Max_G
tightVnc, client does not show menu
Sat May 28, 2016 8:41 am
I have installed a new Pi, with the latest Jessie image.
Created user maxg, with
sudo usermod -a -G users maxg
sudo usermod -a -G sudo maxg
sudo visudo -f /etc/sudoers
sudo service sudo restart
then got tightVNC with
sudo apt-get install tightvncserver
then launched it with:
vncserver :1 -geometry 1920x1080 -depth 24
installed the client on windows 10, can connect to the Pi, BUT:
The menu, which can be seen on top of the Pi's gui screen is missing in the VNC client.
I see a desktop, trash and folder icon, with a raspberry in the middle, but the menu is missing.
How do I get this menu included in the vnc session.
I have read about the various ways on how to install tightvnc, but pulling the app, starting the server, then starting the client seems to be the right steps... what am I missing?
Thank you for your help!
vethno
Re: tightVnc, client does not show menu
Sun May 29, 2016 1:41 am
I am having the same problem. VERY frustrating - nothing I have tried has worked.
SteveDee
Sun May 29, 2016 5:54 am
The Raspberry should be centre screen, which indicates that the view of the desktop is clipped. Try reducing the geometry (say 1024 x 768 as a starting point).
MarkHaysHarris777
Sun May 29, 2016 6:06 am
SteveDee wrote:The Raspberry should be centre screen, which indicates that the view of the desktop is clipped. Try reducing the geometry (say 1024 x 768 as a starting point).
That is definitely the problem... reduce the geometry and voila!
(another thing you might try is a notebook running Mint gnu+linux ! )
marcus
:ugeek:
Max_G
Sun May 29, 2016 8:29 am
Sorry guys... I cut the rest of the image to make it smaller, as I saw no relevance in the whole picture.
Even starting with tightvncserver :1 did not change the result.
However, I have been spending most of the day with looking for a solution...
... and found one.
this link: http://vandorp.biz/2012/01/installing-a ... 0qbL75PL3g had a solution that worked.
I saved a copy of my ~/.vnc/xstartup
apt-get install xorg lxde-core tightvncserver
# Started VNC to create config file (xstartup)
tightvncserver :1
# Then stopped VNC
tightvncserver -kill :1
# Edited config file to start session with LXDE:
nano ~/.vnc/xstartup
# and added this at the bottom of the file:
lxterminal &
/usr/bin/lxsession -s LXDE &
# start VNC
tightvncserver :1
and this worked... I now have a menu bar!
the complete ~/.vnc/xstartup as follows:
#!/bin/sh
xrdb $HOME/.Xresources
xsetroot -solid grey -cursor_name left_ptr
#x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" &
#x-window-manager &
# Fix to make GNOME work
export XKL_XMODMAP_DISABLE=1
/etc/X11/Xsession
lxterminal &
Good luck with it. :)
scruss
Tue Sep 20, 2016 12:12 pm
running x11vnc is much less work, should anyone wish to mirror their Raspberry Pi desktop somewhere else. All I did to install it was sudo apt install x11vnc, then run this on a console:
x11vnc -forever -bg -usepw -httpdir /usr/share/vnc-java/ -httpport 5901 -display :0
Maybe not exactly your use case, but I quickly came round to it.
