komeda
Crackling when using USB2 audio interfaces
Fri May 27, 2016 11:59 am
Hi there,
I am experiencing massive problems with USB DACs for a week now and I can't seem to wrap my mind around the problem.
I am developing an embedded audio-streamer built around a busybox, which I set up myself. The embedded system is derived from a Linux From Scratch system. I compile everything on the LFS and copy over only what I need. This is working very fine for over a year now. The system is working flawlessly with any HAT audio card as well as with my M-Audio Fast Track Pro (USB 1). USB 2 interfaces give me trouble, though. I get crackling noise. System load and IO are no issue: I can run jackd, netjack, brutefir and an audio-player when using a HAT or the USB 1 interface. The latter can even use brutefir with 4 channels. For tests I only use arecord | aplay or jackd and have the rest turned off.
I tried different kernel versions and they all have the same behaviour. At the moment I arrived at 4.4.11. The kernels are self-compiled, using bcm2709_defconfig and only changing the preemption model to CONFIG_PREEMPT. Firmware is the latest .
What is weird is that on my LFS system the USB interfaces work fine while on my embedded system, I get crackling noise.
This is really strange, since (to my understanding) the only elements involved are the same on both systems: The kernel drivers - snd_usb_audio - and the alsa-subsystem, which loads automatically upon usage. Besides from that there is no system-load or heavy IO on neither of the systems. cmdline.txt is the same on both as well. Putting dwc_otg.fiq_fsm_enable=0 leads to horrible distortion on both systems, and dwc_otg.fiq_fsm_enable=1 fixes that entirely on the LFS system and helps quite a bit on the busybox system, but doesn't really cure it.
So after a full week I decided to go and seek professional help ;)
Any ideas welcome!
jdb
Re: Crackling when using USB2 audio interfaces
Mon May 30, 2016 3:18 pm
What is the output of lsusb -v with the USB2.0 DAC connected?
Rockets are loud.
https://astro-pi.org
komeda
Mon May 30, 2016 4:02 pm
Ok, here is a crackling Native Instruments Audio 8 DJ USB 2 interface on the busybox:
can't get debug descriptor: Invalid argument
Bus 001 Device 002: ID 0424:9514
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         2
  bMaxPacketSize0        64
  idVendor           0x0424
  idProduct          0x9514
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
      bInterfaceSubClass      0
      bInterfaceProtocol      1
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         9
      bInterfaceProtocol      2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
  wHubCharacteristic 0x000d
    Per-port power switching
    Compound device
    Per-port overcurrent protection
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  bHubContrCurrent      1 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0503 highspeed power enable connect
   Port 5: 0000.0100 power
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0001
  Self Powered
Bus 001 Device 001: ID 1d6b:0002
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x1d6b
  idProduct          0x0002
  bcdDevice            4.04
  iManufacturer           3 Linux 4.4.11-v7 dwc_otg_hcd
  iProduct                2 DWC OTG Controller
  iSerial                 1 3f980000.usb
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
      bInterfacecan't get device qualifier: Invalid argument
SubClass      0
      bInterfaceProtocol      0
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
  wHubCharacteristic 0x0008
    Ganged power switching
  bPwrOn2PwrGood        1 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x00
 Hub Port Status:
  Self Powered
Bus 001 Device 003: ID 0424:ec00
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255
      bInterfaceProtocol    255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0010  1x 16 bytes
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 17cc:1978
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass       255
  bDeviceProtocol       255
  bMaxPacketSize0        64
  idVendor           0x17cc
  idProduct          0x1978
  bcdDevice            0.0e
  iManufacturer           1 Native Instruments
  iProduct                2 Audio 8 DJ
  iSerial                 5 SN-72PGF554F2
    bLength                 9
    bDescriptorType         2
    wTotalLength           69
    bNumInterfaces          1
    bConfcan't get debug descriptor: Invalid argument
cannot read device status, Invalid argument (22)
igurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              476mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255
      bInterfaceSubClass    255
      iInterface              3 Highspeed
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           4
      bInterfaceClass       255
      iInterface              4 Fullspeed
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x82  EP 2 IN
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x06  EP 6 OUT
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass       255
  bDeviceProtocol       255
  bMaxPacketSize0        64
And here it is on the Linux from scratch system, where it works fine:
can't get debug descriptor: Success
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         2 TT per port
  bMaxPacketSize0        64
  idVendor           0x0424 Standard Microsystems Corp.
