akehrli
[Solved] impossible to install something
Wed May 25, 2016 10:01 am
I am a real newbie, so sorry to my ignorance, but I am completely stuck to install something on Raspbian. Indeed, here is what i have done :
sudo apt-get update // that's works
sudo apt-get install tightvncserver
I have :
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  nodered xfonts-base
Suggested packages:
  tightvnc-java
  tightvncserver xfonts-base
The following packages will be upgraded:
  nodered
1 upgraded, 2 newly installed, 0 to remove and 7 not upgraded.
1 not fully installed or removed.
Need to get 0 B/12.0 MB of archives.
After this operation, 9,895 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Reading changelogs... Done
(Reading database ... 117963 files and directories currently installed.)
Preparing to unpack .../nodered_0.13.4-1_armhf.deb ...
Unpacking nodered (0.13.4-1) over (0.13.4) ...
it is stuck at this position during a while and I have :
dpkg: error processing archive /var/cache/apt/archives/nodered_0.13.4-1_armhf.deb (--unpack):
 unable to securely remove '/usr/lib/node_modules/node-red/node_modules/when/unfold/list.js.dpkg-new': Read-only file system
dpkg: error while cleaning up:
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/LICENSE.txt': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/es6-shim/Promise.browserify-es6.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/es6-shim/Promise.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/es6-shim/Promise.min.js.map': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/es6-shim/Promise.min.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/es6-shim/Promise.js.map': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/pipeline.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/guard.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.js.map': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.debug.js.map': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.debug.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.min.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/dist/browser/when.min.js.map': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/delay.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/generator.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/parallel.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/monitor.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/cancelable.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/poll.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/keys.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/sequence.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/function.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/when/package.json': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/window-size/LICENSE-MIT': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/window-size/index.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/window-size/package.json': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/brace-expansion/index.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/brace-expansion/package.json': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/xml2js/lib/bom.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/xml2js/lib/processors.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/xml2js/lib/xml2js.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/xml2js/LICENSE': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/xml2js/package.json': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/commander/LICENSE': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/commander/index.js': Read-only file system
 unable to restore backup version of `/usr/lib/node_modules/node-red/node_modules/commander/package.json': Read-only file system
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/lodash.keys/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/lodash.keys/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/lodash.keys/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/lib/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/node_modules/assert-plus/AUTHORS': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/node_modules/assert-plus/assert.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/node_modules/assert-plus/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/getpass/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bindings/bindings.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bindings/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/etag/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/etag/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/etag/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/once/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/once/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/once/once.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/lib/core.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/lib/curve255.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/lib/utils.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/lib/eddsa.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/lib/dh.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/almond.1': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/AUTHORS.md': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/jsdoc.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/almond.0': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/jodid25519/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/type-is/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/type-is/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/type-is/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/.deps/Release/bcrypt_lib.node.d': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/.deps/Release/obj.target/bcrypt_lib.node.d': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/.deps/Release/obj.target/bcrypt_lib/src/blowfish.o.d': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt.o.d': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/.deps/Release/obj.target/bcrypt_lib/src/bcrypt_node.o.d': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/obj.target/bcrypt_lib/src/bcrypt_node.o': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/obj.target/bcrypt_lib/src/blowfish.o': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/obj.target/bcrypt_lib/src/bcrypt.o': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/obj.target/bcrypt_lib.node': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Release/bcrypt_lib.node': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/bcrypt_lib.target.mk': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/binding.Makefile': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/Makefile': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/build/config.gypi': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/binding.gyp': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/bcrypt.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/werker.yml': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/Makefile': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/src/blowfish.cc': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/src/node_blf.h': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/src/bcrypt.cc': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/src/bcrypt_node.cc': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/bcrypt/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/mime-types/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/mime-types/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/mime-types/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/caseless/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/caseless/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/caseless/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/destroy/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/destroy/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/destroy/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/basic-auth/LICENSE': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/basic-auth/index.js': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/node_modules/basic-auth/package.json': Input/output error
 unable to remove newly-extracted version of `/usr/lib/node_modules/node-red/package.json': Read-only file system
 unable to remove newly-extracted version of `/usr/bin/node-red-stop': Read-only file system
 unable to remove newly-extracted version of `/usr/bin/node-red-start': Read-only file system
 unable to remove newly-extracted version of `/usr/bin/update-nodejs-and-nodered': Read-only file system
 unable to securely remove '/var/lib/dpkg/tmp.ci': Read-only file system
 unable to securely remove '/var/lib/dpkg/reassemble.deb': Read-only file system
dpkg: error processing archive /var/cache/apt/archives/tightvncserver_1.3.9-6.5_armhf.deb (--unpack):
 cannot access archive: No such file or directory
dpkg: error processing archive /var/cache/apt/archives/xfonts-base_1%3a1.0.3_all.deb (--unpack):
Processing triggers for gnome-menus (3.13.3-6) ...
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
dpkg: unrecoverable fatal error, aborting:
 unable to flush updated status of `gnome-menus': Read-only file system
E: Sub-process /usr/bin/dpkg returned an error code (2)
E: Problem executing scripts DPkg::Post-Invoke '/usr/bin/test -e /usr/share/dbus-1/system-services/org.freedesktop.PackageKit.service && /usr/bin/test -S /var/run/dbus/system_bus_socket && /usr/bin/gdbus call --system --dest org.freedesktop.PackageKit --object-path /org/freedesktop/PackageKit --timeout 4 --method org.freedesktop.PackageKit.StateHasChanged cache-update > /dev/null; /bin/echo > /dev/null'
E: Sub-process returned an error code
And I have to restart Pi, and do
sudo dpkg --configure -a
But this problem appears each time I have to install something so I really need your help!
many thanks
Antoine
andreasko
Re: impossible to install something
Wed May 25, 2016 6:27 pm
Hi Antoine,
Don't know if my approach is correct...
