Need help for an issue with NUT
Posted: Fri May 27, 2016 7:03 am
Hi all.
I have installed NUT on my Raspberry Pi to monitor my Eaton UPS.
If there’s a power failure the UPS shutdown the RPI.
That’s OK.
But when the power comes back, the RPI restart
and then, reboots.
The timer in NOTIFYCMD makes it reboot after 10 mn’s wait (if value is changed to 900, the RPI reboot after 15mn).
And I don’t get why.
This is the whole enchilada:
/etc/default/nut
/etc/nut/ups.conf
/etc/nut/nut.conf
/etc/nut/upsd.conf
/etc/nut/upsd.users
/etc/nut/upsmon.conf
And finally, NOTIFYCMD:
/etc/nut/notifycmd
That’s it.
I wish you can help me to find the reason of this issue..
That’s OK.
and then, reboots.
let "n = 600"And I don’t get why.
/etc/default/nut
# start upsd
START_UPSD=yes
# start upsmon
START_UPSMON=yes
[eaton]
driver = usbhid-ups
port = auto
desc = "Eaton3S"
standalone
# LISTEN <address> <port>
LISTEN 127.0.0.1 3493
LISTEN ::1 3493Code: Select all
[admin]
password = mypass
actions = SET
instcmds = ALL
[upsmon]
password = mypass
upsmon master
MONITOR eaton@localhost 1 admin mypass master
MINSUPPLIES 1
FINALDELAY 5
SHUTDOWNCMD "sudo /sbin/shutdown -h +0"
NOTIFYCMD "/etc/nut/notifycmd"
NOTIFYFLAG ONBATT EXEC+SYSLOG+WALL
NOTIFYFLAG ONLINE EXEC+SYSLOG+WALL
NOTIFYCMD /etc/nut/notifycmd
/etc/nut/notifycmd
#!/bin/bash
# NUT NOTIFYCMD script
PATH=/sbin:/usr/sbin:/bin:/usr/bin:/usr/local/sbin:/usr/local/bin
trap "exit 0" SIGTERM
if [ "$NOTIFYTYPE" = "ONLINE" ]
then
echo $0: power restored | wall
curl "command"
#sleep 5
# Cause all instances of this script to exit.
killall -s SIGTERM `basename $0`
fi
if [ "$NOTIFYTYPE" = "ONBATT" ]
then
echo $0: 10 minutes till system powers down... | wall
curl "command!"
# Loop with one second interval to allow SIGTERM reception.
let "n = 600"
while [ $n -ne 0 ]
do
sleep 1
let "n--"
done
echo $0: commencing shutdown | wall
upsmon -c fsd
fiI wish you can help me to find the reason of this issue..