  idProduct          0x9514 SMC9514 Hub
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceProtocol      1 Single TT
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceProtocol      2 TT per port
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
 Hub Port Status:
   Port 2: 0000.0503 highspeed power enable connect
   Port 4: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            4.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptorcan't get device qualifier: Invalid argument
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255 Vendor Specific Class
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idProduct          0xec00 SMSC9512/9514 Fast Ethernet Adapter
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255 Vendor Specific Class
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 009: ID 17cc:1978 Native Instruments Audio 8 DJ
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClcan't get debug descriptor: Invalid argument
ass       255 Vendor Specific Subclass
  bDeviceProtocol       255 Vendor Specific Protocol
  bMaxPacketSize0        64
  idVendor           0x17cc Native Instruments
  idProduct          0x1978 Audio 8 DJ
  bcdDevice            0.0e
    bLength                 9
    bDescriptorType         2
    wTotalLength           69
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              476mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass    255 Vendor Specific Subclass
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           4
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        bInterval               1
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass       255 Vendor Specific Subclass
  bMaxPacketSize0        64
jdb
Mon May 30, 2016 4:36 pm
What's the output of cat /proc/asound/card1/stream0 when playing (garbled) audio?
Note: this assumes you have the onboard audio driver enabled - if not, then it'll be card0 instead of card1.
Rockets are loud.
komeda
Mon May 30, 2016 5:08 pm
There is no such file as stream0 on either of my systems.
In /proc/asound/card0 i have
id midi0 pcm0c/ pcm0p/
I guess you are after information in /proc/asound/card0/pcm0p/sub0 , there are
hw_params info status sw_params
...and here are all of them for a garbled playback:
~ # cat /proc/asound/card0/pcm0p/sub0/hw_params
access: MMAP_INTERLEAVED
format: S24_3BE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 1024
buffer_size: 8192
~ # cat /proc/asound/card0/pcm0p/sub0/info
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
id: Audio 8 DJ
name: Audio 8 DJ
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 4
subdevices_avail: 3
~ # cat /proc/asound/card0/pcm0p/sub0/status
state: RUNNING
owner_pid : 2293
trigger_time: 17.852852024
tstamp : 0.000000000
delay : 7292
avail : 900
avail_max : 7208
hw_ptr : 13013820
appl_ptr : 13021112
~ # cat /proc/asound/card0/pcm0p/sub0/sw_params
tstamp_mode: NONE
period_step: 1
avail_min: 1024
start_threshold: 1
stop_threshold: 8192
silence_threshold: 0
silence_size: 0
boundary: 1073741824
Since the LFS system is just compiling something right now, I'll post the output of the files on that system later. You want all of the above again?
jdb
Mon May 30, 2016 5:29 pm
Hm. That implies that snd-usb-audio isn't in charge of the device.
What does lsusb -t report?
Rockets are loud.
komeda
Mon May 30, 2016 6:13 pm
Right, for the Native Instruments interface it is snd_usb_caiaq while for the Focusrite it is snd_usb_audio. They both show the exact same behaviour, working fine on one system and on the other one garbled.
I will hook up the Focusrite later on and get back to you with new input..
komeda
Mon May 30, 2016 6:39 pm
Ok, here we go, Focusrite Scarlet 2i4 via D-Link DUB-H7 USB powered Hub. The Scarlett won't work without it.