But here is what I did....
Force removed nodered (That is the package that makes all the fuzz)
sudo dpkg --force-all -P nodered
It will probably through some warnings that some directories are not empty, so dpkg will not delete them.
As I type now, I am doing an "apt-get upgrade" and so far I haven't had any problems.
I hope it finishes smoothly.
best regards,
Andreas
akehrli
Thu May 26, 2016 7:23 am
Hello Andreas,
Thanks for your reply, I thought something was wrong with this file but I didn't dare (and know) how to proceed to remove such file. So many thanks for your explanations.
I add I forgot to mention but I had done an apt-get upgrade, but as soon as Raspbian needs to open a packet, same problem occured, a bit like i was in a vicious cycle...
So it is solved now, thanks again
Cheers
Antoine
akehrli
Thu May 26, 2016 1:24 pm
Hi all,
Sorry to be back in this post, but I get everytime same problem to install something, I am not far to throw my RPi to bin !!
here is my actions :
[email protected]:~ $ sudo apt-get -f install
Correcting dependencies... Done
  libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0
  raspberrypi-bootloader
5 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
2 not fully installed or removed.
Need to get 0 B/35.9 MB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 111010 files and directories currently installed.)
Preparing to unpack .../libraspberrypi-dev_1.20160512-1_armhf.deb ...
Unpacking libraspberrypi-dev (1.20160512-1) over (1.20160506-1) ...
dpkg: error processing archive /var/cache/apt/archives/libraspberrypi-dev_1.20160512-1_armhf.deb (--unpack):
 unable to clean up mess surrounding `./opt/vc/include/VG/vgext.h' before installing another version: Read-only file system
 unable to remove newly-extracted version of `/opt/vc/include/bcm_host.h': Read-only file system
dpkg: error processing archive /var/cache/apt/archives/libraspberrypi-doc_1.20160512-1_armhf.deb (--unpack):
dpkg: error processing archive /var/cache/apt/archives/libraspberrypi-bin_1.20160512-1_armhf.deb (--unpack):
dpkg: error processing archive /var/cache/apt/archives/libraspberrypi0_1.20160512-1_armhf.deb (--unpack):
dpkg: error processing archive /var/cache/apt/archives/raspberrypi-bootloader_1.20160512-1_armhf.deb (--unpack):
dpkg: error: unable to create new file '/var/lib/dpkg/status-new': Read-only file system
each it appears it is unable to overwrite on present version of files, and it talks about read only file system...
Impossible to do anything, knowing I want just to install vnc, with tightvncserver package.
i re-install several times NOOBS, or RaspBian on my SD which is OK with the list, so, I am a bit lost...
Thanks for your help,
Antoine
SkyRise
Thu May 26, 2016 1:35 pm
Have you got enough space left on your SD card? Has the filesystem been expanded to the full size of the card?
It looks more like filesystem corruption though, which is why the filesystem is getting mounted Read Only.
After a reboot, can you post the output of:
mount
and
df -h
akehrli
Thu May 26, 2016 6:50 pm
Hello Skyline
Thanks for your reply I will test it tomorrow morning ( in Switzerland) but I guess something wrong with installation. I precise I extended partition via sudo raspi-config. I let you know
Cheers
Antoine
scruss
Thu May 26, 2016 6:55 pm
Have you tried a different card? The read-only filesystem message usually means a corrupted card.
akehrli
Fri May 27, 2016 7:54 am
Hello SkyLine ans Scruss,
Please find here result of mount command:
[email protected]:~ $ mount
/dev/mmcblk0p2 on / type ext4 (rw,noatime,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=469544k,nr_inodes=117386,mode=755)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=22,pgrp=1,timeout=300,minproto=5,maxproto=5,direct)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
configfs on /sys/kernel/config type configfs (rw,relatime)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=94776k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
and for ressources with df -h command, here is result:
[email protected]:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        15G  3.4G   11G  25% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           463M     0  463M   0% /dev/shm
tmpfs           463M  6.4M  457M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           463M     0  463M   0% /sys/fs/cgroup
/dev/mmcblk0p1   63M   21M   43M  33% /boot
tmpfs            93M     0   93M   0% /run/user/1000
but As Cruss said, perhaps SD is bad, but I have not a one availble right now....
Antoine
akehrli
Wed Jun 01, 2016 8:19 am
Just to say my problem coming from my kingston SD card, even if it was compliant with Raspberry, now it is working well with my SanDisk ultra. I find it's a bit a pity to be annoying by such problem, because all memory support, compliant in terms of size, class, read/write ops should work. On my opinion this problem doesn't help Raspberry if we consider a newbie can be easily discouraged, and then will give up this fantastic support to quickly. but it's only my opinion.
Antoine
PS: I don't now where I can set this topic as solved...
blaablaaguy
Wed Jun 01, 2016 1:02 pm
akehrli wrote:Hello,
Antoine
Just edit yourp posts title with [Solved] in front of the name
This signature intentionally left blank.
