First time poster, and semi-newbie when it comes to linux.
So this is a long one, but i have been trying to tackle this one for a few days now.
I am currently working on a project that runs two different versions of vsftpd config files (one for IPv4, and the other for IPv6).
the first config file we called /etc/vsftpd-config-bkup/vsftpd.v4.conf
listen=YES
local_enable=YES
write_enable=YES
local_umask=022
dirmessage_enable=YES
use_localtime=YES
xferlog_enable=YES
connect_from_port_20=NO
chroot_local_user=YES
secure_chroot_dir=/var/run/vsftpd/empty
pam_service_name=vsftpd
pasv_enable=YES
pasv_addr_resolve=YES
pasv_address=ftp.tienet
pasv_min_port=50101
pasv_max_port=50120
listen_port=421
listen=NO
listen_ipv6=YES
local_enable=YES
write_enable=YES
local_umask=022
use_localtime=YES
xferlog_enable=YES
pasv_enable=YES
pasv_min_port=50081
pasv_max_port=50100
listen_port=621
The first called vsftpd_v4
#!/bin/sh
### BEGIN INIT INFO
# Provides: vsftpd_v4
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Very secure FTP server
# Description: Provides a lightweight, efficient FTP server written
# for security.
### END INIT INFO
set -e
ARGS ="/etc/vsftpd-conf-bkup/vsftpd.v4.conf"
DAEMON="/usr/sbin/vsftpd"
NAME="vsftpd_v4"
PATH="/sbin:/bin:/usr/sbin:/usr/bin"
LOGFILE="/var/log/vsftpd_v6.log"
CHROOT="/var/run/vsftpd/empty"
test -x "${DAEMON}" || exit 0
. /lib/lsb/init-functions
if [ ! -e "${LOGFILE}" ]
then
touch "${LOGFILE}"
chmod 640 "${LOGFILE}"
chown root:adm "${LOGFILE}"
fi
if [ ! -d "${CHROOT}" ]
then
mkdir -p "${CHROOT}"
fi
case "${1}" in
start)
log_daemon_msg "Starting FTP server" "${NAME}"
if [ -e /etc/vsftpd-conf-bkup/vsftpd.v4.conf ] && ! egrep -iq "^ *listen(_ipv6)? *= *yes" /etc/vsftpd-conf-bkup/vsftpd.v4.conf
then
log_warning_msg "vsftpd disabled - listen disabled in config."
exit 0
fi
start-stop-daemon --start --background -m --oknodo --pidfile /var/run/vsftpd_v4/vsftpd.pid --exec ${DAEMON} -- ${ARGS}
n=0
while [ ${n} -le 5 ]
do
_PID="$(if [ -e /var/run/vsftpd_v4/vsftpd.pid ]; then cat /var/run/vsftpd_v4/vsftpd.pid; fi)"
if ! ps -C vsftpd | grep -qs "${_PID}"
then
break
fi
sleep 1
n=$(( $n + 1 ))
done
then
log_warning_msg "vsftpd failed - probably invalid config."
exit 1
fi
log_end_msg 0
stop)
log_daemon_msg "Stopping FTP server" "${NAME}"
start-stop-daemon --stop --pidfile /var/run/vsftpd_v4/vsftpd.pid --oknodo --exec ${DAEMON} -- ${ARGS}
rm -f /var/run/vsftpd_v4/vsftpd.pid
log_end_msg 0
restart)
${0} stop
${0} start
reload|force-reload)
log_daemon_msg "Reloading FTP server configuration"
start-stop-daemon --stop --pidfile /var/run/vsftpd_v4/vsftpd.pid --signal 1 --exec $DAEMON -- ${ARGS}
log_end_msg "${?}"
status)
status_of_proc "${DAEMON}" "FTP server"
echo "Usage: ${0} {start|stop|restart|reload|status}"
exit 1
esac
exit 0
#!/bin/sh
### BEGIN INIT INFO
# Provides: vsftpd_v6
# for security.
### END INIT INFO
set -e
ARGS ="/etc/vsftpd-conf-bkup/vsftpd.v6.conf"
NAME="vsftpd_v6"
then
touch "${LOGFILE}"
fi
then
fi
case "${1}" in
start)
if [ -e /etc/vsftpd-conf-bkup/vsftpd.v6.conf ] && ! egrep -iq "^ *listen(_ipv6)? *= *yes" /etc/vsftpd-conf-bkup/vsftpd.v6.conf
then
exit 0
fi
start-stop-daemon --start --background -m --oknodo --pidfile /var/run/vsftpd_v6/vsftpd.pid --exec ${DAEMON} -- ${ARGS}
n=0
do
_PID="$(if [ -e /var/run/vsftpd_v6/vsftpd.pid ]; then cat /var/run/vsftpd_v6/vsftpd.pid; fi)"
then
break
fi
sleep 1
n=$(( $n + 1 ))
done
then
exit 1
fi
log_end_msg 0
stop)
start-stop-daemon --stop --pidfile /var/run/vsftpd_v6/vsftpd.pid --oknodo --exec ${DAEMON} -- ${ARGS}
rm -f /var/run/vsftpd_v6/vsftpd.pid
log_end_msg 0
restart)
${0} stop
${0} start
start-stop-daemon --stop --pidfile /var/run/vsftpd_v6/vsftpd.pid --signal 1 --exec $DAEMON -- ${ARGS}
log_end_msg "${?}"
status)
exit 1
esac
exit 0
vsftpd_v4.service
[Unit]
Description=vsftpd FTP server
After=network.target
[Service]
Type=simple
ExecStart=/usr/sbin/vsftpd /etc/vsftpd-conf-bkup/vsftpd.v4.conf
ExecReload=/bin/kill -HUP $MAINPID
ExecStartPre=-/bin/mkdir -p /var/run/vsftpd/empty
[Install]
WantedBy=multi-user.target
[Unit]
[Service]
Type=simple
ExecStart=/usr/sbin/vsftpd /etc/vsftpd-conf-bkup/vsftpd.v6.conf
[Install]
update-rc.d vsftpd_v4 defaults && update-rc.d vsftpd_v6 defaults && systemctl enable vsftpd_v4.service && systemctl enable vsftpd_6.service
sudo service vsftpd_v4 status
● vsftpd_v4.service - vsftpd FTP server
Loaded: loaded (/lib/systemd/system/vsftpd_v4.service; enabled)
Active: failed (Result: exit-code) since Sat 2016-06-11 12:53:28 EDT; 9min ago
Process: 581 ExecStart=/usr/sbin/vsftpd /etc/vsftpd-conf-bkup/vsftpd.v4.conf (code=exited, status=2)
Process: 541 ExecStartPre=/bin/mkdir -p /var/run/vsftpd/empty (code=exited, status=0/SUCCESS)
Main PID: 581 (code=exited, status=2)
Jun 11 12:53:22 raspberrypi systemd[1]: Started vsftpd FTP server.
Jun 11 12:53:28 raspberrypi systemd[1]: vsftpd_v4.service: main process exited, code=exited, status=2/INVALIDARGUMENT
Jun 11 12:53:28 raspberrypi systemd[1]: Unit vsftpd_v4.service entered failed state.
Does anyone have any idea what could be causing this invalid argument during boot?
