hostapd
Posted: Sat Jun 04, 2016 9:44 am
Hi Guys,
i have a problem with hostapd, i installed using this guide
http://en.tacticalcode.de/2013/03/use-y ... or-ap.html
I choose bridge mode
after i reboot the pi and i execute the command " hostapd -dd /etc/hostapd/hostapd.conf "
I get the following output, in particular
This is my config
Does someone can help me to fix the problem?
Thanks in advice
nl80211: Failed to set interface 3 to mode 3: -16 (Device or resource busy)
Configuration file: /etc/hostapd/hostapd.conf
Line 40: DEPRECATED: 'dump_file' configuration variable is not used anymore
ctrl_interface_group=0
rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:10
nl80211: Supported cipher 00-0f-ac:8
nl80211: Supported cipher 00-0f-ac:9
nl80211: Supported cipher 00-0f-ac:6
nl80211: Supported cipher 00-0f-ac:13
nl80211: Supported cipher 00-0f-ac:11
nl80211: Supported cipher 00-0f-ac:12
nl80211: Using driver-based off-channel TX
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 3 iftype 3 (AP)
nl80211: Try mode change after setting interface down
nl80211: Mode change succeeded while interface is down
nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0
nl80211: Subscribe to mgmt frames with AP handle 0x7ffc1810
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x7ffc1810 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x7ffc1810 match=
nl80211: Add own interface ifindex 3
nl80211: if_indices[16]: 3
Could not add bridge br0 : Invalid argument
nl80211: Failed to add the bridge interface br0 : Invalid argument
nl80211: Remove monitor interface: refcount=0
nl80211: Remove beacon (ifindex=3)
netlink: Operstate: ifindex=3 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 3 iftype 2 (STATION)
nl80211: Failed to set interface 3 to mode 2: -16 (Device or resource busy)
nl80211: Teardown AP(wlan0) - device_ap_sme=0 use_monitor=0
nl80211: Unsubscribe mgmt frames handle 0xf7749099 (AP teardown)
nl80211 driver initialization failed.
hostapd_interface_deinit_free(0x7ffbe9f0)
hostapd_interface_deinit_free: num_bss=1 conf->num_bss=1
hostapd_interface_deinit(0x7ffbe9f0)
hostapd_bss_deinit: deinit bss wlan0
hostapd_cleanup(hapd=0x7ffc0d60 (wlan0))
hostapd_free_hapd_data: Interface wlan0 wasn't started
hostapd_interface_deinit_free: driver=(nil) drv_priv=(nil) -> hapd_deinit
hostapd_interface_free(0x7ffbe9f0)
hostapd_interface_free: free hapd 0x7ffc0d60
hostapd_cleanup_iface(0x7ffbe9f0)
hostapd_cleanup_iface_partial(0x7ffbe9f0)
hostapd_cleanup_iface: free iface=0x7ffbe9f0
root@raspberrypi:/etc/network# nano /etc/hostapd/hostapd.conf
root@raspberrypi:/etc/network# sudo service hostapd restart
root@raspberrypi:/etc/network# hostapd -dd /etc/hostapd/hostapd.conf
random: Trying to read entropy from /dev/random
nl80211: Subscribe to mgmt frames with AP handle 0x8022e810
nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0x8022e810 match=
nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0x8022e810 match=
nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0x8022e810 match=
nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0x8022e810 match=
nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0x8022e810 match=
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x8022e810 match=
nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0x8022e810 match=
nl80211: Unsubscribe mgmt frames handle 0x8aa6099 (AP teardown)
hostapd_interface_deinit_free(0x8022b9f0)
hostapd_interface_deinit(0x8022b9f0)
hostapd_cleanup(hapd=0x8022dd60 (wlan0))
hostapd_interface_free(0x8022b9f0)
hostapd_interface_free: free hapd 0x8022dd60
hostapd_cleanup_iface(0x8022b9f0)
hostapd_cleanup_iface_partial(0x8022b9f0)