lsusb -v
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         2
  bMaxPacketSize0        64
  idVendor           0x0424
  idProduct          0x9514
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x1d6b
  idProduct          0x0002
  bcdDevice            4.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
SubClass      0
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 001 Device 009: ID 0835:8502
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0835
  idProduct          0x8502
  bcdDevice            6.09
  iManufacturer           1 Action Star
  iProduct                2 USB HID
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               20mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3
      bInterfaceSubClass      1
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength      35
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval               8
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0002
  (Bus Powered)
  Remote Wakeup Enabled
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x0424
  idProduct          0xec00
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      bInterfaceClass       255
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass          255
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 005: ID 0835:8500
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         2
  bMaxPacketSize0        64
  idVendor           0x0835
  idProduct          0x8500
  bcdDevice            1.09
  iProduct                2 USB2.0 Hub
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
  wHubCharacteristic 0x00e4
    Compound device
    Ganged overcurrent protection
    TT think time 32 FS bits
    Port indicators
  bHubContrCurrent    100 milli Ampere
 Hub Port Status:
   Port 1: 000can't get debug descriptor: Invalid argument
   Port 3: 0000.0503 highspeed power enable connect
   Port 5: 0000.0503 highspeed power enable connect
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0003
  Self Powered
Bus 001 Device 006: ID 0835:8501
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0835
  idProduct          0x8501
  bcdDevice            6.09
  iProduct                2 USB HID
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               20mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Bus 001 Device 007: ID 1235:800a
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239
  bDeviceSubClass         2
  bDeviceProtocol         1
  bMaxPacketSize0        64
  idVendor           0x1235
  idProduct          0x800a
  bcdDevice            1.25
  iManufacturer           1 Focusrite
  iProduct                2 Scarlett 2i4 USB
  iSerial                 0
  bNumConfigurations      2
    bLength                 9
    bDescriptorType         2
    wTotalLength          387
    bNumInterfaces          6
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         1
      bInterfaceProtocol     32
      iInterface              2 Scarlett 2i4 USB
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               8
        wTotalLength          127
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID               41
        bmAttributes         0x03 Internal programmable Clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            9 Internal
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     11 (CLOCK_SELECTOR)
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
          Clock Selector Control (read/write)
        iClockSelector          8 Scarlett 2i4 USB-Sync
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             2
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             4
        bmChannelConfig   0x00000000
        bmControls    0x0000
        iChannelNames          15 Output 1
        iTerminal               6 Scarlett 2i4 USB-Output
        bLength                26
        bDescriptorType        36
        bDescriptorSubtype      6 (FEATURE_UNIT)
        bUnitID                10
        bSourceID               2
        bmaControls( 0)      0x00000000
        bmaControls( 1)      0x00000000
        bmaControls( 2)      0x00000000
        bmaControls( 3)      0x00000000
        bmaControls( 4)      0x00000000
        iFeature                0
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID            20
        wTerminalType      0x0301 Speaker
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        wTerminalType      0x0201 Microphone
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls    0x0000
        iChannelNames          33 Input 1
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                11
        bSourceID               1
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID              11
        bCSourceID             40
        bmControls         0x0000
        iTerminal               7 Scarlett 2i4 USB-Input
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0006  1x 6 bytes
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      iInterface              4 Scarlett 2i4 USB-Out
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      bInterfaceClass         1
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
        bmFormats         0x00000001
          PCM
        bNrChannels             4
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x0400  1x 1024 bytes
        bInterval               1
        AudioControl Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         2 Decoded PCM samples
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      iInterface              5 Scarlett 2i4 USB-In
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         1
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength            9
        bInCollection           1
        baInterfaceNr( 0)       1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         1
      bInterfaceSubClass      3
      iInterface              0
      MIDIStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength           65
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (MIDI_IN_JACK)
        bJackType               1 Embedded
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType        36
        bJackType               2 External
        bJackID                 2
        iJack                  14 FocusriteMIDI In
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (MIDI_OUT_JACK)
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        iJack                  13 FocusriteMIDI Out
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
        MIDIStreaming Endpoint Descriptor:
          bLength                 5
          bDescriptorType        37
          bDescriptorSubtype      1 (GENERAL)
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254
      iInterface             12 Scarlett 2i4 USB-DFU
      Device Firmware Upgrade Interface Descriptor:
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Manifestation Tolerant
          Upload Supported
          Download Supported
        wDetachTimeout                    250 milliseconds
        wTransferSize                      64 bytes
        bcdDFUVersion                   1.10
    bLength                 9
    bDescriptorType         2
    wTotalLength          387
    bNumInterfaces          6
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         1
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength          127
