396226] sd 4:0:0:0: [sdb] Attached SCSI disk
Jun 16 20:37:01 rpiautomation org.gtk.Private.UDisks2VolumeMonitor[818]: index_parse.c:191: indx_parse(): error opening /media/pi/HDD/BDMV/index.bdmv
Jun 16 20:37:01 rpiautomation org.gtk.Private.UDisks2VolumeMonitor[818]: index_parse.c:191: indx_parse(): error opening /media/pi/HDD/BDMV/BACKUP/index.bdmv
Thank you again -- much appreciated.