hostapd_cleanup_iface: free iface=0x8022b9f0
# Only for bridges, place a # before the next line for AP mode!
bridge=br0
# Interface and Driver
interface=wlan0
driver=nl80211
# WLAN-Settings
ssid=HomeNet
channel=6
# ESSID visible
ignore_broadcast_ssid=0
# Country-specific settings
country_code=IT
ieee80211d=1
# Transfer Mode
hw_mode=g
# Optional
# supported_rates=10 20 55 110 60 90 120 180 240 360 480 540
# uncomment the following to enable 802.11 Draft n
# ieee80211n=1
# Enable WMM for Draft-N
# wmm_enabled=1
# Use iw list to see which ht capabilities your wifi card has
# ht_capab=[HT40+][SHORT-GI-40][DSSS_CCK-40]
# Beacons
beacon_int=100
dtim_period=2
# Don't use MAC auth
macaddr_acl=0
# Max Clients
max_num_sta=20
# Limit size of Datapackets
rts_threshold=2347
fragm_threshold=2346
# hostapd Log settings
logger_syslog=-1
logger_syslog_level=2
logger_stdout=-1
logger_stdout_level=2
# temp files
ctrl_interface=/var/run/hostapd
# Authentification
auth_algs=3
# Encryption: WPA2 !!Don't use WEP!
wpa=2
rsn_preauth=1
rsn_preauth_interfaces=wlan0
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
# Key scheduling
wpa_group_rekey=600
wpa_ptk_rekey=600
wpa_gmk_rekey=86400
# Change this, it's the network's key
wpa_passphrase=MYPass
root@raspberrypi:/etc/network# iw list
Wiphy phy0
max # scan SSIDs: 4
max scan IEs length: 2285 bytes
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP (00-0f-ac:4)
* 00-0f-ac:10
* GCMP (00-0f-ac:8)
* 00-0f-ac:9
* CMAC (00-0f-ac:6)
* 00-0f-ac:13
* 00-0f-ac:11
* 00-0f-ac:12
Available Antennas: TX 0 RX 0
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
Band 1:
Bitrates (non-HT):
* 1.0 Mbps
* 2.0 Mbps (short preamble supported)
* 5.5 Mbps (short preamble supported)
* 11.0 Mbps (short preamble supported)
* 6.0 Mbps
* 9.0 Mbps
* 12.0 Mbps
* 18.0 Mbps
* 24.0 Mbps
* 36.0 Mbps
* 48.0 Mbps
* 54.0 Mbps
Frequencies:
* 2412 MHz [1] (20.0 dBm)
* 2417 MHz [2] (20.0 dBm)
* 2422 MHz [3] (20.0 dBm)
* 2427 MHz [4] (20.0 dBm)
* 2432 MHz [5] (20.0 dBm)
* 2437 MHz [6] (20.0 dBm)
* 2442 MHz [7] (20.0 dBm)
* 2447 MHz [8] (20.0 dBm)
* 2452 MHz [9] (20.0 dBm)
* 2457 MHz [10] (20.0 dBm)
* 2462 MHz [11] (20.0 dBm)
* 2467 MHz [12] (20.0 dBm)
* 2472 MHz [13] (20.0 dBm)
* 2484 MHz [14] (disabled)
Supported commands:
* new_interface
* set_interface
* new_key
* start_ap
* new_station
* new_mpath
* set_mesh_config
* set_bss
* authenticate
* associate
* deauthenticate
* disassociate
* join_ibss
* join_mesh
* set_tx_bitrate_mask
* frame
* frame_wait_cancel
* set_wiphy_netns
* set_channel
* set_wds_peer
* probe_client
* set_noack_map
* register_beacons
* start_p2p_device
* set_mcast_rate
* Unknown command (104)
* connect
* disconnect
Supported TX frame types:
* IBSS: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* managed: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* AP/VLAN: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* mesh point: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-client: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-GO: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
* P2P-device: 0x00 0x10 0x20 0x30 0x40 0x50 0x60 0x70 0x80 0x90 0xa0 0xb0 0xc0 0xd0 0xe0 0xf0
Supported RX frame types:
* IBSS: 0x40 0xb0 0xc0 0xd0
* managed: 0x40 0xd0
* AP: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* AP/VLAN: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* mesh point: 0xb0 0xc0 0xd0
* P2P-client: 0x40 0xd0
* P2P-GO: 0x00 0x20 0x40 0xa0 0xb0 0xc0 0xd0
* P2P-device: 0x40 0xd0
software interface modes (can always be added):
* AP/VLAN
* monitor
interface combinations are not supported
HT Capability overrides:
* MCS: ff ff ff ff ff ff ff ff ff ff
* maximum A-MSDU length
* supported channel width
* short GI for 40 MHz
* max A-MPDU length exponent
* min MPDU start spacing
Device supports TX status socket option.
Device supports HT-IBSS.
Device supports SAE with AUTHENTICATE command
Device supports low priority scan.
Device supports scan flush.
Device supports AP scan.
Device supports per-vif TX power setting
Driver supports a userspace MPM
root@raspberrypi:~# ifconfig
br0 Link encap:Ethernet HWaddr b8:27:eb:9b:7a:37
inet addr:192.168.1.64 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::ba27:ebff:fe9b:7a37/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:10438 errors:0 dropped:0 overruns:0 frame:0
TX packets:7544 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1733751 (1.6 MiB) TX bytes:2375448 (2.2 MiB)
eth0 Link encap:Ethernet HWaddr b8:27:eb:9b:7a:37
inet addr:169.254.130.126 Bcast:169.254.255.255 Mask:255.255.0.0
RX packets:10441 errors:0 dropped:0 overruns:0 frame:0
TX packets:7799 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1733889 (1.6 MiB) TX bytes:2522199 (2.4 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:412 errors:0 dropped:0 overruns:0 frame:0
TX packets:412 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:139880 (136.6 KiB) TX bytes:139880 (136.6 KiB)
wlan0 Link encap:Ethernet HWaddr 00:1d:0f:b3:7b:d7
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface lo inet loopback
iface eth0 inet manual
#WLAN Interface
allow-hotplug wlan0
iface wlan0 inet manual
# Bridge
auto br0
iface br0 inet manual
bridge_ports eth0 wlan0
bridge_fd 0
bridge_stp no
Thanks in advice
