Welcome, JLPotocki. That's all good experience you report. Just one thing:
JLPotocki wrote:4.If you need a 24/7 off-grid rig (like camping or tailgating) consider a 20000mah power bank with a Small Solar Power Cell combo.
Make that a "100Ah power bank with a Large Solar Cell combo"
It depends how much sunlight you get, and exactly what you are powering (hardware) and what software you are running. But for your rig, you use about 3Ah battery capacity each hour.
So for the battery to last 24h it needs at least 72Ah, and some reserve for dull days.
At 3.7V (normal power bank battery) 3Ah used in one hour is about 11W consumption. So over 24h your solar panel must provide 264Wh, or 22Ah at 12V. On average you get 12h daylight, much less at high latitudes in winter, and in many places sunlight is not reliable. Even if you can guarantee the sun for 6h in winter, the solar panels will only produce full power when the sun is high, so maybe the equivalent of 4h at full output. So your panel need a peak output of 6A (72W) -- and I haven't been particularly conservative in these calculations. A detailed calculation mneeds a lot more info on the actual requirement for power, the run time without good sunlight, and the local sunlight averages.
tl;dr -- for 24/7 off grid, you need a bigger battery and solar panel than you would ever guess.