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        bLength                 8
        bDescriptorType        36
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             4
        bmControls    0x0000
        bLength                26
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls    0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                11
        bSourceID               1
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID              11
        bCSourceID             40
        bmControls         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
      bInterfaceClass         1
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             4
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         1
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass         1
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength            9
        bInCollection           1
        baInterfaceNr( 0)       1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         1
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength           65
        bLength                 6
        bDescriptorType        36
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType can't get debug descriptor: Invalid argument
       36
        bJackID                 2
        bLength                 9
        bDescriptorType        36
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
Bus 001 Device 008: ID 0835:8500
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         2
  bMaxPacketSize0        64
  idVendor           0x0835
  idProduct          0x8500
  bcdDevice            1.09
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          can't get debug descriptor: Invalid argument
0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      bInterfaceClass         9
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
    Port indicators
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  Self Powered
lsusb -t
~ # lsusb -t
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=, Driver=hub/5p, 480M
        |__ Port 1: Dev 3, If 0, Class=, Driver=smsc95xx, 480M
        |__ Port 4: Dev 5, If 0, Class=, Driver=hub/5p, 480M
            |__ Port 1: Dev 6, If 0, Class=, Driver=usbhid, 480M
            |__ Port 3: Dev 7, If 0, Class=, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 7, If 1, Class=, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 7, If 2, Class=, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 7, If 3, Class=, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 7, If 4, Class=, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 7, If 5, Class=, Driver=, 480M
            |__ Port 5: Dev 8, If 0, Class=, Driver=hub/5p, 480M
                |__ Port 1: Dev 9, If 0, Class=, Driver=usbhid, 480M
cat /proc/asound/card0/stream0
~ # cat /proc/asound/card0/stream0
Focusrite Scarlett 2i4 USB at usb-3f980000.usb-1.4.3, high speed : USB Audio
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 112
    Momentary freq = 44105 Hz (0x5.8360)
    Feedback Format = 16.16
  Interface 1
    Altset 1
    Format: S32_LE
    Channels: 4
    Endpoint: 1 OUT (ASYNC)
    Rates: 44100, 48000, 88200, 96000
    Data packet interval: 125 us
Capture:
  Status: Stop
  Interface 2
    Altset 1
    Format: S32_LE
    Channels: 2
    Endpoint: 2 IN (ASYNC)
komeda
And the same for the system where it is working fine:
lsusb -v
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  Self Powered
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  bcdDevice            4.04
    bLength                 9
    bDescriptorType         2
    wTotalLength           25
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
can't get debug descriptor: Device or resource busy
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             1
 Hub Port Status:
  Self Powered
Bus 001 Device 014: ID 0835:8502 Action Star Enterprise Co., Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0835 Action Star Enterprise Co., Ltd
  idProduct          0x8502
  bcdDevice            6.09
  iProduct                2 USB HID
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               20mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  bcdDevice            2.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDesccan't get debug descriptor: Device or resource busy
riptorType         2
    wTotalLength           39
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           3
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               4
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         1
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 010: ID 0835:8500 Action Star Enterprise Co., Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  idProduct          0x8500
  bcdDevice            1.09
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttribcan't get debug descriptor: Device or resource busy
utes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
    Port indicators
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 011: ID 0835:8501 Action Star Enterprise Co., Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idProduct          0x8501
  bcdDevice            6.09
  iProduct                2 USB HID
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           34
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower               20mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bNumDescriptors         1
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Bus 001 Device 012: ID 1235:800a Focusrite-Novation Scarlett 2i4
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x1235 Focusrite-Novation
  idProduct          0x800a Scarlett 2i4
  bcdDevice            1.25
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength          387
    bNumInterfaces          6
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength          127
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        bLength                 8
        bDescriptorType        36
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             4
        bmControls    0x0000
        bLength                26
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls    0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                11
        bSourceID               1
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID              11
        bCSourceID             40
        bmControls         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             4
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength            9
        bInCollection           1
        baInterfaceNr( 0)       1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass      3 MIDI Streaming
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength           65
        bLength                 6
        bDescriptorType        36
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType        36
        bJackID                 2
        bLength                 9
        bDescriptorType        36
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass       254 Application Specific Interface
      bInterfaceSubClass      1 Device Firmware Update
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
    bLength                 9
    bDescriptorType         2
