blaablaaguy
Help setting up wifi
Tue May 24, 2016 3:20 pm
Set up wifi on jessie litw according to this tutorial and installed the gui. Now in the taskbar i get two screens with 3 dots on them where the wifi icon normally is, and when i click on it it says "no wireless interfaces found".
How can i get it back to normal so i can use it to connect to different wifi connections?
EDIT: I forgot the link didnt i? I am such and idiot. http://raspberrypihq.com/how-to-add-wif ... pberry-pi/
This signature intentionally left blank.
SteveDee
Re: Help setting up wifi
Thu May 26, 2016 5:56 am
If you are still having problems with this, I can only suggest you follow my guide, which has more diagnostic steps than the one you were following. (http://captainbodgit.blogspot.co.uk/201 ... ry-pi.html)
Generally, the default interfaces file is OK to get started, and I prefer to add entries for access points to wpa_supplicant.
