iulius_felix
[Solved] WiFi on Pi3 killed after upgrade to Stretch
Mon Jun 06, 2016 4:08 am
I've got the Respbian Lite on my Pi3 updated to Stretch last night (add the stretch source then do the apt full-upgrade), but found I've lost my WLAN interface afterwards.
After run the rpi-update, now my Pi3 is on 4.4.12-v7+ #892, but the WLAN interface still missing and there are some brcmfmac related kernel massage:
[    4.931879] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[    4.932451] usbcore: registered new interface driver brcmfmac
[    4.957749] brcmfmac_sdio mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.txt failed with error -2
I thought that could be firmware problem, but install the firmware files from https://github.com/RPi-Distro/firmware-nonfree/tree/master/brcm80211/brcm to /lib/firmware/brcm does not fixed the problem.
Then I found in README of DT overlay, it says:
Info: Selects the bcm2835-sdhost SD/MMC driver, optionally with overclock.
N.B. This overlay is designed for situations where the mmc driver is
the default, so it disables the other (mmc) interface - this will kill
WiFi on a Pi3. If this isn't what you want, either use the sdtweak
overlay or the new sd_* dtparams of the base DTBs.
Load: dtoverlay=sdhost,<param>=<val>
but seems neither putting dtoverlay=sdtweak in config.txt nor using dtoverlay sdtweak command works for the issue.
Any suggestion will be appreciated, thanks in advance!
Re: WiFi on Pi3 killed after upgrade to Stretch
Mon Jun 06, 2016 7:48 am
Build a fresh SDCard with a copy of NOOBS 1.9.2 or Raspbian 2016-05-27.
With a USB SDCard reader you can then pull your valuable data and programs from the old SDCard.
This is a doctor free zone.
iulius_felix
Mon Jun 06, 2016 9:21 am
Thanks for the reply, but I managed to solve the problem by coping two firmware from Ubuntu, they are:
Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
4a410ab9a1eefe82e158d36df02b3589 brcmfmac43430-sdio.bin
8c3cb6d8f0609b43f09d083b4006ec5a brcmfmac43430-sdio.txt
After that I found out that the firmware I downloaded from Github was corrupted.
wdmjun
Re: [Solved] WiFi on Pi3 killed after upgrade to Stretch
Thu Sep 08, 2016 10:06 pm
Same problem here. Upgraded raspbian jessie to raspbian stretch on pi3 and lost wifi (due to the upgrading of firmware-brcm80211 package). Just copied the contents of /lib/firmware/brcm from raspbian jessie (from another pi) and rebooted. Now wifi works on pi3 with raspbian stretch.
elkberry
Sun Jan 22, 2017 6:11 pm
This issue is still present: I needed to upgrade to Stretch and lost wlan0 on its way. This post saved my day: I copied the firmware blobs from one of my backup USB thumbdrives, rebooted, and wlan0 worked again.
From ZX81 to Raspberry Pi, but wait ... where's the 7805 gone?
schallee
Sat Mar 25, 2017 7:45 pm
Make sure the firmware-brcm80211 package is installed. Though still on jessie, somehow the firmware files disappeared and this package was not installed. Oddly they must have been there before because it worked for a long time until a update and reboot. Installing it fixed the issue.
elmicha
Fri Jan 12, 2018 9:40 pm
Thank you, schallee!
I did have the latest version of firmware-brcm80211 installed, but wlan0 still didn't show up.
sudo apt remove firmware-brcm80211
sudo apt install firmware-brcm80211
and it worked.
iamhssingh
Sat Jan 26, 2019 11:17 am
Can you post a link to those files? I am facing the same problem and have been searching for a solution but last 48 hours resulted in no success. I do have a WiFi USB that works like a charm, but really need the internal one to work.
Thanks.
elmicha
Sun Jan 27, 2019 5:23 pm
http://raspbian.raspberrypi.org/raspbia ... u1_all.deb
But if your Pi has an internet connection you don't need to download the file manually, just use apt.
