scar75
RPi2-RPi3 compatibility
Fri May 27, 2016 3:15 pm
Hi all,
I developed an application on RPi2, configured the board so to work interface hardware, wifi connectivity, ... all works well on RPI2
I am trying to place the same SD card that on the RPi3 but this does not boot.
Wasn't RPi3 supposed to be compatible to RPi2?
kusti8
Re: RPi2-RPi3 compatibility
Fri May 27, 2016 3:36 pm
It is, you need to update all of the firmware.
sudo apt-get update
sudo apt-get dist-upgrade
dom
Fri May 27, 2016 4:45 pm
kusti8 wrote:It is, you need to update all of the firmware.
sudo apt-get update
This will work from raspbian jessie. If you are on wheezy or another distribution then this won't work.
kusti8
Fri May 27, 2016 5:21 pm
sudo apt-get update
True, on wheezy you need to update to jessie. viewtopic.php?t=121880
Fri May 27, 2016 8:43 pm
scar75 wrote:Hi all,
You have not included Operating System !!
Retired disgracefully.....