    wTotalLength          387
    bNumInterfaces          6
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         3
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength          127
        bmControl            0x00
        bLength                 8
        bDescriptorType        36
        bClockID               41
        bmControls           0x07
        bAssocTerminal          0
        bLength                 8
        bDescriptorType        36
        bUnitID                40
        bNrInPins               1
        baCSourceID( 0)        41
        bmControls           0x03
        bLength                17
        bDescriptorType        36
        bTerminalID             2
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             4
        bmControls    0x0000
        bLength                26
        bDescriptorType        36
        bUnitID                10
        bSourceID               2
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            20
        bAssocTerminal          0
        bSourceID              10
        bCSourceID             40
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             1
        bAssocTerminal          0
        bCSourceID             40
        bNrChannels             2
        bmControls    0x0000
        iTerminal               0
        bLength                18
        bDescriptorType        36
        bUnitID                11
        bSourceID               1
        iFeature                0
        bLength                12
        bDescriptorType        36
        bTerminalID            22
        bAssocTerminal          0
        bSourceID              11
        bCSourceID             40
        bmControls         0x0000
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           2
        bLength                16
        bDescriptorType        36
        bTerminalLink           2
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             4
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
        bLength                 7
        bDescriptorType         5
        bmAttributes           17
          Synch Type               None
          Usage Type               Feedback
        bInterval               4
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
        bLength                16
        bDescriptorType        36
        bTerminalLink          22
        bmControls           0x00
        bFormatType             1
          PCM
        bNrChannels             2
        bLength                 6
        bDescriptorType        36
        bSubslotSize            4
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength            9
        bInCollection           1
        baInterfaceNr( 0)       1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength           65
        bLength                 6
        bDescriptorType        36
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType        36
        bJackID                 2
        bLength                 9
        bDescriptorType        36
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 9
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bRefresh                0
        bSynchAddress           0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           0
        bLength                             9
        bDescriptorType                    33
        bmAttributes                        7
          Will Not Detach
          Manican't get debug descriptor: Device or resource busy
festation Tolerant
          Upload Supported
          Download Supported
        bcdDFUVersion                   1.10
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  (Bus Powered)
Bus 001 Device 013: ID 0835:8500 Action Star Enterprise Co., Ltd
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  idProduct          0x8500
  bcdDevice            1.09
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             5
    Compound device
    Port indicators
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0
  bMaxPacketSize0        64
  Self Powered
lsusb -t
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/5p, 480M
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
        |__ Port 4: Dev 10, If 0, Class=Hub, Driver=hub/5p, 480M
            |__ Port 1: Dev 11, If 0, Class=Human Interface Device, Driver=usbhid, 480M
            |__ Port 3: Dev 12, If 0, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 12, If 1, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 12, If 2, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 12, If 3, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 12, If 4, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 12, If 5, Class=Application Specific Interface, Driver=, 480M
            |__ Port 5: Dev 13, If 0, Class=Hub, Driver=hub/5p, 480M
                |__ Port 1: Dev 14, If 0, Class=Human Interface Device, Driver=usbhid, 480M
root:~# cat /proc/asound/card0/stream0
Playback:
  Status: Running
    Interface = 1
    Altset = 1
    Packet Size = 112
  Interface 1
    Altset 1
    Format: S32_LE
    Channels: 4
Capture:
  Status: Stop
  Interface 2
    Altset 1
    Format: S32_LE
    Channels: 2
---EDIT---
Haha, lspci! Just checked for answers and saw my typo. lspci kinda burned-in over the years ;)
I'll edit that now...
komeda
Tue May 31, 2016 2:26 pm
jdb, are still with me? I was so happy, you stepped in...
jdb
Mon Jun 06, 2016 12:08 pm
One thing of note is that a fair few of the endpoints reported on the USB2.0 DAC have an interval of 1 microframe (125uS). Due to the way the hardware works, we can't guarantee 1-microframe precision when there is lots of other interrupt activity (ethernet, SD card).
The listings are inconclusive - I was expecting something that would tell me which endpoints are active on the other device.
The only other thing that would tell me this would be to load usbmon - which gives USB debugging information but is clunky to use.
Edit: I'm confused. Your last post says that you have a case where it's not working, but the listing is for a Pi. Is this correct?
Rockets are loud.
komeda
Mon Jun 06, 2016 12:57 pm
I have two systems, both Pis. One is a Linux from scratch, here it is working, one is a busybox system, derived from the LFS. Here it crackles. Both have identical kernels, cmdline.txt and config.txt. All libraries and binaries are of course the same.
jdb
Mon Jun 06, 2016 2:43 pm
Ok. Do you get the issue with either of these devices on the latest version of Raspbian?
Rockets are loud.
komeda
Mon Jun 06, 2016 3:00 pm
Nope, only system having trouble is the busybox and I spent over a week investigating why. Alsa is loading/configuring itself upon usage with plughw:0 (so there should be no difference between LFS and busybox) and apart from that the kernel and modules are the same. I don't see anything else involved that could cause a different behaviour. There is neither a lot of system or network load. Tearing my hairs out on this one...
jdb
Tue Jun 07, 2016 3:32 pm
If it works on the Raspbian image then I can't really spend time troubleshooting whatever software environment you have.
That said, can you give me the output of uname -a, dmesg | grep otg and cat /proc/cmdline for the LFS and busybox systems? There may be a simple command-line switch that can help.
Rockets are loud.
komeda
Wed Jun 08, 2016 8:32 am
Sure, I can do that later on when I come home.
komeda
Thu Jun 09, 2016 10:06 am
Here we go, crackling busybox system:
~ uname -a
Linux AroioEX 4.4.11-v7 #2 SMP PREEMPT Tue May 24 17:11:26 UTC 2016 armv7l GNU/Linux
~ # dmesg | grep otg
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa01041 bcm2709.serial=0x2e6b9053 smsc95xx.macaddr=B8:27:EB:6B:90:53 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.fiq_fsm_enable=1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rw rootfstype=ext3 elevator=deadline rootwait
[    2.250731] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.710519] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    2.756072] dwc_otg: Microframe scheduler enabled
[    2.780292] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.787255] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.796613] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    2.840000] usb usb1: Manufacturer: Linux 4.4.11-v7 dwc_otg_hcd
[    2.867769] dwc_otg: FIQ enabled
[    2.867785] dwc_otg: NAK holdoff enabled
[    2.867796] dwc_otg: FIQ split-transaction FSM enabled
[    3.289419] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.793400] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[  141.413500] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[  141.865528] usb 1-1.4.1: new high-speed USB device number 5 using dwc_otg
[  142.105525] usb 1-1.4.3: new high-speed USB device number 6 using dwc_otg
[  142.325480] usb 1-1.4.5: new high-speed USB device number 7 using dwc_otg
[  143.385487] usb 1-1.4.5.1: new high-speed USB device number 8 using dwc_otg
~ # cat /proc/cmdline
Clean sounding LFS system:
root:~# uname -a
Linux lfs 4.4.11-v7 #2 SMP PREEMPT Tue May 24 17:11:26 UTC 2016 armv7l GNU/Linux
root:~# dmesg |grep otg
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa01041 bcm2709.serial=0x2e6b9053 smsc95xx.macaddr=B8:27:EB:6B:90:53 bcm2708_fb.fbswap=1 bcm2709.uart_clock=3000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.fiq_fsm_enable console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    2.304601] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.764479] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[    2.809959] dwc_otg: Microframe scheduler enabled
[    2.834138] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.841073] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.850428] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[    2.893728] usb usb1: Manufacturer: Linux 4.4.11-v7 dwc_otg_hcd
[    2.921741] dwc_otg: FIQ enabled
[    2.921757] dwc_otg: NAK holdoff enabled
[    2.921769] dwc_otg: FIQ split-transaction FSM enabled
[    3.304245] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.812240] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    4.116197] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[    4.556291] usb 1-1.4.1: new high-speed USB device number 5 using dwc_otg
[    4.795180] usb 1-1.4.5: new high-speed USB device number 6 using dwc_otg
[    5.840222] usb 1-1.4.5.1: new high-speed USB device number 7 using dwc_otg
[   38.504199] usb 1-1.4: new high-speed USB device number 8 using dwc_otg
[   39.008178] usb 1-1.4.1: new high-speed USB device number 9 using dwc_otg
[   39.320207] usb 1-1.4.5: new full-speed USB device number 10 using dwc_otg
[   39.680200] usb 1-1.4.5: new high-speed USB device number 11 using dwc_otg
[   40.812204] usb 1-1.4.5.1: new high-speed USB device number 12 using dwc_otg
[   66.528207] usb 1-1.4.3: new high-speed USB device number 13 using dwc_otg
root:~# cat /proc/cmdline
epoch1970
Thu Jun 09, 2016 10:32 am
You wrote "command line is the same as well".
It isn't, factually. I took both lines "[ 0.000000] Kernel command line", replaced spaces with line breaks, did a sort and removed all duplicated lines. There is a list of unique items, meaning your boot config differs:
rootfstype=ext3
rootfstype=ext4
rw
How important that is, I have no clue.
komeda
Thu Jun 09, 2016 1:35 pm
Thx for pointing that out. I played around with different parameters and forgot to change things back. Just did that now, changed the cmdline.txt of the troubled busybox to the same values as the lfs system, exept for the ext3/4 part. No change, the busybox has crackles. ;(
trulio
Wed May 10, 2017 9:23 am
Hi everyone,
wish you will be able to solve this issue.
since the 4.9 kernel upgrade, i notice frequent audio glitches like in the old times before the USB packet management patch.
the issue was submitted 3 month ago on raspberry firmware repository but does not seem to be solved.
(https://github.com/raspberrypi/firmware/issues/753)
My hardware is a raspberry 2 and my DAC is an synchronous adaptive 9018 one sold by hifimediy and my distribution is raspbian lite.
Do you know if the FIQ_FSM USB is still applied?
Thanks for your support.
Regards,
Trulio
